NRF24 - multiple radio.write(), radio sometimes read all, sometimes skip some
Hi guys,
My code currently has 4 radio.write() functions in successions, and I placed a delay of 100ms between them, and when I check the receiver, the radio.read() function skips one or two of the data written by the radio.
For example, let's say on the transmitter side, i placed radio.write temp, then radio.write humidity, radio.write lux, and radio.write gas sensor value.
And on the receiving side, when the transmitting arduino has been turned on for a while, it can read the values of the transmitter, but then later in the loop, it continuously reads only temp, then skips over to gas for a random amount of time, etc. Pretty much perform completely random reads.
Furthermore, sometimes the data as well isn't real-time, i.e. like I'd have to wait 5,10,12 seconds for the humidity to update after blowing air into the sensor
What's the problem here? I thought the delay would make it so that the radio will not get overwhelmed by the amount of data. Increasing the delay doesn't seem to do much too. I am also writing all these data into one pipe, because radio.write() function only writes to one pipe in one program.
Thank you for any of the replies.
The reason for these multiple radio.write() is because I have a lot of data to send that is more than 32 bytes each. The OP is just an example. I am sending these data in an array.
How is this different from your last post?
Hi Whandall,
In that post, I had radio1 to radio9 which probably wasn't the best idea to do so..
But now I have only one radio initialised on both the rx and tx, and I managed to separate the data using a char array.
Now I am currently facing another issue, which is explained in the OP.
I disagree.
The ridiculous idea of using three different radios was dismissed early on.
We discussed how to transfer data that is/seems to be too long in the old thread.
As you seemingly do not like my answer, good luck with your project.
@Whandall Sorry if I seemed like that, and thank you.
To anyone who might have the same problem, I initialised radio.openwritingpipe() based on an if statement
e.g. set addr1 = 0xF0F0F0F0A0LL, addr2 = 0xF0F0F0F0A1LL
and if int pipe1 = 1, then radio.openwritingpipe(addr1),
else if int pipe2 = 1, then radio.openwritingpipe(addr2)
on the receiver side, i would then have two radio.openreadingpipe(), that are radio.openreadingpipe(1,addr1) and
radio.openreadingpipe(2,addr2).
