NRF Scanner for ESP8266
Hi, please help me with projekt 2.4 GHz band Scanner.
I apologize in advance for possibly stupid questions. I am completely new to arduino programming.
So, I managed to find a ready-made NRF scanner project for arduino. Here is a link to github. GIT
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define OLED_RESET 4
#define CE  9
#define CHANNELS  64
int channel[CHANNELS];
int  line;
char grey[] = " .:-=+*aRW";
#define _NRF24_CONFIG      0x00
#define _NRF24_EN_AA       0x01
#define _NRF24_RF_CH       0x05
#define _NRF24_RF_SETUP    0x06
#define _NRF24_RPD         0x09
Adafruit_SSD1306 display = Adafruit_SSD1306(128, 32, &Wire);
byte count;
byte sensorArray[128];
byte drawHeight;
char filled = 'F';
char drawDirection = 'R';
char slope = 'W';
byte getRegister(byte r)
 byte c;
 PORTB &=~_BV(2);
 c = SPI.transfer(r&0x1F);
 c = SPI.transfer(0);
 PORTB |= _BV(2);
 return(c);
void setRegister(byte r, byte v)
 PORTB &=~_BV(2);
 SPI.transfer((r&0x1F)|0x20);
 SPI.transfer(v);
 PORTB |= _BV(2);
void powerUp(void)
 setRegister(_NRF24_CONFIG,getRegister(_NRF24_CONFIG)|0x02);
 delayMicroseconds(130);
void powerDown(void)
 setRegister(_NRF24_CONFIG,getRegister(_NRF24_CONFIG)&~0x02);
void enable(void)
   PORTB |= _BV(1);
void disable(void)
   PORTB &=~_BV(1);
void setRX(void)
 setRegister(_NRF24_CONFIG,getRegister(_NRF24_CONFIG)|0x01);
 enable();
 delayMicroseconds(100);
void scanChannels(void)
 disable();
 for( int j=0 ; j<200  ; j++)
   for( int i=0 ; i<CHANNELS ; i++)
     setRegister(_NRF24_RF_CH,(128*i)/CHANNELS);
     setRX();
     delayMicroseconds(40);
     disable();
     if( getRegister(_NRF24_RPD)>0 )   channel[i]++;
void outputChannels(void)
 int norm = 0;
   if( channel[i]>norm ) norm = channel[i];
 Serial.print('|');
   int pos;
   if( norm!=0 ) pos = (channel[i]*10)/norm;
   else          pos = 0;
   if( pos==0 && channel[i]>0 ) pos++;
   if( pos>9 ) pos = 9;
   Serial.print(grey[pos]);
   channel[i] = 0;
 Serial.print("| ");
 Serial.println(norm);
  display.setCursor(90, 10);
  display.setTextSize(2);
  display.setTextColor(WHITE);
  display.print(norm);
  display.setCursor(90, 8);
  display.setTextSize(1);
  display.print("");
  display.drawLine(0, 0, 0, 32, WHITE);
  display.drawLine(80, 0, 80, 32, WHITE);
  for (count = 0; count < 40; count += 10)
    display.drawLine(80, count, 75, count, WHITE);
    display.drawLine(0, count, 5, count, WHITE);
  for (count = 10; count < 80; count += 10)
    display.drawPixel(count, 0 , WHITE);
    display.drawPixel(count, 31 , WHITE);
  drawHeight = map(norm, 0, 200, 0, 32 );
  sensorArray[0] = drawHeight;
  for (count = 1; count <= 80; count++ )
    if (filled == 'D' || filled == 'd')
      if (drawDirection == 'L' || drawDirection == 'l')
        display.drawPixel(count, 32 - sensorArray[count - 1], WHITE);
      else //else, draw dots from right to left
        display.drawPixel(80 - count, 32 - sensorArray[count - 1], WHITE);
        if (slope == 'W' || slope == 'w')
          display.drawLine(count, 32, count, 32 - sensorArray[count - 1], WHITE);
          display.drawLine(count, 1, count, 32 - sensorArray[count - 1], WHITE);
          display.drawLine(80 - count, 32, 80 - count, 32 - sensorArray[count - 1], WHITE);
          display.drawLine(80 - count, 1, 80 - count, 32 - sensorArray[count - 1], WHITE);
 // drawAxises();
  display.display();
  display.clearDisplay();
  for (count = 80; count >= 2; count--)
    sensorArray[count - 1] = sensorArray[count - 2];
void printChannels(void)
 Serial.println(">      1 2  3 4  5  6 7 8  9 10 11 12 13  14                     <");
 Serial.begin(57600);
 display.begin(SSD1306_SWITCHCAPVCC, 0x3C);
 for (count = 0; count <= 128; count++)
    sensorArray[count] = 0;
 Serial.println("Starting 2.4GHz Scanner ...");
 Serial.println("Channel Layout");
 printChannels();
 SPI.begin();
 SPI.setDataMode(SPI_MODE0);
 SPI.setClockDivider(SPI_CLOCK_DIV2);
 SPI.setBitOrder(MSBFIRST);
 pinMode(CE,OUTPUT);
 disable();
 powerUp();
 setRegister(_NRF24_EN_AA,0x0);
 setRegister(_NRF24_RF_SETUP,0x0F);
 scanChannels();
 outputChannels();
 if( line++>12 )
   printChannels();
   line = 0;
This is a great project, probably it can be useful to many. But my task is to make it on ESP8266 or ESP32
However, when selecting the esp board in arduino ide, the code does not compile and throws errors.
nRF24L01pScannerOled:31:19: error: 'PORTB' was not declared in this scope
31 | #define CE_off PORTB &= 0xFD
You probably need to correct the code or use other libraries. I wrote to the author asking for help, but so far there is no answer.
I have been looking for a solution for several days now but my knowledge is not enough.
Please help me make a sketch of this project for ESP8266.
You can not make that sketch work on an ESP8266 (without an attached NRF).
You could attach an NRF to an ESP8266 to get the functionality.
You can't use ATmega328P procesor registers (like PORTB) on an ESP8266 processor.
Change "PORTB &= ~_BV(2);" to "digitalWrite(10, LOW);"
Change "PORTB |= _BV(2);" to "digitalWrite(10, HIGH);"
Change "PORTB &= ~_BV(1);" to "digitalWrite(9, LOW);"
Change "PORTB |= _BV(1);" to "digitalWrite(9, HIGH);"
Then pick pin numbers appropriate for your processor.
I thought that the decision should not be difficult. Thank you!
What decision?
