Nrf2401 and arduino
Dear friends,
I have set up a transmiter and receiver to turn on and off one Led using nrf2401 module and its ok working
Now I want to extend this and control 6 Leds on the receiver side.
Can any body please help me on this?
raminaziz:
Dear friends,
I expect lots of people could help if you gave us any hint as to what you need help with. What have you tried and what was the result?
Paul
To control 6 LEDs your probably gonna have to send two pieces of information. The led your addressing and the state.
say your leds are numbered 1 to 6 and you want to turn led 3 to on. The transmitter would send
the number of the led (3) and the state (0 , because a 0 will light up the led).
On the receive side the arduino would read the info and extract the address and state information and change the output pins that the led's are connected to.
so in this case
digitalwrite(LED3, LOW);
You don't have to use numbers you can use characters also.
normally the reciever would let the transmitter that the message was recieved.
so hopefully this gave you an idea how to go about it.
Please post the code that you have by using tags.
Have a look at this Simple nRF24L01+ Tutorial.
Wireless problems can be very difficult to debug so get the wireless part working on its own before you start adding any other features.
The examples are as simple as I could make them and they have worked for other Forum members. If you get stuck it will be easier to help with code that I am familiar with. Start by getting the first example to work
...R
Can you post the code you have already and schematic of your project please?
What model Arduinos are you using?
Thanks.. Tom.. :slight_smile:
Thank you all
I have done the simple example and it worked ok I am using two Arduino Uno at the moment but may also use Nano too.
I am sending my code for six leds but tried to work first by two leds that I got stuck with it.
here is the code for Transmitter:
#include <SPI.h>
#include <nRF24L01.h>
#include <RF24.h>
RF24 radio(9, 8); // CE, CSN
const byte address[6] = "00001";     //Byte of array representing the address. This is the address where we will send the data. This should be same on the receiving side.
int button1_pin = 2;
int button2_pin = 3;
//int button3_pin = 4;
//int button4_pin = 5;
//int button5_pin = 6;
//int button6_pin = 7;
boolean button1_state = 0;
boolean button2_state = 0;
//boolean button3_state = 0;
//boolean button4_state = 0;
//boolean button5_state = 0;
//boolean button6_state = 0;
pinMode(button1_pin, INPUT);
pinMode(button2_pin, INPUT);
//pinMode(button3_pin, INPUT);
//pinMode(button4_pin, INPUT);
//pinMode(button5_pin, INPUT);
//pinMode(button6_pin, INPUT);
radio.begin();                  //Starting the Wireless communication
radio.openWritingPipe(address); //Setting the address where we will send the data
radio.setPALevel(RF24_PA_MIN);  //You can set it as minimum or maximum depending on the distance between the transmitter and receiver.
radio.stopListening();          //This sets the module as transmitter
   button1_state = digitalRead(button1_pin);
   button2_state = digitalRead(button2_pin);
  // button3_state = digitalRead(button3_pin);
  // button4_state = digitalRead(button4_pin);
  // button5_state = digitalRead(button5_pin);
  // button6_state = digitalRead(button6_pin);
  if(button1_state == HIGH)
   const char text[] = "Button1 State is HIGH";
   Serial.println( " Button1 State is HIGH");
   radio.write(&text, sizeof(text));                  //Sending the message to receiver
  else if(button1_state == LOW)
    const char text[] = " Button1 State is LOW";
    Serial.println( "Button1 State is LOW");
  if(button2_state == HIGH)
     const char text1[] = "Button2 State is HIGH";
     Serial.println( " Button2 State is HIGH");
     radio.write(&text1, sizeof(text1));
else if(button2_state ==LOW)
   const char text1[] = "Button2 State is LOW";
   Serial.println( "Button2 State is LOW");
radio.write(&button1_state, sizeof(button1_state));  //Sending the message to receiver
 radio.write(&button2_state, sizeof(button2_state));
for the receiver side:
#include <SPI.h>
#include <RF24.h>
int led1_pin = 3;
int led2_pin = 4;
pinMode(4, OUTPUT);
pinMode(3, OUTPUT);
radio.begin();
radio.openReadingPipe(0, address);   //Setting the address at which we will receive the data
radio.setPALevel(RF24_PA_MIN);       //You can set this as minimum or maximum depending on the distance between the transmitter and receiver.
radio.startListening();              //This sets the module as receiver
if (radio.available())              //Looking for the data.
 char text[32] = "";                 //Saving the incoming data
 char text1[32] = "";
   radio.read(&text, sizeof(text));    //Reading the data
   radio.read(&button1_state, sizeof(button1_state));    //Reading the data
     digitalWrite(3, HIGH);
     Serial.println(text);
     digitalWrite(3, LOW);
     Serial.println("b 1 is Low");
    radio.read(&text1, sizeof(text1));
    radio.read(&button2_state, sizeof(button2_state));
     digitalWrite(4, HIGH);
     Serial.println(text1);
    digitalWrite(4, LOW);
    Serial.println("b 2 is low");
THe result of the above codes is the that on receiver side one led comes on and off by itself without pushing any button)and the second led dose not come on at all .independent of pushing any button.
How have you got your buttons wired?
Tom… :slight_smile:
Dear Tom
This is the connection push buttons .( not exactly the same pin numbers)
raminaziz:
If that means that you tried the first example in my Tutorial why don’t you stick with that and just modify it a little to send the switch states.
You could record the state of each switch in an array
byte switchStates[6];
for (byte n = 0; n < 6; n++) {
    switchStates[n] = digitalRead(switchPin[n];
radio.write(&switchStates, sizeof(switchStates));
In the receiver have an equivalent 6 byte array
…R
Thank you Robin2.
I have put your codes in my transmitter and shows no error so far and I am working on the receiver side now will you please see if I have done it correctly ?
#include <SPI.h>
#include <RF24.h>
//boolean switchStates[6] = 0;
int switchPin[6]={2,3,4,5,6,7};
pinMode(switchPin[6], INPUT);
    switchStates[n] = digitalRead(switchPin[n]);
if(switchStates == HIGH)
  else if(switchStates == LOW)
 radio.write(&switchStates, sizeof(switchStates));  //Sending the message to receiver
  delay(1000);}
You don't need any of this
And when working on a wireless problem always post the Tx and the Rx code because they must work as a pair.
...R
raminaziz:
Dear Tom
Sorry, no picture.
http://forum.arduino.cc/index.php/topic,148850.0.html .
Please attach the picture.
Thanks... Tom... :slight_smile:
Robin2:
You don’t need any of this
…R
Hi Robin,
Now I am sending both Tx and RX codes for your considerations.
TX Code:
#include <SPI.h>
#include <RF24.h>
      radio.write(&switchStates[n], sizeof(switchStates[n]));
       Serial.println( switchStates[n]);
  delay(10);
[code]
RX Code:
[code]
#include <SPI.h>
#include <RF24.h>
int LED_Pin[6]={2,3,4,5,6,7};
char text[32] = "";
pinMode(LED_Pin[6], OUTPUT);
radio.begin();
   radio.read(&switchStates[n], sizeof(switchStates[n]));
  radio.read(&switchStates, sizeof(switchStates));    //Reading the data
 if(switchStates[n] == HIGH)
     digitalWrite(LED_Pin[n], HIGH);
     digitalWrite(LED_Pin[n], LOW);
     Serial.println("Leds are Low");
   // radio.read(&text, sizeof(text));
  //  radio.read(switchStates[n], sizeof(switchStates[n]));
delay(10);
[code]
Unfortunately no Led will come on.
[/code]
raminaziz:
Fortunately no important devices are controlled by this unsensible try. :wink:
Put all your data in a struct/array and send one packet.
Your approach wastes a lot of bandwidth and makes it impossible to identify the sent data.
Don't read from the radio without checking available first.
Thank you Sir,
I corrected according to your advise,Now on TX side I get “0” and "1"on the monitor, and on the RX side
all leds Flickr
This is my RX code now:
#include <SPI.h>
#include <RF24.h>
char text[32] = "";
radio.begin();
  delay(2);
raminaziz:
No, you did not.
Sorry ,It means I did not understand you.
Will you please clarify more?
Whandall:
You read six packets after you check for the existance of one.
You don't use a struct/array to receive all data in one packet.
You didn't post the (hopefully better) changed tx sketch.
Thank you for your prompt reply.
I am not that expert in programming,please take me step by step.
this is my TX Code:
 #include <SPI.h>
#include <RF24.h>
    delay(5);
RX Code:
#include <SPI.h>
#include <RF24.h>
char text[32] = "";
radio.begin();
  delay(2);
