not in sync?
code:
[const int pingPin = 7;
long duration, inches, cm;
pinMode(pingPin, OUTPUT);
digitalWrite(pingPin, LOW);
delayMicroseconds(2);
digitalWrite(pingPin, HIGH);
delayMicroseconds(5);
pinMode(pingPin, INPUT);
duration = pulseIn(pingPin, HIGH);
inches = microsecondsToInches(duration);
cm = microsecondsToCentimeters(duration);
Serial.print(inches);
Serial.print("in, ");
Serial.print(cm);
Serial.print("cm");
delay(100);
long microsecondsToInches(long microseconds) {
return microseconds / 74 / 2;
long microsecondsToCentimeters(long microseconds) {
return microseconds / 29 / 2;
error message:Arduino: 1.6.12 (Mac OS X), Board: "Arduino Nano, ATmega328"
Sketch uses 2,642 bytes (8%) of program storage space. Maximum is 30,720 bytes.
Global variables use 194 bytes (9%) of dynamic memory, leaving 1,854 bytes for local variables. Maximum is 2,048 bytes.
/Users/svteacher/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino6/bin/avrdude -C/Users/svteacher/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino6/etc/avrdude.conf -v -patmega328p -carduino -P/dev/cu.wchusbserial620 -b57600 -D -Uflash:w:/var/folders/_h/cw2_jv2j0kb8m4shtlxb48900000gq/T/arduino_build_337768/qweert.ino.hex:i
avrdude: Version 6.3, compiled on Sep 12 2016 at 17:22:25
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "/Users/svteacher/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino6/etc/avrdude.conf"
User configuration file is "/Users/svteacher/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/cu.wchusbserial620
Using Programmer : arduino
Overriding Baud Rate : 57600
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
avrdude done. Thank you.
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
option enabled in File -> Preferences.
its on the nano
WOW 26 posts and still doesn't know how to post code and error messages.
"stk500" would fit very well in the "search box" at the top of the page too.
Even maybe with "resp=0x00"
