Hello,
I am building a sensor system that has to be installed on a IIm train car (1:22.5). This car should be able to measure:
- distance (approximate, +/-50 cm maximum), solved with a reed and a magnet on the wheel
- pitch and roll of the car (in order to check if rails are placed well), solved with a 9DoF FXOS8700 + FXAS21002 gyro, accelerometer and mag.
- log the informations on an SD card, solved (pretty easy).
- Display values on a local LCD, works great
- Transmit data to a remote and receive a number from it. It WAS working one-way and now I’m lost.
The remote has an Arduino Uno, RF24L01+, a button and a led. It should display which data are displayed on the first LCD line and the values on the second. The button is used to switch between the shown data (I will call “data pages” from now on).
I have 5 data pages, selectables with an integer from 0 to 4. It has to be sent to the rail car every time the button is pressed.
The rail car will then choose which data to transmit back (16 characters, ready for my LCD).
This transmission is made at a rate around once per second. Or… -should be made-.
I managed to transmit one value from the car to the remote, but then I added the bi-directional transmission and changed a few things to make it work as desired. Now it is 4 days that I am trying to solve this problem. Any ideas? Thank you in advance!
My current code is the following (whole codes at the bottom):
Rail car/Arduino Mega: radio related instructions
//RADIO TRANSCEIVER
//Radio transceiver module present 1=yes
int txAct = 1;
//Radio transceiver CSN connected to pin
int txCsn = 8;
//Radio transceiver CE connected to pin
int txCe = 6;
//Radio Mega to Uno channel
const byte txaddress[6] = "00101";
//Radio Uno to Mega channel
const byte rxaddress[6] = "00011";
RF24 radio(txCe, txCsn);
radio.begin();
radio.openReadingPipe(0, rxaddress);
radio.setPALevel(RF24_PA_MIN);
radio.startListening();
radio.openWritingPipe(txaddress);
void texttx(void)
Serial.print("transmitting ");
char txstr[32];
int len;
String txstring1="";
String txstring2="";
String fth, ftm, fts;
float spitch, sroll;
spitch=(round(pitch*10))/10;
sroll=(round(roll*10))/10;
switch(pagec)
case 1 : //txstring2+=pagec;
txstring2+=distance;
txstring2+=odoUnit;
case 2 : //txstring2+=pagec;
txstring2+="P";
txstring2+=spitch;
txstring2+=" R";
txstring2+=sroll;
case 3 : //txstring2+=pagec;
txstring2+=heading;
case 4 : //txstring2+=pagec;
txstring2+=pmpitch;
default : //txstring2+=pagec;
if(th<100)
fth="0";
if(th<10)
fth="00";
if(tm<10)
ftm="0";
if(ts<10)
fts="0";
txstring2+=fth;
txstring2+=th;
txstring2+=":";
txstring2+=ftm;
txstring2+=tm;
txstring2+=":";
txstring2+=fts;
txstring2+=ts;
len=sizeof(txstring2);
txstring2.toCharArray(txstr,len);
Serial.println(txstring2);
if (!radio.write(&txstr, len))
Serial.println(F("failed"));
void comrx(void)
if (radio.available())
char text[] = "";
String stext;
int itext;
int len = radio.getDynamicPayloadSize();
radio.read(&text, 16);
stext=text;
itext=stext.toInt();
pagec=itext;
Arduino Uno: radio related instructions
int txAct = 1;
int txCsn = 10;
int txCe = 9;
radio.begin();
radio.openReadingPipe(1, txaddress);
radio.openWritingPipe(rxaddress);
void radiorx(void)
if (radio.available()) {
char text[32] = "";
radio.read(&text, len);
txStr=text;
lcd.clear();
lcd.setCursor(0,0);
switch(pagec)
case 1 : lcd.print("Distance");
case 2 : lcd.print("Pitch and Roll °");
case 3 : lcd.print("Heading");
case 4 : lcd.print("Steep");
default : lcd.print("Inspection Train");
lcd.setCursor(0,1);
lcd.print(txStr);
lcd.clear();
lcd.setCursor(0,0);
lcd.print("NO CONNECTION!");
void pagechange(void)
int len;
pagec=pagec+1;
if(pagec>4)
pagec=0;
while(digitalRead(interruptPin)==buttonType)
char txtext[5]="";
itoa(pagec, txtext, 1);
len=sizeof(txtext);
if (!radio.write(&txtext, len))
//Serial.println(F("failed"));
UNO_RX_v3.ino (8.21 KB)
MEGA_TX_v3.ino (14.9 KB)
