Nothing showing up on display!
Hello, I recently bought an ESP32-3248S035R and I just started to play around with it. I tried displaying the temp that's being read from the M5Stack ENV III. sensor onto the screen but nothing works. The LED just blinks every 2 seconds and that's what it only does for some reason.
Here's my code:
#include <Wire.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_SHT31.h>
#include <Adafruit_ILI9341.h>
#define TFT_CLK  13
#define TFT_MISO 19
#define TFT_MOSI 23
#define TFT_CS   15
#define TFT_DC    2
#define TFT_RST   4
Adafruit_ILI9341 tft = Adafruit_ILI9341(TFT_CS, TFT_DC, TFT_RST, TFT_CLK, TFT_MISO, TFT_MOSI);
Adafruit_SHT31 sht31 = Adafruit_SHT31();
    Serial.println("Starting setup...");
    Wire.begin();
    if (!sht31.begin(0x44)) {
        Serial.println("Couldn't find SHT30");
        while (1) delay(1);
    Serial.println("SHT30 sensor initialized");
    tft.begin();
    tft.setRotation(1);
    tft.fillScreen(ILI9341_BLACK);
    tft.setTextColor(ILI9341_WHITE);
    Serial.println("ILI9341 display initialized");
    float humidity = sht31.readHumidity();
    float temperature = sht31.readTemperature();
    if (!isnan(humidity) && !isnan(temperature)) {
        tft.setCursor(10, 50);
        tft.setTextSize(2);
        tft.print("Temp: ");
        tft.print(temperature);
        tft.print("C");
        tft.setCursor(10, 80);
        tft.print("Humi: ");
        tft.print(humidity);
        tft.print("%");
        Serial.print("Temperature: ");
        Serial.print(temperature);
        Serial.print("C, Humidity: ");
        Serial.print(humidity);
        Serial.println("%");
        Serial.println("Failed to read from SHT30 sensor");
    delay(2000); // wait a little bit before reading again
Any help is appreciated! :slightly_smiling_face:
What does the Serial monitor tell you? Did both devices initialize properly? Are you seeing the temperature and humidity on the Serial Monitor every 2 seconds?
I am seeing the temperature and humidity properly in the serial monitor.
Does the display work with one of the display library example programs?
If not, solve that problem first.
Seeing that you just received your ESP32 last week. Why not learn to use it first, with ESP32 examples, before trying other devices.
I already fixed it, thank you though!
