i use a atmega328p-pu as a reciever which burned by arduino uno.but it is nor working as a reciever. i mean it does the its other duties but reciever orders is not done. if i use the arduino instead of atmega, arduino does reciever orders. so what my problem could be?
reciever code
#include <VirtualWire.h>
vw_set_ptt_inverted(true);
vw_set_rx_pin(8);
vw_setup(4000); // Bits per sec
pinMode(4, OUTPUT);
vw_rx_start(); // Start the receiver PLL running
uint8_t buf[VW_MAX_MESSAGE_LEN];
uint8_t buflen = VW_MAX_MESSAGE_LEN;
digitalWrite(9,HIGH);
if (vw_get_message(buf, &buflen)) // Non-blocking
if(buf[0]=='1'){
digitalWrite(4,HIGH);
if(buf[0]=='0'){
digitalWrite(4,LOW);
The ATmega328P needs a 16 MHz resonator (or crystal with loading capacitors), a 5V regulated power supply, and a pull-up on Reset to act as an Arduino. How is it wired? How did you program it?
i think all wires are correct because the led which on the 9th pin light. i programmed with arduino bootloader.
thank you
i try to use arduino's 328p-pu as a reciever but it did not work. so i think arduino has a part what i have to use if i want to 328p-pu as a reciever except crystal and capacitors. what it could be?
recokko:
Do you have a pull-up resistor on Reset? Do you have all of the Vcc and Gnd pins connected? Do you have AVcc connected?
I asked "How is it wired?" and you never provided an answer.
i wired 328p-pu's pin 7 and 20 to 5v, 8 and 22 to ground,9 and 10 to 16 mhz crystal then the cristal to 22 pf capacitors.
thank you
recokko:
thank you
So even after I have mentioned it TWICE you have not installed a pull-up resistor on pin 1 (Reset)?!?
How are the two capacitors connected? One should be between pin 9 and Ground and the other between pin 10 and ground.
And you don't have Pin 9 (PB1/pin 15) or Pin 4 (PD4/pin 6) connected to anything?
And your radio receiver is not connected?!? Shouldn't that got to PB3 (pin 17)?
If you don't want to bother answering in full you will have trouble getting accurate results.
no i have not installes. should i have to do it?
both capacitors between crystal and ground.
i dont have any connection.
i tested with a wire. if it passes test, i will use radio reciever.
sorry for my messages. thank you
