Hi. I’m trying to call the fastLED library function Fire2012(); when my DFplayer is playing but I’m not sure where to insert the function call. Probably I will have to add some more code so it’s continues to go during the play period of DFplayer.
Thanks for any help.
#include <FastLED.h>
#include "SoftwareSerial.h"
//................DFplayer variables.........
SoftwareSerial mySerial(10, 11);
# define Start_Byte 0x7E
# define Version_Byte 0xFF
# define Command_Length 0x06
# define End_Byte 0xEF
# define Acknowledge 0x00
# define ACTIVATED LOW
//......DFplayer variables........
int buttonPause = A0;
int volumeUp = A2;
int volumeDown = A4;
int playNextButton = 2;
boolean isPlaying = false;
//................DFplayer END.........
#define LED_PIN 6
#define COLOR_ORDER GRB
#define CHIPSET WS2812
#define NUM_LEDS 8
#define BRIGHTNESS 150
#define FRAMES_PER_SECOND 60
bool gReverseDirection = false;
CRGB leds[NUM_LEDS];
//FastLed setup..........
delay(3000); // sanity delay
FastLED.addLeds<CHIPSET, LED_PIN, COLOR_ORDER>(leds, NUM_LEDS).setCorrection( TypicalLEDStrip );
FastLED.setBrightness( BRIGHTNESS );
//.............DFplayer setup.................
pinMode(buttonPause, INPUT);
digitalWrite(buttonPause, HIGH);
pinMode(volumeUp, INPUT);
digitalWrite(volumeUp, HIGH);
pinMode(volumeDown, INPUT);
digitalWrite(volumeDown, HIGH);
pinMode(playNextButton, INPUT);
digitalWrite(playNextButton, HIGH);
int volume = 10; // A number 1 - 30. 30 is max volume
mySerial.begin (9600);
playFirst();
//.......MY volume.........
setVolume(volume);
isPlaying = true;
//.............DFplayer setup END...........
// Fire2012(); // run simulation frame
// FastLED.show(); // display this frame
// FastLED.delay(1000 / FRAMES_PER_SECOND);
if(digitalRead(buttonPause) == ACTIVATED)
if (isPlaying)
pause();
isPlaying = false;
} else
isPlaying = true;
play();
if (digitalRead(playNextButton) == ACTIVATED)
if(isPlaying)
playNext();
if (digitalRead(volumeUp) == ACTIVATED)
if (isPlaying)
VOL_UP();
if (digitalRead(volumeDown) == ACTIVATED)
if (isPlaying)
VOL_DWN();
//................DFplayer loop end.............
}// close loop
//...................DFplayer functions....................
void playFirst()
execute_CMD(0x3F, 0, 0);
setVolume(20);
execute_CMD(0x11, 0, 1);
void pause()
execute_CMD(0x0E, 0, 0);
void play()
execute_CMD(0x0D, 0, 1);
void playNext()
execute_CMD(0x01, 0, 1);
void playPrevious()
execute_CMD(0x02, 0, 1);
void setVolume(int volume)
execute_CMD(0x06, 0, volume); // Set the volume (0x00~0x30)
delay(2000);
//.......my additional CMDs....................
I got the commands for DFplayer from here:
https://github.com/neskweek/DFPlayer/blob/master/DFPlayer_SoftwareSerial.h
void VOL_UP()
execute_CMD(0x04, 0, 1);
void VOL_DWN()
execute_CMD(0x05, 0, 1);
//.......my additional CMDs.END................
void execute_CMD(byte CMD, byte Par1, byte Par2)
// Excecute the command and parameters
// Calculate the checksum (2 bytes)
word checksum = -(Version_Byte + Command_Length + CMD +
Acknowledge + Par1 + Par2);
// Build the command line
byte Command_line[10] = { Start_Byte, Version_Byte, Command_Length,
CMD, Acknowledge,
Par1, Par2, highByte(checksum), lowByte(checksum), End_Byte
//Send the command line to the module
for (byte k = 0; k < 10; k++)
mySerial.write( Command_line[k]);
//...................DFplayer functions END................
//...........fastLed....functions
// Default 50, suggested range 20-100
#define COOLING 55
// SPARKING: What chance (out of 255) is there that a new spark will be lit?
// Higher chance = more roaring fire. Lower chance = more flickery fire.
// Default 120, suggested range 50-200.
#define SPARKING 120
void Fire2012()
// Array of temperature readings at each simulation cell
static byte heat[NUM_LEDS];
// Step 1. Cool down every cell a little
for( int i = 0; i < NUM_LEDS; i++) {
heat[i] = qsub8( heat[i], random8(0, ((COOLING * 10) / NUM_LEDS) + 2));
// Step 2. Heat from each cell drifts 'up' and diffuses a little
for( int k= NUM_LEDS - 1; k >= 2; k--) {
heat[k] = (heat[k - 1] + heat[k - 2] + heat[k - 2] ) / 3;
// Step 3. Randomly ignite new 'sparks' of heat near the bottom
if( random8() < SPARKING ) {
int y = random8(7);
heat[y] = qadd8( heat[y], random8(160,255) );
// Step 4. Map from heat cells to LED colors
for( int j = 0; j < NUM_LEDS; j++) {
CRGB color = HeatColor( heat[j]);
int pixelnumber;
if( gReverseDirection ) {
pixelnumber = (NUM_LEDS-1) - j;
pixelnumber = j;
leds[pixelnumber] = color;
