i loaded all the drivers as per instructions on web site. opened the blink file and uploaded it. it works fine. Then i tried to load the button file and got this message: avrdude: stk500_getsync(): not in sync: resp=0x00
I have since rebooted, changed com ports, usb ports, tried to update drivers. reset the board and upload.
and just so you know i'm new to every aspect of this... to include posting on a forum!
• Start the Arduino IDE
• Click the menu item Tools then Serial Port. Ensure the correct serial port is selected.
• Click the menu item Tools then Serial Monitor
• Continue with the loop-back test
i just tried again with a different usb cable and didn't get the chime. I pulled out the jumpers and plugged it in and got a chime. then i reinstalled the jumpers and got the chime. the plugged in chime sounds different than normal. lower, possibly a sort of not good connection sound. ran the serial monitor no echo
I must have worded the questions poorly. I'll try this wording...
• Disconnect the Arduino from the computer
• Remove the jumpers
• Open Device Manager.
? Are COM1, COM3, and COM4 listed under Ports?
? Are any Unknown devices present anywhere in the tree?
• Connect the Arduino.
? Did the computer chime?
i loaded the driver to that port it now shows as com5 under coms and ports i run the serial monitor and it echoes what i type i try to upload the revised blink file (made the light blink on for longer and off for shorter) and get the new sync error
i would also recommend taking all jumpers off the board before trying to upload! works great now. Thank you for all your help. I was getting frustrated!
