Just begining to research how to use the arduino as the master in SSI communications to the AS5134 encoder.
This uses:
~ three wire SSI: DIO (dual input output), DCLK (clock signal), and CS (chip select) OR
~ two wire SSI: DIO (dual input output), DCLK (clock signal)
I think it would be possible to tie together an input and output pin and connect this to the DIO pin on the encoder, ignoring the input pin while I write to the device. My confusion is how to use the SPI library when I don't want to shift out or read in a complete number of bytes worth of bits, and how to ensure the reading is triggered promptly after completing the write?
Any pointers or do I need to consider a little extra hardware to sit between the arduino and the encoder?
Cheers,
Wesley.
Data sheet for the encoder can be found here: ams OSRAM a global leader in optical solutions | ams OSRAM
