nRF24L01 + Arduino
I have got a nRF24L01 device (sparkfun: SparkFun Transceiver Breakout - nRF24L01+ (RP-SMA) - WRL-00705 - SparkFun Electronics ), a Arduino Diecimila and a robot.
The robot is configurated with this parameters:
Channel: 10
Address: AISOY
Payload: 32
Speed: 1 Mbps
CRC ON with 1 byte
I'm using this library: Arduino Playground - Nrf24L01 and I connected nRF24L01 with arduino as in this url.
Datasheet of nRF24L01 : Explore our product portfolio - nordicsemi.com
On page 54 can be seen the configurable registers.
My code:
#include <SPI.h>
#include <Mirf.h>
#include <nRF24L01.h>
#include <MirfHardwareSpiDriver.h>
#include "Arduino.h"
byte data[32];
void setup(){
  Mirf.spi = &MirfHardwareSpi;
  Mirf.csnPin = 8;
  Mirf.cePin = 7;
  Mirf.init();
  Mirf.payload = 32;
  Mirf.channel = 10;
  Mirf.config();
  Mirf.setRADDR((byte*)"AISAY");
  Mirf.configRegister(RF_SETUP, 0x80); //Air data rate 1Mbit, 0dBm, Setup LNA
  Mirf.configRegister(EN_AA, 0x00); //Disable auto-acknowledge
  Mirf.configRegister(SETUP_RETR, 0x00);
  Mirf.configRegister(CONFIG, 0x7B);
  Mirf.configRegister(SETUP_AW, 0x03);
  Serial.println("Configuration Success.");
void loop(){
  if(Mirf.dataReady()){
    Mirf.getData(data);
    Serial.println(data[0]);
    Mirf.flushRx();
I want send from robot to nRF24L01 a string, for example "333" and read 3 with serial monitor to verify that is working well.
But when I uploaded this sketch, and I see the serial monitor I read this (robot didn't send nothing, was off, I only was testing nRF24L01):
Why if i didn't send nothing? Noise? bad configuration? Mirf.dataReady() should be 0...
Thanks for the replys! :slight_smile:
From the datasheet I think the following line
should be
Mirf.configRegister(RF_SETUP, 0x07); //Air data rate 1Mbit, 0dBm, Setup LNA
I don't know if that makes a difference but give it a try.
pylon:
should be
Thanks!
But I tried and did not work :frowning:
a Arduino Diecimila
With a 168 or a 328?
Old thread, but for everyone with the same problem - this happens when you've connected the NRF chip incorrectly. Try swapping pins around (especially MOSI and MISO) until you get 14 as status - meaning no packets in the air. From then on you know it's connected correctly.
