Nrf24l01 code convertion
I need to use this code for wireless transmission… can anyone help me to convert this code into code which can tranmit using nrf24l01 module…
thanks
#if defined(ARDUINO) && ARDUINO >= 100
#include “Arduino.h”
#else
#include “WProgram.h”
#endif
#include “EMGFilters.h”
#define TIMING_DEBUG 1
#define SensorInputPin A0 // input pin number
EMGFilters myFilter;
// discrete filters must works with fixed sample frequence
// our emg filter only support “SAMPLE_FREQ_500HZ” or “SAMPLE_FREQ_1000HZ”
// other sampleRate inputs will bypass all the EMG_FILTER
int sampleRate = SAMPLE_FREQ_1000HZ;
// For countries where power transmission is at 50 Hz
// For countries where power transmission is at 60 Hz, need to change to
// “NOTCH_FREQ_60HZ”
// our emg filter only support 50Hz and 60Hz input
// other inputs will bypass all the EMG_FILTER
int humFreq = NOTCH_FREQ_50HZ;
// Calibration:
// put on the sensors, and release your muscles;
// wait a few seconds, and select the max value as the threshold;
// any value under threshold will be set to zero
static int Threshold = 0;
unsigned long timeStamp;
unsigned long timeBudget;
/* add setup code here */
myFilter.init(sampleRate, humFreq, true, true, true);
// open serial
// setup for time cost measure
// using micros()
timeBudget = 1e6 / sampleRate;
// micros will overflow and auto return to zero every 70 minutes
/* add main program code here /
// In order to make sure the ADC sample frequence on arduino,
// the time cost should be measured each loop
------------start here-------------------*/
timeStamp = micros();
int Value = analogRead(SensorInputPin);
// filter processing
int DataAfterFilter = myFilter.update(Value);
int envlope = sq(DataAfterFilter);
envlope = (envlope > Threshold) ? envlope : 0;
timeStamp = micros() - timeStamp;
if (TIMING_DEBUG) {
    // Serial.print("Read Data: "); Serial.println(Value);
    // Serial.print("Filtered Data: ");Serial.println(DataAfterFilter);
    Serial.print("Squared Data: ");
    Serial.println(envlope);
    // Serial.print("Filters cost time: "); Serial.println(timeStamp);
    // the filter cost average around 520 us
/*------------end here---------------------*/
// if less than timeBudget, then you still have (timeBudget - timeStamp) to
// do your work
delayMicroseconds(500);
// if more than timeBudget, the sample rate need to reduce to
// SAMPLE_FREQ_500HZ
Your topic has been moved here as this forum section is more appropriate than where it was originally posted.
Please take care to post in the correct forum section
ok understood
