Novoferm Mix 43-2
Hi All.
I used RFControl, to try to get the value from the key. I don't try to replicate (would be hard with a rolling key)
But i need to identify which key is pushed, But i can't get a stable number! I would have expected that the unique number for a button would have been somewhere inside.
As you can see, i don't have the same "header" or any consistent data..
Any good advice?
09:59:27.045 -> b: 404 4072 804 16576 0 0 0 0
09:59:27.045 -> t: 000000000000000000000001202002022020200202022020020202020220022002022002202020020202202020200202020202202002202002200220202020202020020202202020200220200203
09:59:27.187 ->
09:59:27.373 -> b: 404 4072 804 16576 0 0 0 0
09:59:27.373 -> t: 000000000000000000000001202002022020200202022020020202020220022002022002202020020202202020200202020202202002202002200220202020202020020202202020200220200203
09:59:27.514 ->
09:59:27.697 -> b: 404 4072 804 16580 0 0 0 0
09:59:27.697 -> t: 000000000000000000000001202002022020200202022020020202020220022002022002202020020202202020200202020202202002202002200220202020202020020202202020200220200203
09:59:27.835 ->
09:59:28.022 -> b: 404 4072 804 16576 0 0 0 0
09:59:28.022 -> t: 000000000000000000000001202002022020200202022020020202020220022002022002202020020202202020200202020202202002202002200220202020202020020202202020200220200203
09:59:28.161 ->
09:59:28.349 -> b: 404 4068 804 16580 0 0 0 0
09:59:28.349 -> t: 000000000000000000000001202002022020200202022020020202020220022002022002202020020202202020200202020202202002202002200220202020202020020202202020200220200203
09:59:28.488 ->
09:59:28.673 -> b: 404 4068 804 16572 0 0 0 0
09:59:28.673 -> t: 000000000000000000000001202002022020200202022020020202020220022002022002202020020202202020200202020202202002202002200220202020202020020202202020200220200203
09:59:28.812 ->
09:59:28.996 -> b: 404 4068 804 16572 0 0 0 0
09:59:28.996 -> t: 000000000000000000000001202002022020200202022020020202020220022002022002202020020202202020200202020202202002202002200220202020202020020202202020200220200203
09:59:29.138 ->
09:59:29.325 -> b: 404 4068 804 16572 0 0 0 0
09:59:29.325 -> t: 000000000000000000000001202002022020200202022020020202020220022002022002202020020202202020200202020202202002202002200220202020202020020202202020200220200203
09:59:29.467 ->
09:59:29.654 -> b: 404 4072 804 16576 0 0 0 0
09:59:29.654 -> t: 000000000000000000000001202002022020200202022020020202020220022002022002202020020202202020200202020202202002202002200220202020202020020202202020200220200203
09:59:29.794 ->
09:59:29.980 -> b: 404 4068 804 16572 0 0 0 0
09:59:29.980 -> t: 000000000000000000000001202002022020200202022020020202020220022002022002202020020202202020200202020202202002202002200220202020202020020202202020200220200203
09:59:30.120 ->
09:59:30.308 -> b: 404 4068 804 16576 0 0 0 0
09:59:30.308 -> t: 000000000000000000000001202002022020200202022020020202020220022002022002202020020202202020200202020202202002202002200220202020202020020202202020200220200203
09:59:30.449 ->
09:59:30.636 -> b: 404 4072 804 16576 0 0 0 0
09:59:30.636 -> t: 000000000000000000000001202002022020200202022020020202020220022002022002202020020202202020200202020202202002202002200220202020202020020202202020200220200203
Is this question realted to Arduino in some way ?
Indeed :slight_smile:
I tried on my Fun board, a Nano and an ESP32, but somehow i dont get a uniform header back.
I'm using the RFControl library and tried with the examples, but dont get anything solid :slight_smile:
I was just wonderng if it might be a timer issue or if anyone had an idea where to go from here.
