Not turing left otherwise normally functioning matter
As described on the title,
Not properly functioning with left turning,
How do I fix it?
Or what part do I buy here?
I'm a newbie. Plz give me a hand~ some kind of expert here:<
Hmmm. :blush:
You appear to have stumbled onto a discussion board dealing with electronic equipment.
You perhaps want a "learn to drive" area for your particular country?
Uh - I do believe you forgot to tell us what you have and what you're trying to do with it...
Paul__B:
Hmmm. :blush:
I mean no 'how to drive'. I mean simply the broken part here instead. Describing more precisely, hmm,
Mine is a type of a 'segway PT'. It functions O.K to the right side, if I lean myself to the direction.
Only left side not go.
I'm trying to do this, because I can't get any A/S for this stuff.
O.K! anyway I can't dump this vehicle because it doesn't go to left. Otherwise it works perfectly.
Self-balancing or other functions without any problem.
In this case,
The trouble occurs from
  1. Mechanical instruments
  2. Somewhere arduino circuit
Which one is the answer? Helpers?
Just with one two points welding, I can do myself.
Any supposition is good enough for me now.
I don't even know where to go.
schematic? code?
There's something wrong with one of the two, but who knows what without seeing them...
HTCwanted:
In this case,
If you want to figure out a problem like that you need to consider the history and how the problem emerged, including events that might have caused the failure.
Questions ...
  • Did it ever work properly?
  • Did it fail suddenly or gradually?
  • Did it fail while you were using it?
  • If so, what precisely were you doing when it failed?
  • If it failed between uses )i.e. it was working perfectly when you put it away and not working next time you tried it) how long was it unused?
  • What sort of sensors does it use to detect "lean" for steering purposes?
Some diagnostic thoughts ...
  • If it can balance and move forwards and backwards (and turn right) it is very unlikely that there is a fault with the motor control circuits.
Guess ...
  • There is a failed turn sensor - which might be as simple as a loose soldered joint
...R
Robin2:
Questions ...
Guess ...
...R
Your answer helped thanx! Have a good one. At least, I have some direction to go now.
DrAzzy:
schematic? code?
Ah... schematic and code sounds horrible for me now. my major was administrative management... not electronics.:<
Just some welding I can do though. I probably should more study this one.
Thanx for your tips anyway. schematic means to be welded again and code means that I need to plug in the circuit part to my computer and coding again.
sounds like this one's gonna be very complicated.
Alright... then simple question I make now..
Oven reflow works for this one too? just like the graphic card reflow?? for the schematic part?
