nothing here
NA
something like this maybe:
//global variables
uint8_t i = 0;
uint8_t threshold = 0;
unsigned long t1, df = 10000;
  //whatever setup you currently have
  int data;
  if (i < 11) {
    data = mux.read(i);
    if (data > 300) {
      if (threshold == 0) {
        t1 = millis();
        threshold = 1;
      else if (millis() - t1 > df) {
        Serial.println("Threshold Detected");
        threshold = 0;
    else {
      ++i;
      threshold = 0;
      delay(1500);
  else {
    i = 0;
It should printout only if data is above threshold for more than 10s. anything less that 10s and nothing should be printed
welcome to the forums. Please read the sticky post at the top of the page - it explains how to properly post code which helps others help you.
Basically, you want to start a timer the first time threshold is exceed and check duration if the timer is already running
unsigned long startTime;
bool timerRunning = false;
const unsigned long delayTime = 10000;
  int data;
  data = mux.read(i);
  if (data > 300) {
    // above threshold, either start the timer
    // or see how long it has been this way
    if ( timerRunning == false ) {
      // start the timer
      startTime = millis();
      timerRunning = true;
      // timer already running so check the duration
      if ( millis() - startTime >= delayTime ) {
    // threshold too low, kill timer
  delay(1500);
If you want to know that something is in a particular state for a period of time then you need to check for when it is NOT in that state. Something like this
if (data < threshold) {
   timeLastFailedThreshold = millis(); // reset the timer every time the test fails
if (millis() - timeLastFailedThreshold >= interval) {
     // state has been continuously over threshold throughout interval
…R
Or record the time on every transition from below to over-threshold, if using a state-machine approach.
