Hello! Good day, I would like to ask some help for my program code regarding the problem of nrf24l01 and sim800l. Hoping you could help me finish my degree this year coz this is for my year-end project code :’( :’( . Been troubleshooting and searching the code for about a month already and don’t have enough sleep for this. I have the code below
#include <Sleep_n0m1.h>
#include <Time.h>
#include <TinyGPS++.h> // Include TinyGPS++ library
#include <SoftwareSerial.h> // Include software serial library
#include <Sim800l.h>
#define SIM800_Send 2
#include <SPI.h>
#include <nRF24L01.h>
#include <RF24.h>
RF24 radio(7, 8 );
TinyGPSPlus gps;
#define S_RX 3 // Define software serial RX pin
#define S_TX 4 // Define software serial TX pin
SoftwareSerial mySerial(10,11);
SoftwareSerial SoftSerial(S_RX, S_TX); // Configure SoftSerial library
char incomingByte;
String inputString;
long previousMillis = 0;
long interval = 1000;
int green= 9;
int red= 13;
int buzzer=12;
int i = 0;
int x = 0;
const byte rxAddr[6] = “00001”;
String content = “”;
char text;
SoftSerial.begin(9600);
while (!Serial);
pinMode(A0,OUTPUT); //tap indicator
pinMode(A2,INPUT);
pinMode(green,OUTPUT);
pinMode(red,OUTPUT);
pinMode(buzzer, OUTPUT);
digitalWrite(buzzer,HIGH);
pinMode(SIM800_Send,INPUT);
radio.begin();
mySerial.begin(9600);
while(!mySerial.available()){
mySerial.println(“AT”);
Serial.println(“Connecting…”);
Serial.println(“Connected!”);
mySerial.println(“AT+CMGF=1”); //Set SMS to Text Mode
mySerial.println(“AT+CNMI=1,2,0,0,0”); //Procedure to handle newly arrived messages(command name in text: new message indications to TE)
mySerial.println(“AT+CMGL=“REC UNREAD””);
nrf();
tracking();
battery();
void tracking(){
if(i == 0){
while(mySerial.available()){ //if there was a text received
delay(100);
// Serial Buffer
incomingByte = mySerial.read(); // the GSM reads the character
inputString += incomingByte; //if the incoming string was a new line
delay(10);
Serial.println(inputString);
inputString.toUpperCase(); // Uppercase the Received Message
if (inputString.indexOf(“OFF”) > -1){
delay(100);
mySerial.end();
i = 1;
x = 1;
delay(50);
//Delete Messages & Save Memory
if (inputString.indexOf(“OK”) == -1){
mySerial.println(“AT+CMGDA=“DEL ALL””);
delay(1000);}
inputString = “”;
if(i == 1){
// the buzzer would make a noise if the device receives an off message
if(x==1)
digitalWrite(buzzer,LOW);
//delay(120000);
x=0;
// finding the coordinates
while(SoftSerial.available()>0) { //if the GPS module was available
if(gps.encode(SoftSerial.read())) { //if the GPS has coordinates
if(gps.location.isValid()) { // checking if it is valid
// printing at the Serial monitor the latitude and the longitude
Serial.print("Latitude = “);
Serial.println(gps.location.lat(), 6);
Serial.print(“Longitude = “);
Serial.println(gps.location.lng(), 6);
digitalWrite(buzzer, LOW);
// sending the latitude and the longitude to the server
mySerial.write(“AT+CMGF=1\r\n”); // Set the module into text mode
mySerial.write(“AT+CMGS=”+639324497090”\r\n”); // send the text
mySerial.print(gps.location.lat(), 6);
mySerial.print(” ");
mySerial.print(gps.location.lng(), 6);
mySerial.write((char)26); // write all the characters*/
delay(100);
void nrf(){
radio.openReadingPipe(0, rxAddr);
radio.startListening();
if(radio.available()){
//radio.powerUp();
radio.read(&text, sizeof(text));
//Serial.println(text);
if(text == ‘2’){
content = “F7DB9173”;
Serial.println(content);
for(x=0; x<=1; x++)
digitalWrite(green,LOW);
digitalWrite(red,LOW);
digitalWrite(A0,HIGH);
delay(3000);
digitalWrite(A0,LOW);
else if(text == ‘1’){
content = “E5C1A179”;
delay(100);
void battery(){
int sensorValue = analogRead(A2);
float voltage = sensorValue * (5.0 / 1023.0);
voltage = (voltage/2.5)*5;
//Serial.println(voltage);
if (currentMillis - previousMillis > interval)
if (voltage <= 2.5)
Serial.println(“Low Battery”);
digitalWrite(red,HIGH);
else{
digitalWrite(green,HIGH);
//text=“HIGH BATTERY”;
delay(100);
When the radio.begin() initializes, the code for sim800l in the setup
( while(!mySerial.available()){
delay(500); )
keeps on responding as CONNECTING but when I remove the radio.begin(), it works perfectly fine. Is there a way that you could help me? What I need is the nrf24l01 and sim800l are just to wait for the incoming data. What I did was, when coding separately for nrf and sim800l, they work fine but when they are merged together, it no longer work. Hoping you could help me with my year-end project. I am using only one arduino nano for both of them. Please do respect.
