NRF24l01 automatic start reciving problem
first I need to thank you becouse the NRF24L01 moduls are working. Thank you for the help in the program I sent you in the last topic. But now I have anoter problem. When I unplug the arduino like I will shut down the motorbike, and then I plug it in the reciver doesn't start to recive data until I turn on the Serial window in top right corner. I did put in the serial.print command to see if inputs are getting some signal, but it doesn't start reciving signal if the serial.print command is not included in the program?
Can you please help me once more.
I will put the program for reciving once more down in this message.
Thank you for your time.
Matej
/*2 - VCC 3.3V !!! NOT 5V
3 - CE to Arduino pin 9
4 - CSN to Arduino pin 10
5 - SCK to Arduino pin 13
6 - MOSI to Arduino pin 11
7 - MISO to Arduino pin 12
8 - UNUSED
Brakes = D2
Left Blinker = D3
Right Blinker = D4*/
/-----( Import needed libraries )-----/
#include <SPI.h>
#include <nRF24L01.h>
#include <RF24.h>
/-----( Declare Constants and Pin Numbers )-----/
#define CE_PIN 9
#define CSN_PIN 10
// NOTE: the "LL" at the end of the constant is "LongLong" type
const uint64_t pipe = 0xE8E8F0F0E1LL; // Define the transmit pipe
/-----( Declare objects )-----/
RF24 radio(CE_PIN, CSN_PIN); // Create a Radio
/-----( Declare Variables )-----/
int input[3];
int ledStateLeft = LOW;
int ledStateRight = LOW;
unsigned long previousMillisLeft = 0;
unsigned long previousMillisRight = 0;
unsigned long previousMillisLed = 0;
int done;
const long interval = 500;
void setup() /****** SETUP: RUNS ONCE ******/
pinMode(2,OUTPUT);
pinMode(3,OUTPUT);
pinMode(4,OUTPUT);
Serial.println("Nrf24L01 Receiver Starting");
radio.begin();
radio.openReadingPipe(1,pipe);
radio.startListening();
}//--(end setup )---
void loop() /****** LOOP: RUNS CONSTANTLY ******/
Serial.print(input[2]);
Serial.print('\n');
if ( radio.available() )
// Fetch the data payload
radio.read(input, sizeof(input));
/* Serial.println(input[0]);
Serial.println(input[1]);
Serial.println(input[2]);
if (input[0] >= 505)
digitalWrite(2, HIGH); // turn the LED on (HIGH is the voltage level)
{ digitalWrite(2, LOW);
if (input[1] > 505)
// check to see if it's time to blink the LED; that is, if the
// difference between the current time and last time you blinked
// the LED is bigger than the interval at which you want to
// blink the LED.
if(currentMillis - previousMillisLeft >= interval) {
// save the last time you blinked the LED
previousMillisLeft = currentMillis;
// if the LED is off turn it on and vice-versa:
if (ledStateLeft == LOW)
ledStateLeft = HIGH;
ledStateLeft = LOW;
// set the LED with the ledState of the variable:
digitalWrite(3, ledStateLeft);
else {
ledStateLeft = LOW;
if (input[2] > 505)
// blink the LED.
if(currentMillis - previousMillisRight >= interval) {
previousMillisRight = currentMillis;
if (ledStateRight == LOW)
ledStateRight = HIGH;
digitalWrite(4, ledStateRight);
else {
} //end if radio available
}//--(end main loop )---
/-----( Declare User-written Functions )-----/
//NONE
//( THE END )**
matejm2001:
Please post a link to that Topic so we can see the background.
Please also modify your post and use the code button </>
so your code
looks like this
and is easy to copy to a text editor. See How to use the Forum
Your code is too long for me to study quickly without copying to my text editor.
The programs in my Simple nRF24L01+ Tutorial don't seem to have any problem picking up new messages when either the Tx or the Rx is repowered.
...R
@matejm2001
Other post/duplicate DELETED
Please do NOT cross post / duplicate as it wastes peoples time and efforts to have more than one post for a single topic.
Continued cross posting could result in a time out from the forum.
Could you take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
