I'm using the sketch below to experiment with the 'SG90 micro servo' that came with my starter kit.
Q1: With the values shown I would expect to get a 180 degree sweep in both directions, but I estimate it as about 150. Trying other values, it always falls short by20-30 degrees. Is that normal?
Q2: Is there a sketch available anywhere that uses a function, with parameters (such as start and finish angle, and duration)? That might be neater and easier to use for testing.
Q3: For the project I have in mind I will probably need a servo with greater torque but still compact in size. Any recommendations before I start googling please?
Q4: On a general point, why are comments inside /* always in a faint, hard-to-read font? Can that be changed?
Any other practical advice would be appreciated please.
/* Sweep
by BARRAGAN <http://barraganstudio.com>
This example code is in the public domain.
modified 8 Nov 2013
by Scott Fitzgerald
http://www.arduino.cc/en/Tutorial/Sweep
#include <Servo.h>
Servo myservo; // create servo object to control a servo
// twelve servo objects can be created on most boards
int pos = 0; // variable to store the servo position
myservo.attach(9); // attaches the servo on pin 9 to the servo object
for (pos = 0; pos <= 180; pos += 1) { // goes from 0 degrees to 180 degrees
// in steps of 1 degree
myservo.write(pos); // tell servo to go to position in variable 'pos'
delay(15); // waits 15ms for the servo to reach the position
for (pos = 180; pos >= 0; pos -= 1) { // goes from 180 degrees to 0 degrees
