I am trying to learn about using those cheap ESP8266 ESP-01 and sending and receiving data from the Arduino. I think I have most of this demo worked out but I am getting gibberish as a response from Adafruit IO. The program starts, connects to my WiFi and sends the number to Adafruit IO, I can see it in my feed but (and I could be mistaken here) I think the demo code is supposed to receive a resopnse back and it is not working for me. I did not write the code so maybe I am not understanding the issue but it is coming back as "Feed not found". Any help is appreciated and I will be gald to answer any questions. Thank you in advance.
Tom
#include "Arduino.h"
#include <SoftwareSerial.h>
SoftwareSerial espSerial(10,11);
String IO_USERNAME = ""; //paste username here
String IO_KEY = ""; //paste key here
String WIFI_SSID = ""; //Only need to change if using other network, eduroam won't work
String WIFI_PASS = ""; //Blank for open network
int num = 1; //Counts up to show upload working
boolean debug = true; //Whether or not to print responses from the ESP in the serial monitor
espSerial.begin(9600);
Serial.println("setting up");
String resp = espData("get_macaddr",2000,debug);
resp = espData("wifi_ssid="+WIFI_SSID,2000,debug);
resp = espData("wifi_pass="+WIFI_PASS,2000,debug);
resp = espData("io_user="+IO_USERNAME,2000,debug);
resp = espData("io_key="+IO_KEY,2000,debug);
resp = espData("setup_io",15000,debug);
if(resp.indexOf("connected") < 0){
Serial.println("\nAdafruit IO Connection Failed");
while(1);
resp = espData("setup_feed=1,test feed",2000,debug);
Serial.println("------ Setup Complete ----------");
// Wait a few seconds between uploads
// Adafruit IO only allows 30 uploads/minute, it discards everything else
delay(5000);
Serial.print("Num is: ");
Serial.println(num);
String resp = espData("send_data=1,"+String(num),2000,debug);
num++;
String espData(String command, const int timeout, boolean debug)
String response = "";
espSerial.println(command);
long int time = millis();
while ( (time + timeout) > millis())
while (espSerial.available())
char c = espSerial.read();
response += c;
//Serial.print(c);
if (debug)
Serial.println("Resp: "+response);
response.trim();
return response;
