Notifiche push da webserver
Ciao a tutti, sto cercando i venirne a capo ma non riesco…
Devo associare un’evento di notifica push alla pressione di un bottone, lato webserver, che allo stesso tempo varia lo stato di un relè.
Sotto il codice:
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = {
  0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress ip(192,168,1, 177);
IPAddress gateway(192,168,1,1); /
IPAddress subnet(255,255,255,0);
char myserver[] = "www.notifymyandroid.com";
EthernetServer server(8083);
EthernetClient clientpush;
char Apikey[] = "1234567891011212;
  pinMode(2, OUTPUT);
  pinMode(3, OUTPUT);
  digitalWrite(2,HIGH);
  digitalWrite(3,HIGH);
  Ethernet.begin(mac, ip);
  server.begin();
  if (client)
    boolean currentLineIsBlank = true;
    String buffer = "";
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
        Serial.print(c);
        buffer+=c;
        if (c == '\n' && currentLineIsBlank)
          client.println("Content-Type: text/html");
          client.println();
          client.println("<html>");
          client.println("<head>");
          client.println("<title>Webserver</title>");
          client.println("</head>");
          client.println("<div style='width:360px; height:360px;'>");
          client.println("<ul>");
          client.println("<li><form action=\"./?1-on\" method=\"post\"><button type=\"submit\">Notifica</button>
</form></li>");
          client.println("</ul>");
          client.println("
          client.println("</div>");
          client.println("</body>");
          client.println("</html>");
        if (c == '\n')
          buffer="";
        else if (c == '\r')
          if(buffer.indexOf("POST /?1-on")>=0)
             digitalWrite(2,LOW);
             delay(200);
             sendGET(Apikey,"2","Notifica","Prova");
          currentLineIsBlank = false;
    delay(1);
    client.stop();
  }//end if client
}//end void loop
void sendGET(char Api[], char Priority[], char Eventi[],char Desc[])
  if (clientpush.connect(myserver, 80)) {
    Serial.print("connected");
    clientpush.print("GET /publicapi/notify?apikey=");
    clientpush.print(Api);
    clientpush.print("&priority=");
    clientpush.print(Priority);
    clientpush.print("&application=arduino&event=");
    clientpush.print(Eventi);
    clientpush.print("&description=");
    clientpush.print(Desc);
    clientpush.print(" HTTP/1.1");
    clientpush.print("Host: ");
    clientpush.print(myserver);
    clientpush.print("User-Agent: Arduino");
    clientpush.println();
  else {
    Serial.println("connection failed");
  while(clientpush.connected() && !clientpush.available()) delay(1); //waits for data
  while (clientpush.connected() || clientpush.available()) { //connected or data available
    char c = clientpush.read();
    Serial.print(c);
  Serial.println("disconnecting.");
  Serial.println("==================");
  clientpush.stop();
Praticamente, quando accedo al webserver da browser, mi parte il relè senza che io abbia cliccato sul bottone. Se elimino la funzione sendget funziona tutto regolarmente. Possibile che il problema derivi dal fatto che non chiudo correttamente il socket relativo alla variabile client?
Potete aiutarmi?
Grazie.
Eleonora.
dove fai l'if
tieni d'occhio il valore di buffer. Arduino ha qualche bel problema di ram, un array
Scrivi HTTP1.0 ibvece che l'HTTP1.1 e sei allineata alle specifiche :)
