not working
i was trying to control LEDs with sms using Arduino Uno and Sim900 Gsm/Gprs. Im using the code attached below but its not working. Its showing "Ready" on serial monitor than no more respond. Please anyone help me as fast as possible. Im new so i not so good in coding n the term. please help me.
sorry forget to attach the code. the code is here.
led control code.txt (2.65 KB)
Please post the code as soon as possible. Use code tags, and try to think of a more helpful thread title
i already post the code. Please check it
No, didn’t post the code, you attached it
Please check it.
oh. im sorry…
#include <SoftwareSerial.h>
char inchar; // Will hold the incoming character from the GSM shield
SoftwareSerial SIM900(7, 8);
int led1 = 10;
int led2 = 11;
int led3 = 12;
int led4 = 13;
  Serial.begin(19200);
  // set up the digital pins to control
  pinMode(led1, OUTPUT);
  pinMode(led2, OUTPUT);
  pinMode(led3, OUTPUT);
  pinMode(led4, OUTPUT);
  digitalWrite(led1, LOW);
  digitalWrite(led2, LOW);
  digitalWrite(led3, LOW);
  digitalWrite(led4, LOW);
  // wake up the GSM shield
  SIM900power();
  SIM900.begin(19200);
  delay(20000);  // give time to log on to network.
  SIM900.print("AT+CMGF=1\r");  // set SMS mode to text
  delay(100);
  SIM900.print("AT+CNMI=2,2,0,0,0\r");
  // blurt out contents of new SMS upon receipt to the GSM shield's serial out
  delay(100);
  Serial.println("Ready...");
void SIM900power()
// software equivalent of pressing the GSM shield "power" button
  digitalWrite(9, HIGH);
  digitalWrite(9, LOW);
  delay(7000);
  //If a character comes in from the cellular module...
  if(SIM900.available() >0)
    inchar=SIM900.read();
    if (inchar=='#')
      delay(10);
      if (inchar=='a')
        delay(10);
        if (inchar=='0')
        else if (inchar=='1')
          digitalWrite(led1, HIGH);
        delay(10);
        if (inchar=='b')
          if (inchar=='0')
            digitalWrite(led2, HIGH);
          delay(10);
          if (inchar=='c')
            if (inchar=='0')
              digitalWrite(led3, HIGH);
            delay(10);
            if (inchar=='d')
              delay(10);
              if (inchar=='0')
                digitalWrite(led4, HIGH);
              delay(10);
          SIM900.println("AT+CMGD=1,4"); // delete all SMS
Moderator edit: the usual
You check to see if there's at least one character available to read, then you go ahead and read umpteen of them.
Please remember to use code tags when posting code.
sorry i don understand. Im not so good in coding. I checked few times but i failed. Please edit the code for me. Im in urgent.
Which SIM900 based shield? Link please.
If you want someone to write code for you you need to be in the Gigs and Collaborations section, and will need to pay for the service.
Can you please post a copy of your sketch, using code tags?
They are made with the </> icon in the reply Menu.
See section 7 http://forum.arduino.cc/index.php/topic,148850.0.html
As the OP of this thread you can go and edit the subject of this thread.
If you are serious about getting help, please edit it to something that describes your equipment and problem.
“Arduino Uno and Sim900 Gsm/Gprs, not working”
Simple!!!
Tom… :slight_smile:
Using that subject you will get forum members who are experienced in Arduino Uno and Sim900 Gsm/Gprs and possibly a fast response and solution.
Im really sorry about this. Im new here and new for Arduino.
This is the link where i brought the GSM.
http://www.tinyosshop.com/index.php?route=product/product&product_id=464
Here is my code.
int led1 = 10;
int led2 = 11;
int led3 = 12;
int led4 = 13;
  SIM900power();
  delay(100);
  delay(100);
void SIM900power()
  delay(7000);
    if (inchar=='#')
      delay(10);
      if (inchar=='a')
        delay(10);
        if (inchar=='0')
        delay(10);
        if (inchar=='b')
          if (inchar=='0')
          delay(10);
          if (inchar=='c')
            if (inchar=='0')
            delay(10);
            if (inchar=='d')
              delay(10);
              if (inchar=='0')
              delay(10);
The TinyOS shield doesn't use D7 & D8. How have you got the jumpers (opposite end of the board to the aerial) set?
Sorry. I have no idea what im doing now. I totally confused. Please let me no what to do step by steps. Sorry for trouble. :'( . I need to present it by tomorrow. Please help me. The LED can be minimize to even 1 is enough. I just want the arduino respond to the sms i send n turn on the led.
Set the jumpers at the opposite end of the board to the aerial to SW. Instead of SoftwareSerial SIM900(7, 8); use:
SoftwareSerial SIM900(2,3);
Replace SIM900power with
  digitalWrite(8, HIGH);
  digitalWrite(8, LOW);
  delay(7000);
Why do you delete all the SMS messages? Don't do that until you know it's working as then you can check the SIM card in a regular mobile/cell phone.
I change everything as u said but still not function.
Try this cut down version of your code. If it receives an SMS containing the character ‘#’ it will turn on the led on pin 13 (the onboard one).
int led4 = 13;
  Serial.println("Starting...");
  SIM900power();
  delay(100);
  delay(100);
void SIM900power()
  delay(7000);
    if (inchar=='#')
      Serial.println("LED on.");
