NRF24L01 can`t communicate
I have connected pins of my Arduino UNO + NRF and pro mini + NRF regarding to this tutorial:
http://arduino-info.wikispaces.com/Nrf24L01-2.4GHz-HowTo
But it is not gets respond from other NRF :frowning: Whole Serial output is about filed to get respond. I use “Getting started” library from “maniacbug”.
I am worried about RF24 radio(9,10); is connected wrongly. Is this pin numbers there ? if yes then my pin 10 is not connected on arduino boards and probably pin 9 is in wrong direction.
Help me on this please.
Turkel.
You don't show us your code and no circuitry, also no link to the used library, so it's difficult to help.
If that's correct, you haven't connected your modules like advised in the tutorial (there is no connection to pin 10).
RF24 radio(9,10);
I don`t know what are these pins on arduino and NRF.
My code is:
 Copyright (C) 2011 J. Coliz <maniacbug@ymail.com>
 This program is free software; you can redistribute it and/or
 modify it under the terms of the GNU General Public License
 version 2 as published by the Free Software Foundation.
 * Example for Getting Started with nRF24L01+ radios.
 * This is an example of how to use the RF24 class.  Write this sketch to two
 * different nodes.  Put one of the nodes into 'transmit' mode by connecting
 * with the serial monitor and sending a 'T'.  The ping node sends the current
 * time to the pong node, which responds by sending the value back.  The ping
 * node can then see how long the whole cycle took.
#include <SPI.h>
#include "nRF24L01.h"
#include "RF24.h"
#include "printf.h"
// Hardware configuration
// Set up nRF24L01 radio on SPI bus plus pins 9 & 10
RF24 radio(9,10);
// Topology
// Radio pipe addresses for the 2 nodes to communicate.
const uint64_t pipes[2] = { 0xF0F0F0F0E1LL, 0xF0F0F0F0D2LL };
// Role management
// Set up role.  This sketch uses the same software for all the nodes
// in this system.  Doing so greatly simplifies testing.
// The various roles supported by this sketch
typedef enum { role_ping_out = 1, role_pong_back } role_e;
// The debug-friendly names of those roles
const char* role_friendly_name[] = { "invalid", "Ping out", "Pong back"};
// The role of the current running sketch
role_e role = role_pong_back;
void setup(void)
  // Print preamble
  Serial.begin(57600);
  printf_begin();
  printf("\n\rRF24/examples/GettingStarted/\n\r");
  printf("ROLE: %s\n\r",role_friendly_name[role]);
  printf("*** PRESS 'T' to begin transmitting to the other node\n\r");
  // Setup and configure rf radio
  radio.begin();
  // optionally, increase the delay between retries & # of retries
  radio.setRetries(15,15);
  // optionally, reduce the payload size.  seems to
  // improve reliability
  radio.setPayloadSize(8);
  // Open pipes to other nodes for communication
  // This simple sketch opens two pipes for these two nodes to communicate
  // back and forth.
  // Open 'our' pipe for writing
  // Open the 'other' pipe for reading, in position #1 (we can have up to 5 pipes open for reading)
  if ( role == role_ping_out )
    radio.openWritingPipe(pipes[0]);
    radio.openReadingPipe(1,pipes[1]);
    radio.openWritingPipe(pipes[1]);
    radio.openReadingPipe(1,pipes[0]);
  // Start listening
  radio.startListening();
  // Dump the configuration of the rf unit for debugging
  radio.printDetails();
void loop(void)
  // Ping out role.  Repeatedly send the current time
  if (role == role_ping_out)
    // First, stop listening so we can talk.
    radio.stopListening();
    // Take the time, and send it.  This will block until complete
    unsigned long time = millis();
    printf("Now sending %lu...",time);
    bool ok = radio.write( &time, sizeof(unsigned long) );
    if (ok)
      printf("ok...");
      printf("failed.\n\r");
    // Now, continue listening
    // Wait here until we get a response, or timeout (250ms)
    unsigned long started_waiting_at = millis();
    bool timeout = false;
    while ( ! radio.available() && ! timeout )
      if (millis() - started_waiting_at > 200 )
        timeout = true;
    // Describe the results
    if ( timeout )
      printf("Failed, response timed out.\n\r");
      // Grab the response, compare, and send to debugging spew
      unsigned long got_time;
      radio.read( &got_time, sizeof(unsigned long) );
      // Spew it
      printf("Got response %lu, round-trip delay: %lu\n\r",got_time,millis()-got_time);
    // Try again 1s later
  // Pong back role.  Receive each packet, dump it out, and send it back
  if ( role == role_pong_back )
    // if there is data ready
    if ( radio.available() )
      // Dump the payloads until we've gotten everything
      bool done = false;
      while (!done)
        // Fetch the payload, and see if this was the last one.
        done = radio.read( &got_time, sizeof(unsigned long) );
        // Spew it
        printf("Got payload %lu...",got_time);
	// Delay just a little bit to let the other unit
	// make the transition to receiver
	delay(20);
      // Send the final one back.
      radio.write( &got_time, sizeof(unsigned long) );
      printf("Sent response.\n\r");
      // Now, resume listening so we catch the next packets.
  // Change roles
  if ( Serial.available() )
    char c = toupper(Serial.read());
    if ( c == 'T' && role == role_pong_back )
      printf("*** CHANGING TO TRANSMIT ROLE -- PRESS 'R' TO SWITCH BACK\n\r");
      // Become the primary transmitter (ping out)
      role = role_ping_out;
    else if ( c == 'R' && role == role_ping_out )
      printf("*** CHANGING TO RECEIVE ROLE -- PRESS 'T' TO SWITCH BACK\n\r");
      // Become the primary receiver (pong back)
// vim:cin:ai:sts=2 sw=2 ft=cpp
I have connected as on this tutorial:
Write a simple test program that sends commands and data via SPI to the nRF24L01+, and check that it is returning the correct values. If you can't communicate with the device you are wasting your time.
? am not sure 100% but i think yes it correctly communicates with SPI, because with Serial i am getting report about can`t connect to other NRF module. But still confused here, not sure how to debug this :(
Where’s the link to the RF24 library you’re using?
Reading the source code answers most questions. This is from RF24.h:
   * Constructor
   * Creates a new instance of this driver.  Before using, you create an instance
   * and send in the unique pins that this chip is connected to.
   * @param _cepin The pin attached to Chip Enable on the RF module
   * @param _cspin The pin attached to Chip Select
  RF24(uint8_t _cepin, uint8_t _cspin);
Also, have a look at the readme file to understand the configuration function of pin 10.
Couldn`t helped, i have connected RF24 radio(3,4); 3 to CE and 4 to CSN pins on NRF module as this comment says about this in RF24 code you showed above. I have checked all connected pins by multimiter if they are properly connected, soldered. I am getting timeout messages as it sends and waits then says timeout, i have also increased wait time to 500ms but still nothing differs :( help me please what else i can do.
You have to have one board configured as "ping_out" and the other as "pong_back" (refer to the variable "role"), or they won't talk to each other.
Maniacbug wrote the code so it could be configured by setting the input to pin 10 high or low, but you don't have to use that method.
For to transfer i enter T to serial and then i am getting log of failed tries to get responds. Is there are other tutorial similar to this to set and use. Would be better to have new one because this works with old version of arduino software :( Can someone give me simple test script ???
Very good tutorial information on the nRF24 series at
http://blog.diyembedded.com/
