Nothing works for crap with display screens
Well, I can connect and download code, and do simple code. Blink the LED, use a breadboard with a temp sensor.
But nothing works for crap with display screens. Although, the last stackable board at least lights up.
I've tried LCD networked screens, all kinds of variations.......I am running Arduino Linux 1.8.19
I've split this question from your original topic as it does not sound like this relates to the cloud editor.
Please give a proper description of your problem, provide a list of hardware involved (with links to what you bought) as well as your code (and error messages if you get those) and a wiring diagram.
For informed help, please read and follow the directions in the "How to get the best out of this forum" post, linked at the head of every forum category.
That happens, post an annotated schematic showing exactly how you have interconnected everything. Show all power, grounds, power sources, external hardware etc with links to non generic Arduino device technical information.
Arduino Uno R3 - not a clone
2,8 UNO shield LCD
https://www.amazon.com/Stayhome-Shield-Display-Arduino-Resistive/dp/B07QT7DSGL
Here is my code - note the 8347i is spec'd on the box for the screen, using 8347D.
Compiles and uploads ok, runs in the serial monitor - nothing on the screen.
#include <Adafruit_GFX.h> // Core graphics library
#include <HX8347D_kbv.h> // Hardware-specific library
#include <XPT2046_Touchscreen.h> // define pins, calibration, getPoint() is different
//edit begin() method in XPT2046_Touchscreen.cpp source code :
// attachInterrupt( digitalPinToInterrupt(tirqPin), isrPin, FALLING ); //.kbv
#define XPT_CS 4
#define XPT_IRQ 255 //use 3 if you fix interrupts in library source code
#define TS_LEFT 3900 //The XPT2046_Touchscreen works in Landscape
#define TS_RT 300 //I would expect Touch in Portrait
#define TS_TOP 360
#define TS_BOT 3800
HX8347D_kbv tft;
XPT2046_Touchscreen ts(XPT_CS, XPT_IRQ);
Adafruit_GFX_Button buttons[15];
// Color definitions
#define TFT_BLACK 0x0000 /* 0, 0, 0 /
#define TFT_NAVY 0x000F /
0, 0, 128 /
#define TFT_DARKGREEN 0x03E0 /
0, 128, 0 /
#define TFT_DARKCYAN 0x03EF /
0, 128, 128 /
#define TFT_MAROON 0x7800 /
128, 0, 0 /
#define TFT_PURPLE 0x780F /
128, 0, 128 /
#define TFT_OLIVE 0x7BE0 /
128, 128, 0 /
#define TFT_LIGHTGREY 0xC618 /
192, 192, 192 /
#define TFT_DARKGREY 0x7BEF /
128, 128, 128 /
#define TFT_BLUE 0x001F /
0, 0, 255 /
#define TFT_GREEN 0x07E0 /
0, 255, 0 /
#define TFT_CYAN 0x07FF /
0, 255, 255 /
#define TFT_RED 0xF800 /
255, 0, 0 /
#define TFT_MAGENTA 0xF81F /
255, 0, 255 /
#define TFT_YELLOW 0xFFE0 /
255, 255, 0 /
#define TFT_WHITE 0xFFFF /
255, 255, 255 /
#define TFT_ORANGE 0xFD20 /
255, 165, 0 /
#define TFT_GREENYELLOW 0xAFE5 /
173, 255, 47 */
#define TFT_PINK 0xF81F
/******************* UI details */
#define BUTTON_X 40
#define BUTTON_Y 100
#define BUTTON_W 60
#define BUTTON_H 30
#define BUTTON_SPACING_X 20
#define BUTTON_SPACING_Y 20
#define BUTTON_TEXTSIZE 2
// text box where numbers go
#define TEXT_X 10
#define TEXT_Y 10
#define TEXT_W 220
#define TEXT_H 50
#define TEXT_TSIZE 3
#define TEXT_TCOLOR TFT_MAGENTA
// the data (phone #) we store in the textfield
#define TEXT_LEN 12
char textfield[TEXT_LEN + 1] = "";
uint8_t textfield_i = 0;
// We have a status line for like, is FONA working
#define STATUS_X 10
#define STATUS_Y 65
/* create 15 buttons, in classic candybar phone style /
char buttonlabels[15][5] = {
"Send", "Clr", "End", "1", "2", "3", "4", "5", "6", "7", "8", "9", "
", "0", "#"
uint16_t buttoncolors[15] = {
TFT_DARKGREEN, TFT_DARKGREY, TFT_RED,
TFT_BLUE, TFT_BLUE, TFT_BLUE,
TFT_ORANGE, TFT_BLUE, TFT_ORANGE
void setup(void)
Serial.println(F("TFT LCD test"));
uint16_t ID = tft.readID();
tft.begin(ID);
tft.fillScreen(TFT_BLACK);
ts.begin(); //.kbv XPT2046_Touchscreen needs to start
// create buttons
for (uint8_t row = 0; row < 5; row++) {
for (uint8_t col = 0; col < 3; col++) {
uint8_t n = col + row * 3;
// &gfx, x, y, w, h, outline, fill, text, textsize
buttons[n].initButton(&tft, BUTTON_X + col * (BUTTON_W + BUTTON_SPACING_X),
BUTTON_Y + row * (BUTTON_H + BUTTON_SPACING_Y),
BUTTON_W, BUTTON_H, TFT_WHITE, buttoncolors[n], TFT_WHITE,
buttonlabels[n], BUTTON_TEXTSIZE);
buttons[n].drawButton();
// create 'text field'
tft.drawRect(TEXT_X, TEXT_Y, TEXT_W, TEXT_H, TFT_WHITE);
// Print something in the mini status bar with either flashstring
void status(const __FlashStringHelper *msg)
tft.fillRect(STATUS_X, STATUS_Y, 240, 8, TFT_BLACK);
tft.setCursor(STATUS_X, STATUS_Y);
tft.setTextColor(TFT_WHITE);
tft.setTextSize(1);
tft.print(msg);
// or charstring
void status(char *msg)
tft.setTextSize(1);
tft.print(msg);
void loop(void)
int x = -1, y = -1; //regular pixel coordinates
if (ts.touched()) { //XPT2046_Touchscreen can use hardware
TS_Point p = ts.getPoint(); //XPT_2046_touchscreen returns in Landscape
x = map(p.y, TS_BOT, TS_TOP, 0, tft.width());
y = map(p.x, TS_LEFT, TS_RT, 0, tft.height());
// go thru all the buttons, checking if they were pressed
for (uint8_t b = 0; b < 15; b++) {
bool down = buttons[b].contains(x, y);
buttons[b].press(down);
// now we can ask the buttons if their state has changed
if (buttons[b].justReleased()) {
// Serial.print("Released: "); Serial.println(b);
buttons[b].drawButton(); // draw normal
if (buttons[b].justPressed()) {
buttons[b].drawButton(true); // draw invert!
// if a numberpad button, append the relevant # to the textfield
if (b >= 3) {
if (textfield_i < TEXT_LEN) {
textfield[textfield_i] = buttonlabels[b][0];
textfield_i++;
textfield[textfield_i] = 0; // zero terminate
// fona.playDTMF(buttonlabels[b][0]);
// clr button! delete char
if (b == 1) {
if (textfield > 0) {
textfield_i--;
textfield[textfield_i] = ' ';
// update the current text field
Serial.println(textfield);
tft.setCursor(TEXT_X + 2, TEXT_Y + 10);
tft.setTextColor(TEXT_TCOLOR, TFT_BLACK);
tft.setTextSize(TEXT_TSIZE);
tft.print(textfield);
// its always OK to just hang up
if (b == 2) {
status(F("Hanging up"));
Serial.println("Hanging up");
tft.fillRect(TEXT_X + 1, TEXT_Y + 1, TEXT_W - 2, TEXT_H - 2, TFT_BLACK);
textfield_i = 0;
// we dont really check that the text field makes sense
// just try to call
if (b == 0) {
status(F("Calling"));
Serial.print("Calling "); Serial.println(textfield);
//fona.callPhone(textfield);
delay(100); // UI debouncing
