After following this guide, "Getting Started with nRF24L01+ on Arduino | maniacbug" (and countless others) I'm 100% sure all my connections and power needs are correct. although i'm still receiving this error in the serial monitor shown in the picture. any ideas on what to try?
This is just an example code i'm testing with and its not working for me.
Please don't post pictures of text as they are unreadable and the text cannot be copied. Just copy and paste the text and enclose it in code tags using the </> button.
Have a look at this Simple nRF24L01+ Tutorial - the examples do work.
And note that they use the newer TMRh20 version of the RF24 library which solves some problems from the earlier ManiacBug version. Unfortunately TMRh20 did not think to change the name for his version so it is easy to get them confused. If in doubt I suggest you delete the library completely and then download and install the TMRh20 version.
...R
