NRF24 Two ways not working
I'm using an rf 24 library to make a two ways communication between two Arduino UNOs.
One Arduino UNO is connected to NRF24L01 with an antenna, and the other is connected to a regular NRF24L01.
I plan to use the transmitter as a ground station, and the other as a drone.
So, the ground station side should show sensor data from the drone, and the drone should receive control data from the ground station.
I have connected CE and CNS to pins 7 and 8.
Using ICSP for MOSI, SCK, and MISO.
The ground station fails to radio.write().
This is for drone.
#include <SPI.h>
#include <nRF24L01.h>
#include <RF24.h>
#include <Servo.h>
// NRF
RF24 radio(7, 8); // CE, CSN
const byte thisSlaveAddress[5] = {'R','x','A','A','A'};
bool newData = false;
struct Data_Package_control {
  int c1;
  int c2;
  int c3;
  int c4;
  int c5;
struct Data_Package_sensor {
  int s1;
  int s2;
  int s3;
  int s4;
  int s5;
  int s6;
  int s7;
// Create variables with the above structures
Data_Package_control data_c;
Data_Package_sensor data_s;
// Control Surfaces
// create servo object to control a servo
// Servo aileronLServo;
  // test
  // Servo
  // aileronLServo.attach(9,600,2600);
  // NRF24
  radio.begin();
  radio.setChannel(125);
  radio.setDataRate(RF24_250KBPS);
  radio.setPALevel(RF24_PA_MIN);
  radio.openReadingPipe(1, thisSlaveAddress);
  radio.enableAckPayload();
  radio.startListening();
  radio.writeAckPayload(1, &data_s, sizeof(Data_Package_sensor));
  getData();
  showData();
void resetData() {
  // Reset the values when there is no radio connection - Set initial default values
  // aileronLServo.write(0);
  // aileronRServo.write(0);
  // servo
  // servo
  // servo
void updateMessage() {
  // new sensor data -> sensor package
  data_s.s1 = 22;
  data_s.s2 = 22;
  data_s.s3 = 22;
  data_s.s4 = 22;
  data_s.s5 = 22;
  data_s.s6 = 22;
  data_s.s7 = 22;
void getData() {
    if ( radio.available() ) {
        radio.read( &data_c, sizeof(Data_Package_control) );
        updateMessage();
        newData = true;
    else {
      Serial.println("  Failed to receive");
void showData() {
    if (newData == true) {
        // aileronLServo.write(data_c.c2);
        Serial.print("Data received ");
        Serial.println(data_c.c2);
        newData = false;
    }else{
      resetData();
This is for ground station.
#include <SPI.h>
#include <RF24.h>
const byte slaveAddress[5] = {'R','x','A','A','A'};
unsigned long currentMillis;
unsigned long prevMillis;
unsigned long txIntervalMillis = 100;
// Max size of this struct is 32 bytes - NRF24L01 buffer limit
// byte, int, float, string
  int c1;
  int c2;
  int c3;
  int c4;
  int c5;
  int s1;
  int s2;
  int s3;
  int s4;
  int s5;
  int s6;
  int s7;
// Joystick
int VRx = A0;
int VRy = A1;
int SW = 2;
int SW_state = 0;
  // Joystick
  pinMode(VRx, INPUT);
  pinMode(VRy, INPUT);
  pinMode(SW, INPUT_PULLUP);
  // NRF24
  radio.begin();
  radio.setRetries(5,5);
  radio.openWritingPipe(slaveAddress);
  currentMillis = millis();
  if (currentMillis - prevMillis >= txIntervalMillis) {
    send();
  showData();
void showData() {
    Serial.print(data_s.s1);
    Serial.print(" ");
    Serial.print(data_s.s2);
    Serial.print(" ");
    Serial.print(data_s.s3);
    Serial.print(" ");
    Serial.print(data_s.s4);
    Serial.print(" ");
    Serial.print(data_s.s5);
    Serial.print(" ");
    Serial.print(data_s.s6);
    Serial.print(" ");
    Serial.println(data_s.s7);
void send() {
  bool rslt;
  rslt = radio.write( &data_c, sizeof(Data_Package_control) );
  if (rslt) {
    if ( radio.isAckPayloadAvailable() ) {
      radio.read(&data_s, sizeof(Data_Package_sensor));
      newData = true;
    else {
      Serial.println("  Acknowledge but no data ");
      updateMessage();
    else {
      Serial.println("  Tx failed");
    prevMillis = millis();
  data_c.c1 = digitalRead(SW);
  data_c.c2 = map(analogRead(VRx), 0, 1023, 0, 180);
  data_c.c3 = map(analogRead(VRy), 0, 1023, 0, 180);
  data_c.c4 = 20;
  data_c.c5 = 40;
Can you please post schematics of your project?
How are you powering the NRF units?
Do you have a DMM?
Thanks.. Tom... :smiley: :+1: :coffee: :australia:
Hi Tom. NRF modules are powered by 3.3v output from the arduinos, and I haven't used any capacitors. Now that I think about it, I should have used them.
Never print when there is no packet available (unmoderated),
most of the time there is no packet.
