Nrf24 interference
Hi everyone
I am looking for a way to transmit signals from one Arduino master 2 two Arduino slaves wirelessly.
I have looked at the nrf24 and they look really cool. Before I buy them and start working can anyone answer this!?
If I have 2 identical setups with 3 arduinos and nrf24 each running with the same code.
Would the 3 nrf24's from the first setup interfere with other setup also containing 3 nrf24 when transmitting and receiving signals??? :slight_smile:
Hope someone can help
If the different receiving nRF24s have different addresses and if there is a reasonable interval between messages then there should not be a problem.
If you use a different channel (frequency) for each system that would be even better.
...R
Simple nRF24L01+ Tutorial
Christian2222:
Yeah, they are cool and very flexible.
If you intend to use the chips, you should really study the datasheet.
The basics of operation are covered in detail in that document.
