Hello! Is anyone aware of any problems that might come when using the nRF module with Arduino Pro Mini? I've been trying to make it work but no luck so far. Basically, when I send the code with the module connected to my Mega it works fine, but when I try to do the same with the Mini it doesn't work at all (using the same nRF module).
I've been trying to make an RC transmitter joystick (https://howtomechatronics.com/projects/diy-arduino-rc-transmitter/) for my Arduino tank. Here's also the link to the PCB, select the first one (EasyEDA(Standard) - A Simple and Powerful Electronic Circuit Design Tool)
The code I'm using is just the basic GettingStarted example from the RF24 library
Copyright (C) 2011 J. Coliz <maniacbug@ymail.com>
This program is free software; you can redistribute it and/or
modify it under the terms of the GNU General Public License
version 2 as published by the Free Software Foundation.
* Example for Getting Started with nRF24L01+ radios.
* This is an example of how to use the RF24 class. Write this sketch to two
* different nodes. Put one of the nodes into 'transmit' mode by connecting
* with the serial monitor and sending a 'T'. The ping node sends the current
* time to the pong node, which responds by sending the value back. The ping
* node can then see how long the whole cycle took.
#include <SPI.h>
#include "nRF24L01.h"
#include "RF24.h"
#include "printf.h"
// Hardware configuration
// Set up nRF24L01 radio on SPI bus plus pins 9 & 10
RF24 radio(5,6);
// Topology
// Radio pipe addresses for the 2 nodes to communicate.
const uint64_t pipes[2] = { 0xF0F0F0F0E1LL, 0xF0F0F0F0D2LL };
// Role management
// Set up role. This sketch uses the same software for all the nodes
// in this system. Doing so greatly simplifies testing.
// The various roles supported by this sketch
typedef enum { role_ping_out = 1, role_pong_back } role_e;
// The debug-friendly names of those roles
const char* role_friendly_name[] = { "invalid", "Ping out", "Pong back"};
// The role of the current running sketch
role_e role = role_pong_back;
void setup(void)
// Print preamble
Serial.begin(57600);
printf_begin();
printf("\n\rRF24/examples/GettingStarted/\n\r");
printf("ROLE: %s\n\r",role_friendly_name[role]);
printf("*** PRESS 'T' to begin transmitting to the other node\n\r");
// Setup and configure rf radio
radio.begin();
radio.setAutoAck(false);
// optionally, increase the delay between retries & # of retries
radio.setRetries(15,15);
// optionally, reduce the payload size. seems to
// improve reliability
//radio.setPayloadSize(8);
// Open pipes to other nodes for communication
// This simple sketch opens two pipes for these two nodes to communicate
// back and forth.
// Open 'our' pipe for writing
// Open the 'other' pipe for reading, in position #1 (we can have up to 5 pipes open for reading)
//if ( role == role_ping_out )
//radio.openWritingPipe(pipes[0]);
radio.openReadingPipe(1,pipes[1]);
//else
//radio.openWritingPipe(pipes[1]);
//radio.openReadingPipe(1,pipes[0]);
// Start listening
radio.startListening();
// Dump the configuration of the rf unit for debugging
radio.printDetails();
void loop(void)
// Ping out role. Repeatedly send the current time
if (role == role_ping_out)
// First, stop listening so we can talk.
radio.stopListening();
// Take the time, and send it. This will block until complete
unsigned long time = millis();
printf("Now sending %lu...",time);
bool ok = radio.write( &time, sizeof(unsigned long) );
if (ok)
printf("ok...");
printf("failed.\n\r");
// Now, continue listening
// Wait here until we get a response, or timeout (250ms)
unsigned long started_waiting_at = millis();
bool timeout = false;
while ( ! radio.available() && ! timeout )
if (millis() - started_waiting_at > 200 )
timeout = true;
// Describe the results
if ( timeout )
printf("Failed, response timed out.\n\r");
// Grab the response, compare, and send to debugging spew
unsigned long got_time;
radio.read( &got_time, sizeof(unsigned long) );
// Spew it
printf("Got response %lu, round-trip delay: %lu\n\r",got_time,millis()-got_time);
// Try again 1s later
// Pong back role. Receive each packet, dump it out, and send it back
if ( role == role_pong_back )
// if there is data ready
if ( radio.available() )
// Dump the payloads until we've gotten everything
bool done = false;
while (!done)
// Fetch the payload, and see if this was the last one.
done = radio.read( &got_time, sizeof(unsigned long) );
// Spew it
printf("Got payload %lu...",got_time);
// Delay just a little bit to let the other unit
// make the transition to receiver
delay(20);
// Send the final one back.
radio.write( &got_time, sizeof(unsigned long) );
printf("Sent response.\n\r");
// Now, resume listening so we catch the next packets.
// Change roles
if ( Serial.available() )
char c = toupper(Serial.read());
if ( c == 'T' && role == role_pong_back )
printf("*** CHANGING TO TRANSMIT ROLE -- PRESS 'R' TO SWITCH BACK\n\r");
// Become the primary transmitter (ping out)
role = role_ping_out;
else if ( c == 'R' && role == role_ping_out )
printf("*** CHANGING TO RECEIVE ROLE -- PRESS 'T' TO SWITCH BACK\n\r");
// Become the primary receiver (pong back)
// vim:cin:ai:sts=2 sw=2 ft=cpp
As I said the output is fine when connected with my Mega, but when connected to the Pro Mini firstly all the addresses are set to 0, and the data send fails. The connections seem to be fine (I checked with the beeping thing on the multimeter) but it just won't work...
