(NRF24L01) 2 button state issue
We have 2 arduino's connected with an NRF24L01. There's 2 buttons on the transmitter to control the receiver. One button turns on the LED's and they change colour based off of the temperature of the room. and a second button to turn off the LED's. The problem is we had to force it by making button_state equal to high at the start of the loop and we're not sure how to make the second button make it low permanently until the ON button is pressed again. Files are attached. Any help is appreciated
Transmitter
#include <SPI.h>
#include <nRF24L01.h>
#include <RF24.h>
RF24 radio(9, 10); // CE, CSN
const byte address[6] = "00001";     //Byte of array representing the address. This is the address where we will send the data. This should be same on the receiving side.
int button_pin = 2;
int button_pin2 = 4;
boolean button_state = 0;
boolean button_state2 = 0;
  pinMode(button_pin, INPUT);
  pinMode(button_pin2, INPUT);
  radio.begin();                  //Starting the Wireless communication
  radio.openWritingPipe(address); //Setting the address where we will send the data
  radio.setPALevel(RF24_PA_MAX);  //You can set it as minimum or maximum depending on the distance between the transmitter and receiver.
  radio.stopListening();          //This sets the module as transmitter
  button_state = digitalRead(button_pin);
  button_state2 = digitalRead(button_pin2);
  if (button_state == HIGH)
    button_state == HIGH;
    const char text[] = "LED ON";
    radio.write(&text, sizeof(text));                  //Sending the message to receive
    Serial.println("ON");
  else if (button_state2 == HIGH)
    button_state == LOW;
    const char text[] = "LED OFF";
    radio.write(&text, sizeof(text));                  //Sending the message to receiver
    Serial.println("OFF");
  radio.write(&button_state, sizeof(button_state));  //Sending the message to receiver
  radio.write(&button_state2, sizeof(button_state2));  //Sending the message to receiver
  delay (200);
Receiver
//LIBRARIES
#include "RTClib.h"
#include <Wire.h>
#include <LCD.h>
#include <FastLED.h>
#include <SPI.h>
#include <RF24.h>
//PIN/VARIABLE DEFINITIONS
#define ledPin          4
#define ledNum          50
#define hue             175
#define BACKLIGHT_PIN   3
//VARIABLES
float temp;
CRGB leds[ledNum];
LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);
RTC_DS3231 rtc;
RF24 radio(9, 10);
char daysOfTheWeek[7][12] = {"Sunday", "Monday", "Tuesday", "Wednesday", "Thursday", "Friday", "Saturday"};
void setup ()
  FastLED.addLeds<WS2812, ledPin, GRB> (leds, ledNum);
  radio.begin();
  radio.openReadingPipe(0, address);
  radio.startListening();
  lcd.begin(20, 4);
  lcd.setBacklightPin(BACKLIGHT_PIN, POSITIVE);
  lcd.setBacklight(HIGH);
  if (! rtc.begin())
    Serial.println("Couldn't find RTC");
    while (1);
  if (rtc.lostPower())
    Serial.println("RTC lost power, lets set the time!");
    // following line sets the RTC to the date & time this sketch was compiled
    rtc.adjust(DateTime(2019, 12, 2, 15, 0, 10));
    // This line sets the RTC with an explicit date & time, for example to set
    // January 21, 2014 at 3am you would call:
    // rtc.adjust(DateTime(2014, 1, 21, 3, 0, 0));
void loop ()
  temp = rtc.getTemperature();
  DateTime now = rtc.now();
  if (radio.available())
    char text[32] = "";
    radio.read(&text, sizeof(text));
    radio.read(&button_state, sizeof(button_state));
    radio.read(&button_state2, sizeof(button_state2));
    button_state = HIGH;
        char text[32] = "";
      // LEDs CHANGE COLORS BASED ON TEMP
      if (temp <= 26.00)
        for (int i = 0; i < 50; i++)
          leds[i] = CRGB(0, 0, hue);
          FastLED.show();
          delay(10);
        lcd.setCursor(2, 4);
        lcd.print("Status: COLD" );
      if ((temp > 26.00) && (temp < 29.00))
          leds[i] = CRGB(0, hue, 0);
          FastLED.show();
          delay(10);
        lcd.print("Status: GOOD" );
      if (temp >= 29.00)
          leds[i] = CRGB(hue, 0, 0);
          FastLED.show();
          delay(10);
        lcd.print("Status: HOT!" );
      Serial.println("loop 1");
      char text[32] = "";
        leds[i] = CRGB(0, 0, 0);
        FastLED.show();
        delay(10);
      Serial.println("loop 2");
    //TIME(HOUR, MIN, SEC) LCD DISPLAY
    lcd.setCursor(2, 0); //column & row
    lcd.print("Time: ");
    lcd.print(now.hour(), DEC);
    lcd.print(':');
    lcd.print(now.minute(), DEC);
    lcd.print(':');
    lcd.print(now.second(), DEC);
    //DATE(MONTH, DAY, YEAR) LCD DISPLAY
    lcd.setCursor(2, 1);
    lcd.print(daysOfTheWeek[now.dayOfTheWeek()]);
    lcd.print(" ");
    lcd.print(now.month(), DEC);
    lcd.print("/");
    lcd.print(now.day(), DEC);
    lcd.print("/");
    lcd.print(now.year(), DEC);
    //TEMP(TEMP) LCD DISPLAY
    lcd.setCursor(2, 2);
    lcd.print("Temp: ");
    lcd.print(rtc.getTemperature());
    lcd.print(" C");
    delay(200);
Transmitter.ino (1.5 KB)
Receiver.ino (4.04 KB)
That's not an nrf24l01 problem at all, is it? The problem is all in the transmitter, where you have a problem with the button logic, not with sending the button states to the receiver.
Why don't you just have one button in the transmitter, and use state change detection to make that button a toggle: one click "on", next click "off", another click "on" etc.
Correct, just thought I would state what kind of setup this is running. Also don't these 2 lines in the transmitter code send the button state to the receiver?
kwonjah12:
Presumably, but so what? If you have code that determines buttons' states, it matters not what happens to those states, from the point of view of determining or setting them.
You're making a decision about the Rx end's leds, at th Tx end. If you have a flaw in your logic at the Tx end, you'll be sending the wrong stuff to the Rx.
But you could write the states down and paper and send a guy with a forked stick: that it's nrf24l01 seems to me irrelevant.
So with that out the way ;), what do you think of my one-button-suggestion....
12Stepper:
Or, if you're worried about getting confused about the next click being an on or an off (although it's easy to just have an indicator led at the Tx) you could use a toggle switch: solid on or solid off.
Seems really odd to me to have two buttons acting together...
