Hello Team,
I was using Beta version 11 with a program for the NodeMCU 1.0 (ESP-12E module) at com11 and that is working fine. I can upload the software and see on the build in Arduino IDE serial monitor the data what is send to the monitor. I can even switch to different communication ports on the computer.
I update too version 12 and use the same setup and software as in Beta 11, I was not able to select a com port at all. In the option Tools there is no option available such as "port"or "serial" with a section option of the existing com ports. Also in the drop down section at the top "Select board & port" it is not possible to select a port.
I am still using windows 7
It happens sporadically with me. If I disconnect the processor from the PC and then reconnect it, the IDE finds a port again.
This is a small (annoying) mistake.
I have experienced something like this and reported it here:
opened 03:54PM - 23 Oct 21 UTC
closed 08:31AM - 17 Oct 22 UTC
topic: code
type: imperfection
**Describe the bug**
From time to time, the IDE exhibits the follow symptoms … when I open it:
- No ports are shown under the IDE's board/port menu
- The "**Select Board**" dialog (accessed via "**Select Other Board & Port**") shows "**NO PORTS DISCOVERED**"
- The **Tools > Port** menu is missing
However there are multiple detectable Arduino boards and generic serial ports on my computer and other times when I start the IDE the ports are detected just as expected.
**To Reproduce**
1. Start Arduino IDE
1. Check if ports are listed. If so, then exit IDE and start again at step 1.
Command line looks like this when the issue occurs:
<details>
<summary>Click to expand</summary>
```text
daemon INFO starting discovery builtin:serial-discovery process
daemon INFO starting discovery builtin:mdns-discovery process
daemon INFO started discovery builtin:serial-discovery process
daemon INFO sending command HELLO 1 "arduino-cli 0.19.1" to discovery builtin:serial-discovery
daemon INFO started discovery builtin:mdns-discovery process
daemon INFO sending command HELLO 1 "arduino-cli 0.19.1" to discovery builtin:mdns-discovery
daemon INFO from discovery builtin:serial-discovery received message type: hello, message: OK, protocol version: 1
daemon INFO from discovery builtin:mdns-discovery received message type: hello, message: OK, protocol version: 1
daemon INFO sending command START_SYNC to discovery builtin:serial-discovery
daemon INFO sending command START_SYNC to discovery builtin:mdns-discovery
daemon INFO from discovery builtin:mdns-discovery received message type: start_sync, message: OK
daemon INFO from discovery builtin:serial-discovery received message type: start_sync, message: OK
daemon INFO from discovery builtin:serial-discovery received message type: add, port: COM3
daemon INFO from discovery builtin:serial-discovery received message type: add, port: COM255
daemon INFO from discovery builtin:serial-discovery received message type: add, port: COM1
daemon INFO from discovery builtin:serial-discovery received message type: add, port: COM7
daemon INFO from discovery builtin:serial-discovery received message type: add, port: COM6
daemon INFO from discovery builtin:serial-discovery received message type: add, port: COM254
root WARN Frontend EditorNavigationContribution.onStart is slow, took: 6466.7 ms
root WARN Frontend WorkspaceService.onStart is slow, took: 175.1 ms
root INFO Changed application state from 'init' to 'started_contributions'.
root INFO Changed application state from 'started_contributions' to 'attached_shell'.
root INFO >>> Restoring the layout state...
root INFO [hosted-plugin: 6156] PLUGIN_HOST(6156) starting instance
root INFO [8115205c-c018-490d-b338-36be2ff33303] Sync of 5 plugins took: 512.1 ms
root ERROR Could not restore layout
root INFO Changed application state from 'attached_shell' to 'initialized_layout'.
root INFO [8115205c-c018-490d-b338-36be2ff33303][marus25.cortex-debug]: Loaded contributions.
root INFO [8115205c-c018-490d-b338-36be2ff33303][arduino.vscode-arduino-tools]: Loaded contributions.
root INFO [8115205c-c018-490d-b338-36be2ff33303][vscode.cpp]: Loaded contributions.
root INFO [8115205c-c018-490d-b338-36be2ff33303][vscode.json]: Loaded contributions.
root INFO [8115205c-c018-490d-b338-36be2ff33303][vscode.json-language-features]: Loaded contributions.
root INFO [8115205c-c018-490d-b338-36be2ff33303] Load contributions of 5 plugins took: 145.0 ms
root WARN Frontend EditorPreviewTreeDecorator.onDidInitializeLayout is slow, took: 146.0 ms
root WARN 'cpp' language is remapped from 'source.cpp.embedded.macro' to 'source.cpp' scope
root WARN a registered grammar configuration for 'cpp' language is overridden
root INFO [hosted-plugin: 6156] PLUGIN_HOST(6156): PluginManagerExtImpl/init()
root INFO [hosted-plugin: 6156] PLUGIN_HOST(6156): initializing(cortex-debug@0.3.10 with C:\ide 2\arduino-ide_2.0.0-beta.11-snapshot.846c22c_Windows_64bit\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 6156] Debugger contribution has been registered: cortex-debug
root INFO [hosted-plugin: 6156] PLUGIN_HOST(6156): initializing(vscode-arduino-tools@0.0.1-beta.1 with C:\ide 2\arduino-ide_2.0.0-beta.11-snapshot.846c22c_Windows_64bit\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 6156] PLUGIN_HOST(6156): initializing(cpp@1.52.1 with C:\ide 2\arduino-ide_2.0.0-beta.11-snapshot.846c22c_Windows_64bit\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 6156] PLUGIN_HOST(6156): initializing(json@1.46.1 with C:\ide 2\arduino-ide_2.0.0-beta.11-snapshot.846c22c_Windows_64bit\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 6156] PLUGIN_HOST(6156): initializing(json-language-features@1.46.1 with C:\ide 2\arduino-ide_2.0.0-beta.11-snapshot.846c22c_Windows_64bit\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 6156] PLUGIN_HOST(6156): PluginManagerExtImpl/loadPlugin(C:\ide 2\arduino-ide_2.0.0-beta.11-snapshot.846c22c_Windows_64bit\resources\app\plugins\vscode-builtin-json-language-features\extension\client\dist\jsonMain)
root INFO [hosted-plugin: 6156] PLUGIN_HOST(6156): PluginManagerExtImpl/loadPlugin(C:\ide 2\arduino-ide_2.0.0-beta.11-snapshot.846c22c_Windows_64bit\resources\app\plugins\vscode-arduino-tools\extension\dist\bundle)
root INFO Changed application state from 'initialized_layout' to 'ready'.
root INFO [8115205c-c018-490d-b338-36be2ff33303][marus25.cortex-debug]: Started plugin.
root INFO [8115205c-c018-490d-b338-36be2ff33303][arduino.vscode-arduino-tools]: Started plugin.
root INFO [8115205c-c018-490d-b338-36be2ff33303][vscode.cpp]: Started plugin.
root INFO [8115205c-c018-490d-b338-36be2ff33303][vscode.json]: Started plugin.
root INFO [8115205c-c018-490d-b338-36be2ff33303][vscode.json-language-features]: Started plugin.
root INFO [8115205c-c018-490d-b338-36be2ff33303] Start of 5 plugins took: 914.5 ms
</details>
(note that the ports were discovered even though not shown in the IDE)
Command line looks like this when the issue does not occur:
<details>
```text
daemon INFO from discovery builtin:serial-discovery received message type: add, port: COM14
root WARN Frontend EditorNavigationContribution.onStart is slow, took: 5815.9 ms
root WARN Frontend WorkspaceService.onStart is slow, took: 180.9 ms
root INFO [hosted-plugin: 12360] PLUGIN_HOST(12360) starting instance
root INFO Attached boards and available ports changed:
root INFO - New port is available on COM255
root INFO ------------------------------------------
root INFO [3d74c3ec-e34f-45d3-9f3b-f98baa68c6de] Sync of 5 plugins took: 582.2 ms
root INFO - New port is available on COM1
root INFO - Attached board: Arduino MKR WiFi 1010 [arduino:samd:mkrwifi1010] on COM14
root INFO - Attached board: Arduino Mega or Mega 2560 [arduino:avr:mega] on COM7
root INFO [3d74c3ec-e34f-45d3-9f3b-f98baa68c6de][marus25.cortex-debug]: Loaded contributions.
</details>
**Expected behavior**
All connected ports and boards are always shown in the IDE.
**Screenshots**
If applicable, add screenshots to help explain your problem.
**Desktop (please complete the following information):**
- OS: Windows 10
- Version: 2.0.0-beta.11-snapshot.846c22c
Date: 2021-10-06T15:50:55.015Z
CLI Version: 0.19.1 alpha [718bbbf2]
**Additional context**
Possibly related:
- https://github.com/arduino/arduino-ide/issues/365
- https://github.com/arduino/arduino-ide/issues/540
- https://forum.arduino.cc/t/not-possible-to-setup-a-coms-port-for-uploading-sketch/918369
Unfortunately, the issue occurs intermittently (maybe once every 10 open/close cycles) and I have not been able to identify any pattern to its occurrence. I have not noticed any correlation with
I have never had this problem with the Java IDE, even when I check it at the same time IDE2 is failing.
Thanks to [a tip from @RudolfAtHome](https://forum.arduino.cc/t/not-possible-to-setup-a-coms-port-for-uploading-sketch/918369/2?u=ptillisch), I learned that new ports are still discovered when the IDE is in this condition, including previously unrecognized ports after disconnecting and then reconnecting the board.
For me, the issue is only intermittent. If I close all Arduino IDE windows and then start the IDE again, the ports are then recognized. @HendrikDijk does the problem occur always for you, or are the ports recognized after restarting the IDE?
Thanks for mentioning this! I didn't notice that before, but I just tried it and it is the same for me. I have updated the issue report above with that information.
system
Closed
April 25, 2022, 5:25am
4
