So I have a 16x2 LCD connected to my UNO with an NRF24L01, they share SPI pins. Both work using standalone sketches, the radio is working really well, as is the LCD. I am using the NRF24 library and the liquidcrystsal library.
My issue comes when I try to use the two in conjunction, I can write messages to the screen, but as soon as radio.begin();
is used, the 16x2 goes mad and I get a "D" on the screen instead of my message.
Here is my full code, it is an adaptation of pingpair_dyn from NRF24.
* Example using Dynamic Payloads
* This is an example of how to use payloads of a varying (dynamic) size.
#include <LiquidCrystal.h>
#include <SPI.h>
#include "nRF24L01.h"
#include "RF24.h"
// Hardware configuration
// Set up nRF24L01 radio on SPI bus plus pins 7 & 8
const int rs = 12, en = 11, d4 = 5, d5 = 4, d6 = 3, d7 = 2;
LiquidCrystal lcd(rs, en, d4, d5, d6, d7);
RF24 radio(7,8);
// sets the role of this unit in hardware. Connect to GND to be the 'pong' receiver
// Leave open to be the 'ping' transmitter
const int role_pin = 6;
// Topology
// Radio pipe addresses for the 2 nodes to communicate.
const uint64_t pipes[2] = { 0xF0F0F0F0E1LL, 0xF0F0F0F0D2LL };
// Role management
// Set up role. This sketch uses the same software for all the nodes
// in this system. Doing so greatly simplifies testing. The hardware itself specifies
// which node it is.
// This is done through the role_pin
// The various roles supported by this sketch
typedef enum { role_ping_out = 1, role_pong_back } role_e;
// The debug-friendly names of those roles
const char* role_friendly_name[] = { "invalid", "Ping out", "Pong back"};
// The role of the current running sketch
role_e role;
// Payload
const int min_payload_size = 4;
const int max_payload_size = 32;
const int payload_size_increments_by = 1;
int next_payload_size = min_payload_size;
char receive_payload[max_payload_size+1]; // +1 to allow room for a terminating NULL char
void setup(void)
// Role
lcd.begin(16, 2);
lcd.clear();
lcd.print("Hello WOrld");
delay(400);
role = role_ping_out;
// Print preamble
Serial.println(F("RF24/examples/pingpair_dyn/"));
Serial.print(F("ROLE: "));
Serial.println(role_friendly_name[role]);
delay(400);
lcd.clear();
delay(400);
lcd.print("Hello");
// Setup and configure rf radio
delay(400);
radio.begin();
// enable dynamic payloads
radio.enableDynamicPayloads();
// optionally, increase the delay between retries & # of retries
radio.setRetries(5,15);
// Open pipes to other nodes for communication
// This simple sketch opens two pipes for these two nodes to communicate
// back and forth.
// Open 'our' pipe for writing
// Open the 'other' pipe for reading, in position #1 (we can have up to 5 pipes open for reading)
if ( role == role_ping_out )
radio.openWritingPipe(pipes[0]);
radio.openReadingPipe(1,pipes[1]);
lcd.print("Ping Out");
radio.openWritingPipe(pipes[1]);
radio.openReadingPipe(1,pipes[0]);
// Start listening
//radio.startListening();
// Dump the configuration of the rf unit for debugging
Serial.print("End setup");
//radio.printDetails();
void loop(void)
// Ping out role. Repeatedly send the current time
if (role == role_ping_out)
// The payload will always be the same, what will change is how much of it we send.
static char send_payload[] = "ABCDEFGHIJKLMNOPQRSTUVWXYZ789012";
// First, stop listening so we can talk.
radio.stopListening();
// Take the time, and send it. This will block until complete
Serial.print(F("Now sending length "));
Serial.println(next_payload_size);
radio.write( send_payload, next_payload_size );
// Now, continue listening
// Wait here until we get a response, or timeout
unsigned long started_waiting_at = millis();
bool timeout = false;
while ( ! radio.available() && ! timeout )
if (millis() - started_waiting_at > 500 )
timeout = true;
// Describe the results
if ( timeout )
Serial.println(F("Failed, response timed out."));
// Grab the response, compare, and send to debugging spew
uint8_t len = radio.getDynamicPayloadSize();
// If a corrupt dynamic payload is received, it will be flushed
if(!len){
return;
radio.read( receive_payload, len );
// Put a zero at the end for easy printing
receive_payload[len] = 0;
// Spew it
Serial.print(F("Got response size="));
Serial.print(len);
Serial.print(F(" value="));
Serial.println(receive_payload);
// Update size for next time.
next_payload_size += payload_size_increments_by;
if ( next_payload_size > max_payload_size )
// Try again 1s later
delay(100);
// Pong back role. Receive each packet, dump it out, and send it back
if ( role == role_pong_back )
// if there is data ready
while ( radio.available() )
// Fetch the payload, and see if this was the last one.
if(!len){
continue;
// Spew it
Serial.print(len);
// Send the final one back.
radio.write( receive_payload, len );
Serial.println(F("Sent response."));
// Now, resume listening so we catch the next packets.
