I am attempting to compile Marlin firmware for my Creality CR-10 V2 so that I can use an E3D Hemera hotend/extruder with it. I edited the *.h files as shown in a Youtube video, using VS Code with PlatformIO. The video is titled "How to install a E3D Hemera on a Creality CR-10 v2" by 3D Printing Canada. Anyway.. When I click the "build" button, I get this error:
"c:\users\drago\onedrive\desktop\marlin-2.0.x\marlin\src\inc\MarlinConfigPre.h:39:10: fatal error: ../../Configuration.h: No such file or directory"
That's one of the files that I had to edit, so I know it's there. I'm at a loss. Nothing I have tried has led to any different results. Anybody know what I'm doing wrong here? I have zero experience with this software. I just need to upgrade my printer. :-/
Full text of error:
" > Executing task: C:\Users\drago\.platformio\penv\Scripts\platformio.exe run <
Processing mega2560 (board: megaatmega2560; platform: atmelavr@~3.4; framework: arduino)
---------------------------------------------------------------------------------------------------------------------------------------------------------------------Verbose mode can be enabled via `-v, --verbose` option
In file included from c:\users\drago\onedrive\desktop\marlin-2.0.x\marlin\src\inc\marlinconfig.h:28:0,
from buildroot/share/PlatformIO/scripts/common-dependencies.h:29:
#include "../../Configuration.h"
compilation terminated.
CalledProcessError: Command '"C:\Users\drago\.platformio\packages\toolchain-atmelavr\bin\avr-g++.exe" -D__MARLIN_FIRMWARE__ -DNDEBUG -D__MARLIN_DEPS__ -w -dM -E -x c++ buildroot/share/PlatformIO/scripts/common-dependencies.h' returned non-zero exit status 1.:
File "C:\Users\drago\.platformio\penv\lib\site-packages\platformio\builder\main.py", line 179:
env.SConscript(item, exports="env")
File "C:\Users\drago\.platformio\packages\tool-scons\scons-local-4.3.0\SCons\Script\SConscript.py", line 597:
return _SConscript(self.fs, *files, **subst_kw)
File "C:\Users\drago\.platformio\packages\tool-scons\scons-local-4.3.0\SCons\Script\SConscript.py", line 285:
exec(compile(scriptdata, scriptname, 'exec'), call_stack[-1].globals)
File "C:\Users\drago\OneDrive\Desktop\Marlin-2.0.x\buildroot\share\PlatformIO\scripts\common-dependencies.py", line 247:
apply_features_config()
File "C:\Users\drago\OneDrive\Desktop\Marlin-2.0.x\buildroot\share\PlatformIO\scripts\common-dependencies.py", line 133:
if not env.MarlinFeatureIsEnabled(feature):
File "C:\Users\drago\.platformio\packages\tool-scons\scons-local-4.3.0\SCons\Util.py", line 742:
return self.method(*nargs, **kwargs)
File "C:\Users\drago\OneDrive\Desktop\Marlin-2.0.x\buildroot\share\PlatformIO\scripts\common-dependencies.py", line 216:
load_marlin_features()
File "C:\Users\drago\OneDrive\Desktop\Marlin-2.0.x\buildroot\share\PlatformIO\scripts\common-dependencies.py", line 204:
define_list = run_preprocessor(env)
File "C:\Users\drago\OneDrive\Desktop\Marlin-2.0.x\buildroot\share\PlatformIO\scripts\preprocessor.py", line 42:
define_list = subprocess.check_output(cmd, shell=True).splitlines()
File "C:\Users\drago\.platformio\python3\lib\subprocess.py", line 424:
return run(*popenargs, stdout=PIPE, timeout=timeout, check=True,
File "C:\Users\drago\.platformio\python3\lib\subprocess.py", line 528:
raise CalledProcessError(retcode, process.args,
==================================================================== [FAILED] Took 0.65 seconds ====================================================================
Environment Status Duration
mega2560 FAILED 00:00:00.652
=============================================================== 1 failed, 0 succeeded in 00:00:00.652 ===============================================================The terminal process "C:\Users\drago\.platformio\penv\Scripts\platformio.exe 'run'" terminated with exit code: 1.
Terminal will be reused by tasks, press any key to close it."
