Hi everyone
i bought a Arduino ENC28J60 ethernet Module and im tryng to use EtherCard examples. I tryed backSoon and it work properly but i don’t have any idea how to configure notifyMyAndroid.
I just tried to insert an API created from console.developer.google and obviouly it don’t work.
Can some one help me?
Is it Possible to associate IFTTT with ENC28J60?
Thanks for the help!
// This demo shows how to send a notification to the Notify My Android service
// Warning: Due to the limitations of the Arduino, this demo uses insecure
// HTTP to interact with the nma api (not HTTPS). The API key WILL be sent
// accross the wire in plain text.
// 2015-04-10 jc@wippler.nl
// License: GPLv2
#include <EtherCard.h>
const char apihost PROGMEM = “www.notifymyandroid.com”;
static byte mymac = { 0x74, 0x69, 0x69, 0x2D, 0x30, 0x31 };
byte Ethernet::buffer[900];
Stash stash;
static byte session;
static void notifyMyAndroid () {
byte sd = stash.create();
stash.print(“apikey=”);
stash.print(“APICODE”);
stash.print("&application=");
stash.print(“arduino”);
stash.print("&event=");
stash.print(“Ethercard Notify My Android Example”);
stash.print("&description=");
stash.print(“Test message from an Arduino!”);
stash.print("&priority=");
stash.print(“0”);
stash.save();
int stash_size = stash.size();
// Compose the http POST request, taking the headers below and appending
// previously created stash in the sd holder.
Stash::prepare(PSTR(“POST /publicapi/notify HTTP/1.1” “\r\n”
“Host: $F” “\r\n”
“Content-Length: $D” “\r\n”
“Content-Type: application/x-www-form-urlencoded” “\r\n”
“\r\n”
“$H”),
apihost, stash_size, sd);
// send the packet - this also releases all stash buffers once done
// Save the session ID so we can watch for it in the main loop.
session = ether.tcpSend();
void setup () {
Serial.begin(57600);
Serial.println("\nStarting Notify My Android Example");
// Change ‘SS’ to your Slave Select pin, if you arn’t using the default pin
if (ether.begin(sizeof Ethernet::buffer, mymac, SS) == 0)
Serial.println(F(“Failed to access Ethernet controller”));
if (!ether.dhcpSetup())
Serial.println(F(“DHCP failed”));
ether.printIp("IP: ", ether.myip);
ether.printIp("GW: ", ether.gwip);
ether.printIp("DNS: ", ether.dnsip);
if (!ether.dnsLookup(apihost))
Serial.println(F(“DNS lookup failed for the apihost”));
ether.printIp("SRV: ", ether.hisip);
notifyMyAndroid();
void loop () {
ether.packetLoop(ether.packetReceive());
const char* reply = ether.tcpReply(session);
if (reply != 0) {
Serial.println(“Got a response!”);
Serial.println(reply);
