not working this program
the following program is for line follower.
there is no error message while compiling but this is not working for my robot.
does aurdino support do_while loop ?
what are the corrections i want to make in this program to run my robo smoothly.
my logic is, if a right turn is come, robo will take right turn until straight condition comes. other junctions are also like this.
please help.
pinMode(10,OUTPUT);
pinMode(9,OUTPUT);
pinMode(5,OUTPUT);
pinMode(6,OUTPUT);
pinMode(14,INPUT);
pinMode(15,INPUT);
pinMode(16,INPUT);
pinMode(17,INPUT);
pinMode(18,INPUT);
int S1=digitalRead(14);
int S2=digitalRead(15);
int S3=digitalRead(16);
int S4=digitalRead(17);
int S5=digitalRead(18);
if(S1==LOW && S2==LOW && S3==LOW && S4==LOW && S5==LOW) //0 0 1 0 0 NORMAL STRAIGHT
Serial.print("STRAIGHT");
digitalWrite(10,LOW); //STRAIGHT
digitalWrite(9,HIGH);
digitalWrite(5,LOW);
digitalWrite(6,HIGH);
else if (S1==LOW && S2==HIGH && S3==LOW && S4==HIGH && S5==LOW) //0 1 1 1 0 + CROSS
do
Serial.print("+ CROSS");
digitalWrite(10,LOW); //LEFT
digitalWrite(5,HIGH);
digitalWrite(6,LOW);
while(!(S1==LOW && S2==LOW && S3==LOW && S4==LOW && S5==LOW));
else if (S1==LOW && S2==HIGH && S3==LOW && S4==LOW && S5==LOW) //0 1 1 0 0 LEFT JUNCTION
do
Serial.print("LEFT JUNCTION");
else if (S1==LOW && S2==LOW && S3==LOW && S4==HIGH && S5==LOW) //0 0 1 1 0 RIGHT JUNCTION
do
Serial.print("RIGHT JUNCTION");
else if (S1==LOW && S2==HIGH && S3==HIGH && S4==LOW && S5==LOW) //0 1 0 0 0 LEFT TURN & LEFT BEND
do
Serial.print("LEFT TURN OR BEND");
else if (S1==LOW && S2==LOW && S3==HIGH && S4==HIGH && S5==LOW) //0 0 0 1 0 RIGHT TURN & RIHGT BEND
do
Serial.print("RIGHT TURN OR BEND");
digitalWrite(10,HIGH); //RIGHT
digitalWrite(9,LOW);
else if (S1==LOW && S2==LOW && S3==LOW && S4==HIGH && S5==HIGH) //0 0 1 1 1 ACUTE RIGHT
do
Serial.print("ACUTE RIGHT");
else if (S1==HIGH && S2==HIGH && S3==LOW && S4==LOW && S5==LOW) //1 1 1 0 0 ACUTE LEFT
do
Serial.print("ACUTE LEFT");
else if (S1==LOW && S2==LOW && S3==HIGH && S4==LOW && S5==LOW) //0 0 0 0 0 NO LINE
do
Serial.print("NO LINE");
digitalWrite(6,HIGH);HGJ
else if (S1==LOW && S2==HIGH && S3==HIGH && S4==HIGH && S5==LOW) //0 1 0 1 0 T JUNCTION
do
Serial.print("T JUNCTION");
yes, it is just C++
you should remove all thos do while loops as the variables tested in ti are not refreshed
try this
    pinMode(10,OUTPUT);
    pinMode(9,OUTPUT);
    pinMode(5,OUTPUT);
    pinMode(6,OUTPUT);
    pinMode(14,INPUT);
    pinMode(15,INPUT);
    pinMode(16,INPUT);
    pinMode(17,INPUT);
    pinMode(18,INPUT);
and you might replace this block
with a function
void setMotors(int m1, int m2, int m3, int m4)
        digitalWrite(10, m1);
        digitalWrite(9, m2);
        digitalWrite(5, m3);
        digitalWrite(6, m4);
that could condense your code quite a bit e.g.
Serial.println("LEFT JUNCTION");
setMotors(LOW, HIGH, HIGH, LOW);
etc
I HAVE REPLACED THE CODE TO THE FOLLOWING.
BUT ROBO TURNS LEFT AND PRINT "ACUTE RIGHT" IN SERIAL MONITOR WHEN THE SENSORS READ STRAIGHT CONDITION.
PLEASE HELP.
pinMode(10,OUTPUT);
pinMode(9,OUTPUT);
pinMode(5,OUTPUT);
pinMode(6,OUTPUT);
pinMode(14,INPUT);
pinMode(15,INPUT);
pinMode(16,INPUT);
pinMode(17,INPUT);
pinMode(18,INPUT);
void setMotors(int m1,int m2,int m3,int m4)
digitalWrite(10,m1);
digitalWrite(9,m2);
digitalWrite(5,m3);
digitalWrite(6,m4);
if(S1==HIGH && S2==HIGH && S3==LOW && S4==HIGH && S5==HIGH) //11011 NORMAL STRAIGHT
setMotors(LOW,HIGH,LOW,HIGH);
else if (S1==HIGH && S2==LOW && S3==LOW && S4==LOW && S5==HIGH) //10001 + CROSS
do
setMotors(LOW,HIGH,HIGH,LOW);
while(!(S1==HIGH && S2==HIGH && S3==LOW && S4==HIGH && S5==HIGH));
else if (S1==HIGH && S2==LOW && S3==LOW && S4==HIGH && S5==HIGH) //10011 LEFT JUNCTION
do
else if (S1==HIGH && S2==HIGH && S3==LOW && S4==LOW && S5==HIGH) //11001 RIGHT JUNCTION
do
else if (S1==HIGH && S2==LOW && S3==HIGH && S4==HIGH && S5==HIGH) //10111 LEFT TURN & LEFT BEND
do
else if (S1==HIGH && S2==HIGH && S3==HIGH && S4==LOW && S5==HIGH) //11101 RIGHT TURN & RIHGT BEND
do
setMotors(HIGH,LOW,LOW,HIGH);
else if (S1==HIGH && S2==HIGH && S3==LOW && S4==LOW && S5==LOW) //11000 ACUTE RIGHT
do
else if (S1==LOW && S2==LOW && S3==LOW && S4==HIGH && S5==HIGH) //00011 ACUTE LEFT
do
else if (S1==HIGH && S2==HIGH && S3==HIGH && S4==HIGH && S5==HIGH) //11111 NO LINE
do
else if (S1==HIGH && S2==LOW && S3==HIGH && S4==LOW && S5==HIGH) //10101 T JUNCTION
do
@ nkshaneeb, as a courtesy to people who may be willing to help you please modify your posts to show your program correctly by using the code button </>
so it looks like this
This makes it easy to select and copy to a text editor.
And please don't SHOUT
...R
You are paying a huge price in complexity for not converting the reads to digital. You have so many ifs, elses and whiles that derive from five variables. You can reduce it to one and eliminate all those pesky equality tests. From your comment, //11011, I can see that you realize things are digital. You just need to convert to a number.
Instead of:
you could do something like this:
byte inputVal;
inputVal = digitalRead(18);
inputVal |= digitalRead(17) << 1;
inputVal |= digitalRead(16) << 2;
inputVal |= digitalRead(15) << 3;
inputVal |= digitalRead(14) << 4;
  if(inputVal == 11011b)   //11011           NORMAL STRAIGHT
//.......and so on...
aarg:
That should be 0b11011.
      do
Since the values of S1 to S5 do not change in the body, you might as well use:
   if(!(S1==HIGH && S2==HIGH && S3==LOW && S4==HIGH && S5==HIGH))
      do
      while(1);
so that, once the condition becomes true, the while loop spins forever.
By the way, do/while is a pretty stupid choice in this code. A do/while statement does somethig and THEN checks to see if it should have. A while statement checks first.
aarg:
Instead of:
byte inputVal;
Better still to use switch instead of a gazillion ifs....
Regards,
Ray L.
#7 below:
http://forum.arduino.cc/index.php/topic,148850.0.html
