nRF24 and SD card together on Mega2560 - Issue( Solved)
The code below is a simple one to use a Mega 2560 board with a nRF24 transmitter and SD card.
Pin assignments are as below :
MISO : 50
MOSI : 51
SCK : 52
CSN of nRF24 : 53
CE of nRF24 : 9
CS of SD Card : 10
Problem is when the SD card is connected the nRF24 stops working.
When using such multiple peripherals using the same SPI bus , is there any special precaution to be taken ??
// Hardware kit used is Mega2560
#include <SPI.h>
#include <RF24.h>
#include <SdFat.h>
SdFat SD;                                           // Wrap SD members into SDFat
Sd2Card card;
/****************** Radio Config ***************************/
/* Set up nRF24L01 radio on SPI bus plus pins CE and CSN */
RF24 radio(9, 53);                                   // First pin (9) is CE and Next pin (53) is CSN
byte sdCardSelect = 10;
byte radioAddress[][6] = {"1_PRX", "2_PTX"};         // Radio pipe addresses for RemoteUnit, ThisUnit.
struct tx_dataStruct {                               // Configure your transmission data into this structure
  char lcdMessage[20];
  byte cursorRow;
  boolean gfmReset;
} txDataToRemUnit  ;
struct rx_dataStruct {
  byte RFID[4];
  char keyVal;
  long gfmData;
} rxDataFromRemUnit;
bool firstLine, secondLine ;
unsigned long myMillis;
byte copy_RFID[4];
char copy_KeyVal;
long copy_GFMData;
  Serial.println(F("*** STARTING TRANSMITTER *** "));
  checkSDCard();                                              // Check the presence of SD card
  // Setup and configure radio
  radio.begin();
  radio.setChannel(108);                                       // Above most Wifi Channels
  radio.setDataRate( RF24_250KBPS );
  radio.enableAckPayload();                                    // Allow optional ack payloads
  radio.enableDynamicPayloads();                               // Ack payloads are dynamic payloads
  radio.setRetries(5, 10);                                     // Delay, count
void loop(void)
  send_LCDInfo();
void send_LCDInfo()
  radio.openWritingPipe(radioAddress[1]);                                 // Writing Pipe to Remote Unit
  delay(5);
  strcpy(txDataToRemUnit.lcdMessage, " Sample Tx data..   ");             // Update the payload
  txDataToRemUnit.cursorRow  = 0;
  firstLine = (radio.write(&txDataToRemUnit, sizeof(txDataToRemUnit))); // Send First Line of LCD..
  Serial.println(firstLine);
  delay(5);
  readAckPayLoad(firstLine);
  myMillis = millis();
  sprintf (txDataToRemUnit.lcdMessage, "TX1 millis = %6ul", myMillis);
  txDataToRemUnit.cursorRow  = 1;
  secondLine = (radio.write(&txDataToRemUnit, sizeof(txDataToRemUnit))); // Send Second Line of LCD..
   Serial.println(secondLine);
  delay(5);
  readAckPayLoad(secondLine);
  if ( firstLine && secondLine)
    Serial.println( "RF Link Healthy !");
    Serial.println( "RF Link dead");
//FUNCTION TO READ ACK PAYLOAD AND STORE DATA TO LOCAL VARIABLES..
void readAckPayLoad (boolean txResult)
  if (txResult)
    while ( radio.available())
      radio.read( &rxDataFromRemUnit, sizeof(rxDataFromRemUnit));
      copy_GFMData = rxDataFromRemUnit.gfmData;                  // Transfer all data from ackPayLoad
      copy_KeyVal = rxDataFromRemUnit.keyVal;
      copy_RFID[0] = rxDataFromRemUnit.RFID[0];
      copy_RFID[1] = rxDataFromRemUnit.RFID[1];
      copy_RFID[2] = rxDataFromRemUnit.RFID[2];
      copy_RFID[3] = rxDataFromRemUnit.RFID[3];
// FUNCTION TO CHECK PRESENCE OF SD CARD AND ITS TYPE.
void checkSDCard ()
  if (SD.begin(sdCardSelect))
    Serial.println( "SD Card started ! ") ;
    Serial.println ( "SD Card Failure !");
  if (!card.init(SPI_HALF_SPEED, sdCardSelect))
    Serial.println("Initialization failed. CHECK !!");
    Serial.println("Wiring is correct and a card is present!!");
So looks like peopel have suffered and recovered !!
Here we go with the solution to make the SD card adapter co-exist with nRF24 :
Check out #8. Thanks to the contributor for the this !!
