I have Arduino Nano 33 IOT and SdCard module on SPI
I connected it according to his doc
It looks like this
When running code from examples -> Cardinfo.ino
It doesn't detect mine card. I formated it on fat32 then on fat16 still no luck.
Serial output from running cardinof looks like this:
Initializing SD card...
Initializing SD card...Wiring is correct and a card is present.
Card type: SD1
Could not find FAT16/FAT32 partition.
Make sure you've formatted the card
Card type: SD1
Initializing SD card...initialization failed. Things to check:
* is a card inserted?
* is your wiring correct?
* did you change the chipSelect pin to match your shield or module?
Note: press reset button on the board and reopen this Serial Monitor after fixing your issue!
The last entry is quite interesting. Seems that sometimes it fails. Maybe it is because of breadboard connecions, or maybe something else.
What could be the possible problem here?
