[NOTE] Wifi gets stuck sometimes.
Hey All,
I'm currently debugging an issue from the forum. While getting my initial tests up, just to test my Yun, the wifi got stuck.
How it get stuck
I'm sitting at a public access, namely Jack in the Box in El Paso on Redd Road.
  • The wifi is not responding to the IP it reports.
  • Then I start the YunSerialTerminal to see what is happening.
  • What I see next is a failure of negociating the QOS (Quality of Service).
  • This continues and does not stop.
  • I then hit the [WLAN RST] reset for at least 10 seconds. (Resets the Yun to default factory IP 192.168.240.1)
    I then resume my regular testing.
I do NOT know what is causing this. I'm going to have to ask at the OpenWrt forum. When I figure this out, I will post the fix here. In the meantime, you have that workaround.
Jesse
