I simply try to send a sensor info from an Arduino Nano to another one, both with NRF24's. They used to work but when i updated the maniacbug's RF24 library version from 1.0.1 to 1.1.3, it is now not working, even i try with the old library version.
I stripped the problem to the GettingStarted.cpp example packed in the library. Still doesn't work! I tried it with different Arduino Nanos, different NRF24's even with different cables. ![]()
Arduino IDE version is 1.6.7
Here is the code:
The only difference between sender and receiver is: radioNumber is either 0 or 1.
- Getting Started example sketch for nRF24L01+ radios
- This is a very basic example of how to send data from one node to another
- Updated: Dec 2014 by TMRh20
#include <SPI.h>
#include "RF24.h"
/****************** User Config ************************/
/ Set this radio as radio number 0 or 1 ***/
bool radioNumber = 1;
/* Hardware configuration: Set up nRF24L01 radio on SPI bus plus pins 7 & 8 /
RF24 radio(7,8);
byte addresses[][6] = {"1Node","2Node"};
// Used to control whether this node is sending or receiving
bool role = 0;
Serial.println(F("RF24/examples/GettingStarted"));
Serial.println(F("*** PRESS 'T' to begin transmitting to the other node"));
radio.begin();
// Set the PA Level low to prevent power supply related issues since this is a
// getting_started sketch, and the likelihood of close proximity of the devices. RF24_PA_MAX is default.
radio.setPALevel(RF24_PA_LOW);
// Open a writing and reading pipe on each radio, with opposite addresses
if(radioNumber){
radio.openWritingPipe(addresses[1]);
radio.openReadingPipe(1,addresses[0]);
}else{
radio.openWritingPipe(addresses[0]);
radio.openReadingPipe(1,addresses[1]);
// Start the radio listening for data
radio.startListening();
/****************** Ping Out Role ***************************/
if (role == 1) {
radio.stopListening(); // First, stop listening so we can talk.
Serial.println(F("Now sending"));
unsigned long time = micros(); // Take the time, and send it. This will block until complete
if (!radio.write( &time, sizeof(unsigned long) )){
Serial.println(F("failed"));
radio.startListening(); // Now, continue listening
unsigned long started_waiting_at = micros(); // Set up a timeout period, get the current microseconds
boolean timeout = false; // Set up a variable to indicate if a response was received or not
while ( ! radio.available() ){ // While nothing is received
if (micros() - started_waiting_at > 200000 ){ // If waited longer than 200ms, indicate timeout and exit while loop
timeout = true;
if ( timeout ){ // Describe the results
Serial.println(F("Failed, response timed out."));
}else{
unsigned long got_time; // Grab the response, compare, and send to debugging spew
radio.read( &got_time, sizeof(unsigned long) );
// Spew it
Serial.print(F("Sent "));
Serial.print(time);
Serial.print(F(", Got response "));
Serial.print(got_time);
Serial.print(F(", Round-trip delay "));
Serial.print(time-got_time);
Serial.println(F(" microseconds"));
// Try again 1s later
/****************** Pong Back Role ***************************/
if ( role == 0 )
if( radio.available()){
// Variable for the received timestamp
while (radio.available()) { // While there is data ready
radio.read( &got_time, sizeof(unsigned long) ); // Get the payload
radio.write( &got_time, sizeof(unsigned long) ); // Send the final one back.
radio.startListening(); // Now, resume listening so we catch the next packets.
Serial.print(F("Sent response "));
Serial.println(got_time);
/****************** Change Roles via Serial Commands ***************************/
if ( Serial.available() )
char c = toupper(Serial.read());
if ( c == 'T' && role == 0 ){
Serial.println(F("*** CHANGING TO TRANSMIT ROLE -- PRESS 'R' TO SWITCH BACK"));
role = 1; // Become the primary transmitter (ping out)
}else
if ( c == 'R' && role == 1 ){
Serial.println(F("*** CHANGING TO RECEIVE ROLE -- PRESS 'T' TO SWITCH BACK"));
role = 0; // Become the primary receiver (pong back)
} // Loop
Below is the outputs:
Sender----
Now sending
Now sending
Receiver----
Now sending
failed
THANK YOU!! ![]()
