I am working on a project where accelerometer data will need to be read live and interpreted/analysed using some software or a programming language. After analysis, a corresponding signal would need to be sent to the servo.
Since all of this needs to happen live (and quickly), are there any recommendations what I could use to analyse the accelerometer data? I was thinking of using matlab as I am most familiar with it.
I think you need to provide more detail as to your setup, or people will make assumptions about what you have and what exactly you wish to do.
I will make the assumption that you have an accelerometer connected to an Arduino and that you are reading the data fine to this point.
Is your question more about how best to get that data into a computer and what is the best method in terms of programing language to use to then do some crunching on that data?
If so, then you need to detail what operating system you intend to use, GNU/Linux or Mac OS-X or that other one which I have trouble saying
Also, detail how the servo is connected, as in, is it on the same device as the accelerometer sensor or is it connected directly from the computer?
Tallk about communications as well, as in, do you use serial (USB) or Ethernet or wireless.
Too little detail, too many assumptions to give any concise answers for you.
