NRF24 receive and print sensor readings
Hi.
I’m using the below code base on this
http://arduino-info.wikispaces.com/Nrf24L01-2.4GHz-HowTo
to read values transmitter by a second NRF used as sensor board every 5 secs or more.
Those values needed to be kept in serial monitor.
The receiving code working fine but…
i’m taking a bunch of blank lines between each sensor reading.
How can i print ONLY the transmitted values and not the blank ones ?
Thank you in advance.
/* YourDuinoStarter Example: nRF24L01 Receive Joystick values
 - WHAT IT DOES: Receives data from another transceiver with
   2 Analog values from a Joystick or 2 Potentiometers
   Displays received values on Serial Monitor
 - SEE the comments after "//" on each line below
 - CONNECTIONS: nRF24L01 Modules See:
   1 - GND
   2 - VCC 3.3V !!! NOT 5V
   3 - CE to Arduino pin 9
   4 - CSN to Arduino pin 10
   5 - SCK to Arduino pin 13
   6 - MOSI to Arduino pin 11
   7 - MISO to Arduino pin 12
   8 - UNUSED
 - V1.00 11/26/13
   Based on examples at http://www.bajdi.com/
   Questions: terry@yourduino.com */
/*-----( Import needed libraries )-----*/
#include <SPI.h>
#include <nRF24L01.h>
#include <RF24.h>
/*-----( Declare Constants and Pin Numbers )-----*/
#define CE_PIN   9
#define CSN_PIN 10
// NOTE: the "LL" at the end of the constant is "LongLong" type
const uint64_t pipe = 0xE8E8F0F0E1LL; // Define the transmit pipe
/*-----( Declare objects )-----*/
RF24 radio(CE_PIN, CSN_PIN); // Create a Radio
/*-----( Declare Variables )-----*/
//int joystick[2];  // 2 element array holding Joystick readings
void setup()   /****** SETUP: RUNS ONCE ******/
  Serial.println("Nrf24L01 Receiver Starting");
  radio.begin();
  radio.openReadingPipe(1,pipe);
  radio.startListening();;
}//--(end setup )---
void loop()   /****** LOOP: RUNS CONSTANTLY ******/
  char receivePayload[32];
  if ( radio.available() )
    // Read the data payload until we've received everything
    bool done = false;
    while (!done)
      uint8_t len = radio.getDynamicPayloadSize();
        radio.read(receivePayload, len);
      Serial.println(receivePayload);
      Serial.println("No radio available");
}//--(end main loop )---
/*-----( Declare User-written Functions )-----*/
//NONE
//*********( THE END )***********
use this method
if(income[j] != (char)-1)
       Serial.println("");
Thank you for your reply ...
you mean like this ??
    bool done = false;
    while (!done)
      // Fetch the data payload
      //done = radio.read( joystick, sizeof(joystick) );
     // Serial.print("X = ");
      if(receivePayload[32] != (char)-1)
     // Serial.println(receivePayload);
     // delay(1000);
     // Serial.print(" Y = ");
     // Serial.println(len);
