Ciao,
ho dei problemi col far funzionare la il mio robot RC che usa i due moduli in oggetto.
Sono partito da un progetto base che ho trovato in rete e di cui vi incollo il codice del ricevitore
#include <SPI.h>
#include <nRF24L01.h>
#include <RF24.h>
#define enA 2
#define in1 3
#define in2 4
#define enB 7
#define in3 5
#define in4 6
RF24 radio(8, 9); // CE, CSN
const byte address[6] = "00001";
char receivedData[32] = "";
int xAxis, yAxis;
int motorSpeedA = 0;
int motorSpeedB = 0;
pinMode(enA, OUTPUT);
pinMode(enB, OUTPUT);
pinMode(in1, OUTPUT);
pinMode(in2, OUTPUT);
pinMode(in3, OUTPUT);
pinMode(in4, OUTPUT);
radio.begin();
radio.openReadingPipe(0, address);
radio.setPALevel(RF24_PA_MIN);
radio.startListening();
if (radio.available()) { // If the NRF240L01 module received data
radio.read(&receivedData, sizeof(receivedData)); // Read the data and put it into character array
xAxis = atoi(&receivedData[0]); // Convert the data from the character array (received X value) into integer
delay(10);
yAxis = atoi(&receivedData[0]);
delay(10);
Serial.println(xAxis);
Serial.println(yAxis);
// Y-axis used for forward and backward control
if (yAxis < 470) {
// Set Motor A backward
digitalWrite(in1, HIGH);
digitalWrite(in2, LOW);
// Set Motor B backward
digitalWrite(in3, HIGH);
digitalWrite(in4, LOW);
// Convert the declining Y-axis readings for going backward from 470 to 0 into 0 to 255 value for the PWM signal for increasing the motor speed
motorSpeedA = map(yAxis, 470, 0, 0, 255);
motorSpeedB = map(yAxis, 470, 0, 0, 255);
else if (yAxis > 550) {
// Set Motor A forward
digitalWrite(in1, LOW);
digitalWrite(in2, HIGH);
// Set Motor B forward
digitalWrite(in3, LOW);
digitalWrite(in4, HIGH);
// Convert the increasing Y-axis readings for going forward from 550 to 1023 into 0 to 255 value for the PWM signal for increasing the motor speed
motorSpeedA = map(yAxis, 550, 1023, 0, 255);
motorSpeedB = map(yAxis, 550, 1023, 0, 255);
// If joystick stays in middle the motors are not moving
else {
motorSpeedA = 0;
motorSpeedB = 0;
// X-axis used for left and right control
if (xAxis < 470) {
// Convert the declining X-axis readings from 470 to 0 into increasing 0 to 255 value
int xMapped = map(xAxis, 470, 0, 0, 255);
// Move to left - decrease left motor speed, increase right motor speed
motorSpeedA = motorSpeedA + xMapped;
motorSpeedB = motorSpeedB - xMapped;
// Confine the range from 0 to 255
if (motorSpeedA < 0) {
motorSpeedA = 0;
if (motorSpeedB > 255) {
motorSpeedB = 255;
if (xAxis > 550) {
// Convert the increasing X-axis readings from 550 to 1023 into 0 to 255 value
int xMapped = map(xAxis, 550, 1023, 0, 255);
// Move right - decrease right motor speed, increase left motor speed
motorSpeedA = motorSpeedA - xMapped;
motorSpeedB = motorSpeedB + xMapped;
if (motorSpeedA > 255) {
motorSpeedA = 255;
if (motorSpeedB < 0) {
motorSpeedB = 0;
// Prevent buzzing at low speeds (Adjust according to your motors. My motors couldn't start moving if PWM value was below value of 70)
if (motorSpeedA < 70) {
motorSpeedA = 0;
if (motorSpeedB < 70) {
motorSpeedB = 0;
analogWrite(enA, motorSpeedA); // Send PWM signal to motor A
analogWrite(enB, motorSpeedB); // Send PWM signal to motor B
L'auto parte da sola in maniera casuale, il che mi ha fatto pensare che forse i pin di IN cambiano di stato in maniera casuale facendo partire i motori, anche se sono sorpreso perchè impostandoli come pin di output teoricamente dovrebbero essere a basse impedenza e non ad alta come quando sono impostati come pin di input.
Ho provato a modificare il codice attivando le resistenze di pullup interne e, se ho fatto bene (dubito) invertendo sempre i segni logici dei pin stessi. Ho provato a riscrivere quindi il codice così
/*ARDUINO JOYSTICK CONTROLLED CAR (RECEIVER)
YOU HAVE TO INSTALL THE RF24 LIBRARY BEFORE UPLOADING THE CODE
https://github.com/tmrh20/RF24/
#include <SPI.h>
#include <RF24.h>
#define enA 2
#define in1 3
#define in2 4
#define enB 7
#define in3 5
#define in4 6
int xAxis, yAxis;
pinMode(in1, INPUT_PULLUP);
pinMode(in2, INPUT_PULLUP);
pinMode(in3, INPUT_PULLUP);
pinMode(in4, INPUT_PULLUP);
digitalWrite(in1,HIGH); //motori fermi, segno logico invertito
digitalWrite(in2,HIGH);
digitalWrite(in3,HIGH);
radio.begin();
delay(10);
delay(10);
if (yAxis < 300) {
digitalWrite(in1, LOW); // in realtà alto
digitalWrite(in2, HIGH); // in realtà basso
motorSpeedA = map(yAxis, 300, 0, 0, 255);
motorSpeedB = map(yAxis, 300, 0, 0, 255);
else if (yAxis > 800) {
motorSpeedA = map(yAxis, 800, 1023, 0, 255);
motorSpeedB = map(yAxis, 800, 1023, 0, 255);
else {
motorSpeedA = 0;
motorSpeedB = 0;
if (xAxis < 300) {
int xMapped = map(xAxis, 300, 0, 0, 255);
motorSpeedA = 0;
motorSpeedB = 255;
if (xAxis > 800) {
int xMapped = map(xAxis, 800, 1023, 0, 255);
motorSpeedA = 255;
motorSpeedB = 0;
if (motorSpeedA < 150) {
motorSpeedA = 0;
motorSpeedB = 0;
E' evidente che sto sbagliando ancora qualcosa perchè appena mi avvicino per prendere la macchina dopo averla accesa parte da sola e si accende il LED RX sull'arduino Nano.
Sapreste darmi una mano?
Grazie mille
