Not saving or loading data from EEPROM correctly
Hey, could somebody help me with my code? I took existing code for a "midi preset box" and changed it to suit my needs. I'm getting hung up on correctly saving, or loading the data from EEPROM. I've tried searching quite a bit, but can't find anything similar on how the original programmer wrote the code that saves/loads to EEPROM.
I can enter all of the information that I need into the preset box. It brings it up correctly when I switch presets and banks. I press the save (select) button and it saves correctly. Everything is good while it's still powered on. If I power it down and back on, all of the settings are wrong. Can somebody take a look to see what I'm doing wrong here?
Here is the bit of code that I believe to be the issue:
void storePreset(int bank, int preset)
  int address = (bank*100) + (preset*20);
  superDelay[bank][preset].storeData(address);
void loadPreSets() //load all presets from EEPROM
  superDelay[0][0].loadData(0);
  superDelay[0][1].loadData(20);
  superDelay[0][2].loadData(40);
  superDelay[1][0].loadData(100);
  superDelay[1][1].loadData(120);
  superDelay[1][2].loadData(140);
  superDelay[2][0].loadData(200);
  superDelay[2][1].loadData(220);
  superDelay[2][2].loadData(240);
You can find the original files at GitHub - vongon/Midi-Preset-Box: An Arduino based MIDI Preset Box to the increase flexibility of the audio effect pedal, MOOG MF-104m Super Delay..
The original box only had 3 banks with 1 preset each. I changed the code to have 100 banks with 20 presets each. This is a lot more than I'd ever need though. I'm not sure how I'd need to change the code depending on how many banks and presets are chosen.
THANK YOU!!
Here is the rest of the code for my preset box:
Example code for the Adafruit RGB Character LCD Shield and Library
This code displays text on the shield, and also reads the buttons on the keypad.
When a button is pressed, the backlight changes color.
// include the library code:
#include <Wire.h>
#include <Adafruit_MCP23017.h>
#include <Adafruit_RGBLCDShield.h>
#include <MF104.h>
#include <EEPROM.h>
// These #defines make it easy to set the backlight color
#define RED 0x1
#define YELLOW 0x3
#define GREEN 0x2
#define TEAL 0x6
#define BLUE 0x4
#define VIOLET 0x5
#define WHITE 0x7
//decalre MF104 object
#define totalParameters 19
MF104 superDelay[3][3];
int GlobalBank = 1; //start on bank 1
int GlobalPreset = 1; //start on preset 1
int GlobalParameter = 1; //start on parameter 1
int GlobalValue;
// The shield uses the I2C SCL and SDA pins. On classic Arduinos
// this is Analog 4 and 5 so you can't use those for analogRead() anymore
// However, you can connect other I2C sensors to the I2C bus and share
// the I2C bus.
Adafruit_RGBLCDShield lcd = Adafruit_RGBLCDShield();
  Serial.begin(31250);
  lcd.begin(16, 2);
  lcd.setBacklight(RED);
  initializePins(4,10,8);
  loadPreSets();
  GlobalValue = superDelay[GlobalBank][GlobalPreset].getValue(GlobalParameter);
  updateLCD(GlobalBank, GlobalPreset, GlobalParameter, GlobalValue);
uint8_t i=0;
int prevMidiValue;
int prevBS1;
int prevBS2;
int prevBS3;
  uint8_t buttons = lcd.readButtons();
  GlobalValue = readPot(A0);
  int buttonState1 = digitalRead(4);
  int buttonState2 = digitalRead(10);
  int buttonState3 = digitalRead(8);
  if (GlobalValue != prevMidiValue) //Knob is changed
      //lcd.clear();
      updateLCDvalue(GlobalValue);
      superDelay[GlobalBank][GlobalPreset].setValue(GlobalParameter,GlobalValue);
      superDelay[GlobalBank][GlobalPreset].sendSettings();
      prevMidiValue = GlobalValue;
      delay(50);
  if (buttons) //Selection Buttons are Changed
    if (buttons == 0x12) //LEFT + RIGHT Pressed
      GlobalBank++;
      if(GlobalBank > 100)
        GlobalBank = 1;
      delay(5);
      delay(5);
      delay(400);
    else if (buttons & BUTTON_UP) //RIGHT Pressed
      GlobalPreset++;
      if(GlobalPreset > 20)
        GlobalPreset = 1;
      delay(5);
      delay(5);
      delay(150);
    else if (buttons & BUTTON_DOWN) //LEFT Pressed
      GlobalPreset--;
      if(GlobalPreset < 1)
        GlobalPreset = 20;
      delay(5);
      delay(5);
      delay(150);
    else if (buttons & BUTTON_LEFT) //UP Pressed
      GlobalParameter--;
      if(GlobalParameter < 1) //check for edge
        GlobalParameter = totalParameters;
      delay(150);
    else if (buttons & BUTTON_RIGHT) //DOWN Pressed
      GlobalParameter++;
      if(GlobalParameter > totalParameters) //check for edge
      delay(150);
    else if (buttons & BUTTON_SELECT) //SELECT Pressed
      storePreset(GlobalBank, GlobalPreset);
      //superDelay[GlobalBank][GlobalPreset].sendSettings();
      lcd.clear();
      lcd.setCursor(5,0); lcd.print("PRESET");
      lcd.setCursor(5,1); lcd.print("SAVED!");
      delay(800);
  //store "previous" states so we can detect changes
  prevBS1 = buttonState1;
  prevBS2 = buttonState2;
  prevBS3 = buttonState3;
void initializePins(int A, int B, int C)
     pinMode(A, INPUT);
     pinMode(B, INPUT);
     pinMode(C, INPUT);
int readPot(int port)
   int sensorValue = analogRead(port);
   return sensorValue * (127.0/1023.0);
void updateLCD(int bank, int preset, int parameter, int value)
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.print(bank); lcd.print("-");
    lcd.print(preset); lcd.print(":");
    printParameterName(parameter);
    lcd.setCursor(0,1);
    lcd.print("VALUE:"); lcd.print(value);
void updateLCDvalue(int value)
    lcd.setCursor(6,1);
    lcd.print(value);
    lcd.print("  ");
void printParameterName(int parameter)
  switch(parameter)
    case 1:
      lcd.print("Output Level");
    case 2:
      lcd.print("Time");
    case 3:
      lcd.print("Feedback");
    case 4:
      lcd.print("Mix");
    case 5:
      lcd.print("LFO Rate");
    case 6:
      lcd.print("LFO Amount");
    case 7:
      lcd.print("LFO Waveform");
    case 8:
      lcd.print("Range");
    case 9:
      lcd.print("Time Slew Rate");
    case 10:
      lcd.print("EQ");
    case 11:
      lcd.print("Dly Time Mult");
    case 12:
      lcd.print("LFO Phase Reset");
    case 13:
      lcd.print("LFO ClkDiv");
    case 14:
      lcd.print("Time ClkDiv");
    case 15:
      lcd.print("Spillover");
    case 16:
      lcd.print("Triplets");
    case 17:
      lcd.print("Tap Dest");
    case 18:
      lcd.print("LED Div");
    case 19:
      lcd.print("Bypass");
