nRF24 Mesh: Data identification
I am using RF24 Mesh with a Arduino nano. The example sketches for TMRh20's RF24 mesh library are working fine. My only issue is that how do I identify that which data is coming from which child node.
The incoming data on the master node looks like this.
********Assigned Addresses********
NodeID: 1 RF24Network Address: 05
NodeID: 2 RF24Network Address: 045
NodeID: 3 RF24Network Address: 035
271985
184000
93752
272985
185000
94752
273985
186000
95752
274985
187000
96752
275985
188000
97752
I am using the Mesh Master Example for master node and Mesh example for child or sensor nodes.
Another thing is that i want this data to send on server database, how do i do that?
P.s. This is my first time here so please don't be harsh on me and help this fellow.
What is wrong with putting an ID byte in each message? A different ID from each node.
Read the network header and look at the from node? If you showed the code it would help.
Mater Node:
/** RF24Mesh_Example_Master.ino by TMRh20
 * This example sketch shows how to manually configure a node via RF24Mesh as a master node, which
 * will receive all data from sensor nodes.
 * The nodes can change physical or logical position in the network, and reconnect through different
 * routing nodes as required. The master node manages the address assignments for the individual nodes
 * in a manner similar to DHCP.
#include "RF24Network.h"
#include "RF24.h"
#include "RF24Mesh.h"
#include <SPI.h>
/***** Configure the chosen CE,CS pins *****/
RF24 radio(7, 8);
RF24Network network(radio);
RF24Mesh mesh(radio, network);
uint32_t displayTimer = 0;
  while (!Serial) {
    // some boards need this because of native USB capability
  // Set the nodeID to 0 for the master node
  mesh.setNodeID(0);
  Serial.println(mesh.getNodeID());
  // Connect to the mesh
  if (!mesh.begin()) {
    // if mesh.begin() returns false for a master node, then radio.begin() returned false.
    Serial.println(F("Radio hardware not responding."));
    while (1) {
      // hold in an infinite loop
  // Call mesh.update to keep the network updated
  mesh.update();
  // In addition, keep the 'DHCP service' running on the master node so addresses will
  // be assigned to the sensor nodes
  mesh.DHCP();
  // Check for incoming data from the sensors
  if (network.available()) {
    RF24NetworkHeader header;
    network.peek(header);
    uint32_t dat = 0;
    switch (header.type) {
      // Display the incoming millis() values from the sensor nodes
      case 'M':
        network.read(header, &dat, sizeof(dat));
        Serial.println(dat);
      default:
        network.read(header, 0, 0);
        Serial.println(header.type);
  if (millis() - displayTimer > 5000) {
    displayTimer = millis();
    Serial.println(" ");
    Serial.println(F("********Assigned Addresses********"));
    for (int i = 0; i < mesh.addrListTop; i++) {
      Serial.print("NodeID: ");
      Serial.print(mesh.addrList[i].nodeID);
      Serial.print(" RF24Network Address: 0");
      Serial.println(mesh.addrList[i].address, OCT);
    Serial.println(F("**********************************"));
Child Nodes:
/** RF24Mesh_Example.ino by TMRh20
   This example sketch shows how to manually configure a node via RF24Mesh, and send data to the
   master node.
   The nodes will refresh their network address as soon as a single write fails. This allows the
   nodes to change position in relation to each other and the master node.
#include "RF24.h"
#include <SPI.h>
//#include <printf.h>
/**** Configure the nrf24l01 CE and CS pins ****/
RF24 radio(7, 8);
 * User Configuration: nodeID - A unique identifier for each radio. Allows addressing
 * to change dynamically with physical changes to the mesh.
 * In this example, configuration takes place below, prior to uploading the sketch to the device
 * A unique value from 1-255 must be configured for each node.
#define nodeID 1
struct payload_t {
  unsigned long ms;
  unsigned long counter;
  while (!Serial) {
  // Set the nodeID manually
  mesh.setNodeID(nodeID);
  Serial.println(F("Connecting to the mesh..."));
    if (radio.isChipConnected()) {
      do {
        // mesh.renewAddress() will return MESH_DEFAULT_ADDRESS on failure to connect
        Serial.println(F("Could not connect to network.\nConnecting to the mesh..."));
      } while (mesh.renewAddress() == MESH_DEFAULT_ADDRESS);
      while (1) {
  mesh.update();
  // Send to the master node every second
  if (millis() - displayTimer >= 1000) {
    // Send an 'M' type message containing the current millis()
    if (!mesh.write(&displayTimer, 'M', sizeof(displayTimer))) {
      // If a write fails, check connectivity to the mesh network
      if (!mesh.checkConnection()) {
        //refresh the network address
        Serial.println("Renewing Address");
        if (mesh.renewAddress() == MESH_DEFAULT_ADDRESS) {
          //If address renewal fails, reconfigure the radio and restart the mesh
          //This allows recovery from most if not all radio errors
          mesh.begin();
        Serial.println("Send fail, Test OK");
      Serial.print("Send OK: ");
      Serial.println(displayTimer);
  while (network.available()) {
    payload_t payload;
    network.read(header, &payload, sizeof(payload));
    Serial.print("Received packet #");
    Serial.print(payload.counter);
    Serial.print(" at ");
    Serial.println(payload.ms);
Is there an easy way to send this data to firebase when there are lets say 50 nodes connected to the master????
You almost have it. Before the closing } of your while loop add
   Serial.print(F("source address="));
   Serial.println(header.from_node,OCT);
to see the source address. Use octal because that is how the address are generated in the mesh code.
[EDIT]
If you look in RF24Network.h you will find the header has other useful things like to address, sequence ID, header type, etc.
