NRF24L01 and ethernet work together problem.
Normally, it is because the programmer cannot share (edit: fails to manage) the slave select pins until the individual libraries take over. That would include the uSD if you have a memory card in the ethernet shield slot.
if yes, any solution ?
Maybe. Post your code.
[/quote]
i haven start combine the code together, now what i test is i use this code to send out the data. but when i combine the arduino ethernet circuit, it not function, any extra code i need to add in?
yes, i am going to use the sd card function in my project.
#include "NRF24L01.h"
#define TX_ADR_WIDTH    5   // 5 unsigned chars TX(RX) address width
#define TX_PLOAD_WIDTH  32  // 32 unsigned chars TX payload
unsigned char TX_ADDRESS[TX_ADR_WIDTH]  =
  0x34,0x43,0x10,0x10,0x01
}; // Define a static TX address
unsigned char rx_buf[TX_PLOAD_WIDTH] = {0}; // initialize value
unsigned char tx_buf[TX_PLOAD_WIDTH] = {0};
  SPI_DIR = ( CE + SCK + CSN + MOSI);
  SPI_DIR &=~ ( IRQ + MISO);
  //  attachInterrupt(1, _ISR, LOW);// interrupt enable
  init_io();                        // Initialize IO port
  unsigned char status=SPI_Read(STATUS);
  Serial.print("status = ");
  Serial.println(status,HEX);     // There is read the mode鈥檚 status register, the default value should be 鈥楨鈥?
Serial.println("*******************TX_Mode Start****************************");
  TX_Mode();                       // set TX mode
  int k = 0;
  for(;;)
    for(int i=0; i<32; i++)
        tx_buf[i] = k++;
    unsigned char status = SPI_Read(STATUS);                   // read register STATUS's value
    if(status&TX_DS)                                           // if receive data ready (TX_DS) interrupt
      SPI_RW_Reg(FLUSH_TX,0);
      SPI_Write_Buf(WR_TX_PLOAD,tx_buf,TX_PLOAD_WIDTH);       // write playload to TX_FIFO
    if(status&MAX_RT)                                         // if receive data ready (MAX_RT) interrupt, this is retransmit than  SETUP_RETR
      SPI_Write_Buf(WR_TX_PLOAD,tx_buf,TX_PLOAD_WIDTH);      // disable standy-mode
    SPI_RW_Reg(WRITE_REG+STATUS,status);                     // clear RX_DR or TX_DS or MAX_RT interrupt flag
// Function: init_io();
// Description:
// flash led one time,chip enable(ready to TX or RX Mode),
// Spi disable,Spi clock line init high
void init_io(void)
  SPI_PORT&=~CE;			// chip enable
  SPI_PORT|=CSN;			// Spi disable
  SPI_PORT&=~SCK;			// Spi clock line init high
 * Function: SPI_RW();
 * Description:
 * Writes one unsigned char to nRF24L01, and return the unsigned char read
 * from nRF24L01 during write, according to SPI protocol
unsigned char SPI_RW(unsigned char Byte)
  unsigned char i;
  for(i=0;i<8;i++)                      // output 8-bit
    if(Byte&0x80)
      SPI_PORT |=MOSI;    // output 'unsigned char', MSB to MOSI
      SPI_PORT &=~MOSI;
    SPI_PORT|=SCK;                      // Set SCK high..
    Byte <<= 1;                         // shift next bit into MSB..
    if(SPI_IN & MISO)
      Byte |= 1;       	        // capture current MISO bit
    SPI_PORT&=~SCK;            	        // ..then set SCK low again
  return(Byte);           	        // return read unsigned char
 * Function: SPI_RW_Reg();
 * Description:
 * Writes value 'value' to register 'reg'
unsigned char SPI_RW_Reg(unsigned char reg, unsigned char value)
  unsigned char status;
  SPI_PORT&=~CSN;                   // CSN low, init SPI transaction
  status = SPI_RW(reg);             // select register
  SPI_RW(value);                    // ..and write value to it..
  SPI_PORT|=CSN;                    // CSN high again
  return(status);                   // return nRF24L01 status unsigned char
 * Function: SPI_Read();
 * Description:
 * Read one unsigned char from nRF24L01 register, 'reg'
unsigned char SPI_Read(unsigned char reg)
  unsigned char reg_val;
  SPI_PORT&=~CSN;                // CSN low, initialize SPI communication...
  SPI_RW(reg);                   // Select register to read from..
  reg_val = SPI_RW(0);           // ..then read register value
  SPI_PORT|=CSN;                 // CSN high, terminate SPI communication
  return(reg_val);               // return register value
 * Function: SPI_Read_Buf();
 * Description:
 * Reads 'unsigned chars' #of unsigned chars from register 'reg'
 * Typically used to read RX payload, Rx/Tx address
unsigned char SPI_Read_Buf(unsigned char reg, unsigned char *pBuf, unsigned char bytes)
  unsigned char status,i;
  SPI_PORT&=~CSN;                   // Set CSN low, init SPI tranaction
  status = SPI_RW(reg);       	    // Select register to write to and read status unsigned char
  for(i=0;i<bytes;i++)
    pBuf[i] = SPI_RW(0);    // Perform SPI_RW to read unsigned char from nRF24L01
  SPI_PORT|=CSN;                   // Set CSN high again
 * Function: SPI_Write_Buf();
 * Description:
 * Writes contents of buffer '*pBuf' to nRF24L01
 * Typically used to write TX payload, Rx/Tx address
unsigned char SPI_Write_Buf(unsigned char reg, unsigned char *pBuf, unsigned char bytes)
  for(i=0;i<bytes; i++)             // then write all unsigned char in buffer(*pBuf)
    SPI_RW(*pBuf++);
 * Function: TX_Mode();
 * Description:
 * This function initializes one nRF24L01 device to
 * TX mode, set TX address, set RX address for auto.ack,
 * fill TX payload, select RF channel, datarate & TX pwr.
 * PWR_UP is set, CRC(2 unsigned chars) is enabled, & PRIM:TX.
 * ToDo: One high pulse(>10us) on CE will now send this
 * packet and expext an acknowledgment from the RX device.
void TX_Mode(void)
  SPI_PORT&=~CE;
  SPI_Write_Buf(WRITE_REG + TX_ADDR, TX_ADDRESS, TX_ADR_WIDTH);    // Writes TX_Address to nRF24L01
  SPI_Write_Buf(WRITE_REG + RX_ADDR_P0, TX_ADDRESS, TX_ADR_WIDTH); // RX_Addr0 same as TX_Adr for Auto.Ack
  SPI_RW_Reg(WRITE_REG + EN_AA, 0x01);      // Enable Auto.Ack:Pipe0
  SPI_RW_Reg(WRITE_REG + EN_RXADDR, 0x01);  // Enable Pipe0
  SPI_RW_Reg(WRITE_REG + SETUP_RETR, 0x1a); // 500us + 86us, 10 retrans...
  SPI_RW_Reg(WRITE_REG + RF_CH, 40);        // Select RF channel 40
  SPI_RW_Reg(WRITE_REG + RF_SETUP, 0x07);   // TX_PWR:0dBm, Datarate:2Mbps, LNA:HCURR
  SPI_RW_Reg(WRITE_REG + CONFIG, 0x0e);     // Set PWR_UP bit, enable CRC(2 unsigned chars) & Prim:TX. MAX_RT & TX_DS enabled..
  SPI_PORT|=CE;
