[NOT RESOLVED] HTML Problem
Hi, i have a problem with my html site made with arduino. The site consists in a series of button that turn on/off some leds, and empty spaces that indicate the status of the leds. The problem is: when i click "Accendi" (turn on), the led turns on, and when the page is refreshed, the empty space becomes green (turned on). When I click "spegni" (turn off) from the touch display connected with the arduino, the led turns off, but when the page is refreshed, the empty space becomes red (turned off) and the led turns on because there is still the html request from "Accendi". There are any ways to clear or modify the html request or to fix this problem?
Don't cross-post! Your other post: http://forum.arduino.cc/index.php?topic=481828.msg3289356#msg3289356
Almost certainly. But, since you are the only one that can see your code, only you can fix this problem.
You are unlikely to get any help unless you post your Arduino code and your HTML.
And of course, when I write post, I mean post PROPERLY.
Sorry but all the program are 800 lines, so these are the main lines for the problem
#include <Adafruit_Sensor.h>
#include <DHT.h>
#include <DHT_U.h>
#include <dht11.h>
#include <SPI.h>
#include <TimerOne.h>
#include <Keypad.h>
#include <RTClib.h>
#include <Wire.h>
#include <Dns.h>
#include <Ethernet.h>
#include <Client.h>
#include <Server.h>
//--------------------------- LCD ---------------------------
LiquidCrystal_I2C lcd(0x3F, 16, 2);
//--------------------------- RTC ---------------------------
RTC_DS1307 rtc;
//---------------------------- DHT --------------------------
#define TSOGG    22
#define TCUC     23
#define TCAM     24
#define TBAGNO   26
#define TFUORI   27
#define DHTTYPE  DHT22
DHT_Unified dht22(TFUORI, DHTTYPE);
sensors_event_t event;
dht11 DHT;
int chk;
bool errDht = false;
int tSogg;
//--------------------------- LUCI --------------------------
#define LSOGG    7
#define LCUC     5
#define LCAM     6
#define LBAGNO   8
#define LCORR    9
#define LFUORI   28
#define LED      29
bool statoLSOGG = false;
bool statoLCUC = false;
bool statoLCAM = false;
bool statoLBAGNO = false;
bool statoLCORR = false;
bool statoLFUORI = false;
//-------------------------- LADRI --------------------------
#define SSOGG    43
#define SCUC     44
#define SCAM     45
#define SBAGNO   47
bool statoVentola = false;
//---------------------------- GAS ---------------------------
#define GSOGG    A0
#define GCUC     A1
float sensor_volt;
float RS_air;
float RS_gas;
float R0s;
float R0c;
float sensorValue;
float ratioc;
float ratios;
bool gasRilevato = false;
//--------------------------- ALTRO --------------------------
#define BUZZER   3
#define INA      30
#define INB      31
//-------------------------- ETHERNET ------------------------
byte mac[] = {0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED};                                  //Indirizzo MAC
byte ip[] = {192, 168, 1, 134};                                                     //Indirizzo IP
byte subnet[] = {255, 255, 255, 0};                                                 //Subnet mask
EthernetServer server(80);                                                          //Porta http per la connessione per la connessione con il server
String readString;
bool premuto1;
bool premuto2;
bool premuto3;
bool premuto4;
bool premuto5;
bool premuto6;
bool premutoV;
//-------------------------- KEYPAD --------------------------
const byte ROWS = 4;
const byte COLS = 3;
char hexaKeys[ROWS][COLS] = {
  {'1', '2', '3'},
  {'4', '5', '6'},
  {'7', '8', '9'},
  {'*', '0', '#'}
byte rowPins[ROWS] = {38, 37, 36, 35};
byte colPins[COLS] = {34, 33, 32};
Keypad keypad = Keypad( makeKeymap(hexaKeys), rowPins, colPins, ROWS, COLS);          //Creazione oggetto keypad
//------------------------- VARIABILI ------------------------
bool sec = false;
bool bitE = true;
bool alarm = false;
bool working;
int luce1 = 3;
boolean vent1 = NULL;
boolean luce2 = NULL;
boolean luce3 = NULL;
boolean luce4 = NULL;
boolean luce5 = NULL;
boolean luce6 = NULL;
bool acc = false;
int statoCode = 0;
int code;
int due = 2000;
int temp;
int dieci;
long previousMills = 0;
char lb;
char hb;
char codeC;
char key;
char bt[3];
  Serial.begin(38400);
  Serial1.begin(38400);
  Wire.begin();
  //--------------------------- PIN --------------------------
  pinMode(BUZZER, OUTPUT);      //Buzzer
  pinMode(LSOGG,  OUTPUT);      //Luce Soggiorno
  pinMode(LCUC,   OUTPUT);      //Luce Cucina
  pinMode(LCAM,   OUTPUT);      //Luce Camera1
  pinMode(LBAGNO, OUTPUT);      //Luce Bagno
  pinMode(LCORR,  OUTPUT);      //Luce Corridoio
  pinMode(LFUORI, OUTPUT);      //Luce Fuori
  pinMode(LED,    OUTPUT);      //LED Allarme
  pinMode(INA,    OUTPUT);      //Input A Ventola
  pinMode(INB,    OUTPUT);      //Input B Ventola
  pinMode(SSOGG,   INPUT);      //Switch Soggiorno
  pinMode(SCUC,    INPUT);      //Switch Cucina
  pinMode(SCAM,    INPUT);      //Switch Camera
  pinMode(SBAGNO,  INPUT);      //Switch Bagno
  pinMode(GSOGG,   INPUT);      //Gas Soggiorno
  pinMode(GCUC,    INPUT);      //Gas Cucina
  //-------------------------- LCD ---------------------------
  lcd.init();
  lcd.backlight();
  lcd.clear();
  //-------------------------- DHT ---------------------------
  dht22.begin();
  //-------------------------- GAS ---------------------------
  initGas(GSOGG);
  initGas(GCUC);
  //-------------------------- RTC ---------------------------
  //rtc.adjust(DateTime(2017, 05, 11, 14, 29, 30));
  //------------------------- TIMER --------------------------
  Timer1.initialize(1000000);                                                         //Tempo dell'interupt impostato 1000000ms = 1sec
  Timer1.attachInterrupt( timerOneS );                                                //Funzione da chiamare quando scatta l'interupt
  Ethernet.begin(mac, ip, subnet);
  server.begin();
void ventola() {        //Attivazione ventola in modo automatico ad una certa temperatura
  chk = DHT.read(TSOGG);
  tSogg = DHT.temperature;
  if (tSogg > 28)
    digitalWrite(INA, LOW);
    digitalWrite(INB, HIGH);
    digitalWrite(INB, LOW);
  Serial.println(tSogg);
void initGas(int pin) {                                                              //Calcolo del valore dell'aria pulita (effetuato solo una volta ad inizo programma)
  for (int x = 0 ; x < 100 ; x++)
    sensorValue = sensorValue + analogRead(pin);
  sensorValue = sensorValue / 100.0;                                                  //Test su 100 misure
  sensor_volt = sensorValue / 1024 * 5.0;
  RS_air = (5.0 - sensor_volt) / sensor_volt;
  if (pin == GSOGG) {
    R0s = RS_air / 9.8;
    //Serial.println(R0s);
  else {
    R0c = RS_air / 9.8;
    // Serial.println(R0c);
void gas(int pin) {        //Calcolo del valore di gas nell'aria
  sensorValue = analogRead(pin);
  sensor_volt = (float)sensorValue / 1024 * 5.0;
  RS_gas = (5.0 - sensor_volt) / sensor_volt;
  if (pin == GSOGG) {
    ratios = RS_gas / R0s;
  else {        //Confronto dei valori rilevati con quelli ad aria pulita
    ratioc = RS_gas / R0c;
  if (ratioc  < 7 || ratios < 7 ) {
    gasRilevato = true;
    Serial.print("Gas");
void timerOneS()        //Interupt 1sec
  sec = true;
  dieci++;
void activeAlarm() {        //Accensione Allarme
  digitalWrite(LED, HIGH);
  tone(BUZZER, 1000);
void shutAlarm() {        //Spegnimento Allarme
  digitalWrite(LED, LOW);
  noTone(BUZZER);
void checkAlarm()        //Controllo Antifurto
  if (digitalRead(SSOGG) /*|| digitalRead(SCUC) || digitalRead(SCAM) || digitalRead(SBAGNO)*/)
    activeAlarm();
    shutAlarm();
void controlloLuci() {        //Controllo luci dal sito
  if (luce1 == 1)
    digitalWrite(LSOGG, HIGH);
    statoLSOGG = true;
    luce1 = 3;
  if (luce1 == 0) {
    digitalWrite(LSOGG, LOW);
    statoLSOGG = false;
    luce1 = 3;
  if (vent1) {
    acc = true;
    vent1 = NULL;
  if (!vent1) {
    Serial.print(vent1);
    acc = false;
    vent1 = NULL;
  if (luce2) {
    digitalWrite(LCUC, HIGH);
    statoLCUC = true;
    luce2 = NULL;
  if (!luce2) {
    digitalWrite(LCUC, LOW);
    statoLCUC = false;
    luce2 = NULL;
  if (luce3) {
    digitalWrite(LCAM, HIGH);
    statoLCAM = true;
    luce3 = NULL;
  if (!luce3) {
    digitalWrite(LCAM, LOW);
    statoLCAM = false;
    luce3 = NULL;
  if (luce4) {
    digitalWrite(LBAGNO, HIGH);
    statoLBAGNO = true;
    luce4 = NULL;
  if (!luce4) {
    digitalWrite(LBAGNO, LOW);
    luce4 = NULL;
  if (luce5) {
    digitalWrite(LFUORI, HIGH);
    statoLFUORI = true;
    luce5 = NULL;
  if (!luce5) {
    digitalWrite(LFUORI, LOW);
    luce5 = NULL;
  if (luce6) {
    digitalWrite(LCORR, HIGH);
    statoLCORR = true;
    luce6 = NULL;
  if (!luce6) {
    digitalWrite(LCORR, LOW);
    statoLCORR = false;
    luce6 = NULL;
void controlloBT() {        //Controllo dati inviati dal bluetooth
  switch (bt[0])
    case 'a':
      dht22.temperature().getEvent(&event);
      lb = (int) event.temperature & 0xFF;
      Serial.print(event.temperature);
      Serial.print(lb);
      Serial1.write(lb);
      bt[0] = 0;
    case 'b':
      if (!digitalRead(LFUORI)) {
        statoLFUORI = true;
      bt[0] = 0;
    case 'c':
      chk = DHT.read(TCAM);
      Serial.print(DHT.temperature);
      Serial1.write(DHT.temperature);
      bt[0] = 0;
    case 'd':
      if (!digitalRead(LCAM)) {
        statoLCAM = true;
        statoLCAM = false;
      bt[0] = 0;
    case 'e':
      chk = DHT.read(TBAGNO);
      bt[0] = 0;
    case 'f':
      if (!digitalRead(LBAGNO)) {
        statoLBAGNO = true;
      bt[0] = 0;
    case 'g':
      bt[0] = 0;
    case 'h':
      if (!digitalRead(LSOGG)) {
        statoLSOGG = true;
        statoLSOGG = false;
      bt[0] = 0;
    case 'i':
      if (acc) {
        Serial.println("Spengo");
        acc = false;
        Serial.println("Accendo");
        acc = true;
      bt[0] = 0;
    case 'l':
      chk = DHT.read(TCUC);
      bt[0] = 0;
    case 'm':
      if (!digitalRead(LCUC)) {
        statoLCUC = true;
        statoLCUC = false;
      bt[0] = 0;
    case 'n':
      if (!digitalRead(LCORR)) {
        statoLCORR = true;
        statoLCORR = false;
      bt[0] = 0;
void checkKey() {
  key = keypad.getKey();
  if (key >= '0' && key <= '9') {
    Serial.println(key);
    working = true;
    checkCode();
  if (Serial1.available()) {
    bt[0] = Serial1.read();
    bt[1] = Serial1.read();
    bt[2] = Serial1.read();
    Serial.println(bt[0]);
  if (bitE) {
    lcd.clear();
    lcd.setCursor(0, 1);
    lcd.print("PIN ALLARME:");
    noTone(BUZZER);
  if (sec) {
    agg_oraLcd();
    sec = false;
    gas(GSOGG);
    gas(GCUC);
  if (dieci == 10) {
    dieci = 0;
    //ventola();
  controlloBT();
  checkKey();
  if (gasRilevato)
    activeAlarm();
  if (alarm)
    checkAlarm();
  if (client) {
    while (client.connected()) {
      boolean currentLineIsBlank = true;
      if (client.available()) {
        char c = client.read();
        //read char by char HTTP request
        if (readString.length() < 100) {
          //store characters to string
          readString += c;
          //Serial.print(c);
        //if HTTP request has ended
        if (c == '\n'  && currentLineIsBlank) {
This is the last one
          //CREA LA PAGINA HTML (VERRA' AGGIORNATA AD OGNI ISTRUZIONE NUOVA)
          client.println("Content-Type: text/html");
          client.println("Connection: close");  // the connection will be closed after completion of the response
          client.println("Refresh: 10");  // refresh the page automatically every 5 sec
          client.println();
          client.println("<!DOCTYPE HTML>");
          client.println(F("<html><head> <title> Casa Domotica </title> <meta charset=UTF-8/></head><body style=background-color:powderblue;>"));
          client.println(F("<h1 align=center style=color:red>Casa Domotica</h1> "));
          client.println(F("<div align=center valign=middle>"));
          client.println(F("<table>"));
          client.println(F("<tr>"));
          client.println(F("<td >Luce Soggiorno</td>"));
          client.println(F("<td><a href='?L1=1' name=L1 value=1><button> Accendi </button></a></td> "));
          if (statoLSOGG) {
            client.println(F("<td style=background-color:lime;> &#160 &#160 &#160 &#160 &#160 &#160</td>"));
          else {
            client.println(F("<td style=background-color:red;>  &#160 &#160 &#160 &#160 &#160 &#160</td>"));
          client.println(F("<td><a href='?L1=0' name=L1 value=0><button> Spegni </button></a></td>"));
          client.println(F("<td> Temperatura Soggiorno: </td>"));
          client.println(F("<td>"));
          client.println(DHT.temperature);
          client.println(F("</td>"));
          client.println(F("</tr>"));
          client.println(F("<td >Ventola</td>"));
          client.println(F("<td><a href='?V1=1' name=V1 value=1><button> Accendi</button></a></td> "));
          if (acc) {
            client.println(F("<td style=background-color:lime;>  &#160 &#160 &#160 &#160 &#160 &#160   </td>"));
          else {
            client.println(F("<td style=background-color:red;>  &#160 &#160 &#160 &#160 &#160 &#160   </td>"));
          client.println(F("<td><a href='?V1=0' name=V1 value=0><button> Spegni</button></a></td>"));
          client.println(F("<td >Luce Cucina</td>"));
          client.println(F("<td><a href='?L2=1' name=L2 value=1><button> Accendi</button></a></td> "));
          if (statoLCUC) {
          else {
          client.println(F("<td><a href='?L2=0' name=L2 value=0;><button> Spegni</button></a></td>"));
          client.println(F("<td> Temperatura Cucina: </td>"));
          client.println(F("<td >Luce Camera</td>"));
          client.println(F("<td><a href='?L3=1' name=L3 value=1><button> Accendi </button></a></td> "));
          if (statoLCAM) {
          else {
          client.println(F("<td><a href='?L3=0' name=L3 value=0><button> Spegni </button></a></td>"));
          client.println(F("<td> Temperatura Camera: </td>"));
          client.println(F("</table>"));
          client.println(F("</div>"));
          client.println(F("
          client.println(F("
          client.println(F("
          client.println(F("
          client.println(F("<p align=right> &#169 Bortolozzo Federico, Finotello Alessandro, Giordano Luca. </p>"));
          //CHIUDE I TAG HTML PER LA PAGINA
          client.println(F("</body></html>"));
          client.flush();
            if (readString.indexOf("L1=1") > 0)
            luce1 = 1;
            if (readString.indexOf("V1=1") > 0)
            vent1 = true;
            else if (readString.indexOf("L2=1") > 0)
            luce2 = true;
            if (readString.indexOf("L3=1") > 0)
            luce3 = true;
            else if (readString.indexOf("L4=1") > 0)
            luce4 = true;
            else if (readString.indexOf("L5=1") > 0)
            luce5 = true;
            else if (readString.indexOf("L6=1") > 0)
            luce6 = true;
            else if (readString.indexOf("L1=0") > 0)
            luce1 = 0;
            premuto1 = true;
            if (readString.indexOf("V1=0") > 0)
            vent1 = false;
            premutoV = true;
            else if (readString.indexOf("L2=0") > 0)
            luce2 = false;
            premuto2 = true;
            else if (readString.indexOf("L3=0") > 0)
            luce3 = false;
            premuto3 = true;
            else if (readString.indexOf("L4=0") > 0)
            luce4 = false;
            premuto4 = true;
            else if (readString.indexOf("L5=0") > 0)
            luce5 = false;
            premuto5 = true;
            else if (readString.indexOf("L6=0") > 0)
            luce6 = false;
            premuto6 = true;
            controlloLuci();
        if (c == '\n') {
          // you're starting a new line
        } else if (c != '\r') {
          // you've gotten a character on the current line
          currentLineIsBlank = false;
    //SI PREPARA PER UNA NUOVA ISTRUZIONE
    readString = "";
    delay(1);
    //TERMINA LE OPERAZIONI CLIENTE
    client.stop();
