Not powering via the USB
I want to use the USB connector for debugging etc , but don’t want the Arduino powered via this connection.
I had thought of just making up an adapter with the 5v line disconnected . I’m unsure if this will work , in that data will still transfer , also bothered that the data connection may try to backfeed the Arduino and power it ( I guess I could put a couple of 10k resistors in the data lines to stop this ).
I’ve seen mention of removing components from the board , but would rather avoid that . This is not a board specific question as it’s come up a couple of times in projects ( Mega2560, nano, Uno).
Any thoughts or pointers ?
Thx
Did find this tip on Google for DATA ONLY.
And this topic from a different location which would suggest it may well be worth the effort.
If it works splice in and fit a switch then you have best of both worlds.
Bob.
And another hit via google
