Not Identified on the PC
I had entered a 12V in the 5V PIn by mistake, and some smoke get out from the board :roll_eyes: ]:D ........ the Arduino do no be identified on the pc after that, what should I do ??
Is it a UNO ? Non-SMD then you might give it a try by purchasing another Atmega328p with arduino bootloader and replacing the current on the board.
saravananm92: Is it a UNO ? Non-SMD then you might give it a try by purchasing another Atmega328p with arduino bootloader and replacing the current on the board.
Yes it is UNO R3 , I think that ATmega328p is working well because the last sketch is save on it and it is working well .....what is the arduino bootloader ?
So the Usb ttl conversion might have fried. Try the loopback test.
