Hi everyone !
I don't understand how those two codes work... The first one works exactly as I want but with the Serial.available and I want an automatic check (purpose of the second code)
In the first one, the interrupt work perfectly without incressing the value of the rain falls even if I called many time RainRate()
In the second one, I check the time to execute and check RainRate(), but the value start te increase and never stop.
Can you please tell me what happen ??
Thanks a lot !!
1st Code :
// Hardware pin definitions
// digital I/O pins
const byte RAIN = 2;
// Constants
const byte RAIN_PERIOD = 60;
const byte SWITCH_BOUNCE = 10;
const float RAIN_PER_INT = 0.011;
const int MSECS_TO_SEC = 1000;
const byte SECS_TO_MIN = 60;
const byte MINS_TO_HOUR = 60;
const byte HOURS_TO_24H = 24;
// Global Variables to keep track of things
// Various timers and indices
long lastSecond;
byte seconds = 0;
byte minutes = 0;
byte hours = 0;
// volatiles are subject to modification by IRQs
volatile float rainHour[60]; //60 floating numbers to keep track of 60 minutes of rain
volatile unsigned long raintime, rainlast, raininterval;
//Interrupt routines (these are called by the hardware interrupts, not by the main code)
void rainIRQ()
// Count rain gauge bucket tips as they occur
// Activated by the magnet and reed switch in the rain gauge, attached to input D2
raintime = millis(); // grab current time
raininterval = raintime - rainlast; // calculate interval between this and last event
if (raininterval > SWITCH_BOUNCE) // ignore switch-bounce glitches less than 10mS after initial edge
rainHour[minutes] += RAIN_PER_INT; //Increase this minute's amount of rain
rainlast = raintime; // set up for next event
pinMode(RAIN, INPUT_PULLUP); // input from wind meters rain gauge sensor
lastSecond = millis();
// attach external interrupt pins to IRQ functions
attachInterrupt(0, rainIRQ, FALLING);
// Zero out the arrays
int i;
for (i = 0; i < RAIN_PERIOD; i++)
rainHour[i] = 0;
// turn on interrupts
interrupts();
// Ascom command handlers
void RainRate()
float rainRate;
for (int i = 0; i < RAIN_PERIOD; i++)
rainRate += rainHour[i];
Serial.println(rainRate,5);
//Keep track of which minute it is
if(millis() - lastSecond >= MSECS_TO_SEC)
lastSecond += MSECS_TO_SEC;
// Calculate all weather readings
// Calc rain
calc_rain();
// Calc Wind
String command = "";
if (Serial.available() > 0) {
command = Serial.readStringUntil('\n');
if (command.equalsIgnoreCase("RR")) {
// Rain rate (Ascom needs mm/hour)
// This property can be interpreted as 0.0 = Dry any positive nonzero value = wet.
// Rainfall intensity is classified according to the rate of precipitation:
// Light rain — when the precipitation rate is < 2.5 mm (0.098 in) per hour
// Moderate rain — when the precipitation rate is between 2.5 mm (0.098 in) - 7.6 mm (0.30 in) or 10 mm (0.39 in) per hour
// Heavy rain — when the precipitation rate is > 7.6 mm (0.30 in) per hour, or between 10 mm (0.39 in) and 50 mm (2.0 in) per hour
// Violent rain — when the precipitation rate is > 50 mm (2.0 in) per hour
RainRate();
/* } else if (command.equalsIgnoreCase("WG")) {
// Wind gust (Ascom needs m/s) Peak 3 second wind speed over the last 2 minutes
WindGust();
} else if (command.equalsIgnoreCase("WS")) {
// Wind speed (Ascom needs m/s)
WindSpeed();
} else if (command.equalsIgnoreCase("PW")) {
printWeather();*/
void calc_rain()
if(++seconds >= SECS_TO_MIN)
seconds = 0;
if(++minutes >= MINS_TO_HOUR) minutes = 0;
rainHour[minutes] = 0; //Zero out this minute's rainfall amount
minutes = 0;
if(++minutes >= HOURS_TO_24H) hours = 0;
rainHour[hours] = 0; //Zero out this hour's rainfall amount
void printWeather()
Serial.println("*********************");
Serial.print("RR: ");
RainRate();
/*Serial.print("WG: ");
WindGust();
Serial.print("WS: ");
WindSpeed();*/
2nd code
#define T_rain 500
#define T_wind 2000
// digital I/O pins
// Constants
long lastSecond;
byte seconds = 0;
byte minutes = 0;
byte hours = 0;
long LastRainCheck = 0;
void rainIRQ()
// WIND SPEED AND RAIN SETUP
int i;
rainHour[i] = 0;
interrupts();
// TASK FUNCTIONS
// Calc rain
calc_rain();
Serial.println("Rain : "),RainRate();
void calc_rain()
seconds = 0;
/* if(++minutes >= MINS_TO_HOUR)
minutes = 0;
// FUNCTIONS FOR RAIN AND WIND SPEED
void RainRate()
float rainRate;
