Hi Everyone
I have made code to transmit data from transmitter to receiver uisng NRF24L01.
Connection, acknowledgment everything works fine. but after few hours i can notice that there was connection lost for few minutes and reconnected again.
I have attached 10microFarad capacitor to both nrf24l01. At transmitter side i am using simple NRF24L01 without antenna and receiver side i am using nrf with antenna.
Receiver is placed inside truck cabin and transmitter is placed out side the cabin near. distance between then is around 10 meters.
can some one please check the code and help me how to solve this issue.
Thanks in advance
Transmitter code
#include <avr/sleep.h>
#include <avr/power.h>
#include <avr/wdt.h>
#include <SPI.h>
#include "RF24.h"
#define TRANSMITER_NUM 0 // or 1
#define TILT_PIN 3
const uint64_t talking_pipes[2] = { 0xF0F0F0F0D1LL, 0xF0F0F0F0C2LL };
const uint64_t listening_pipes[2] = { 0x3A3A3A3AD1LL, 0x3A3A3A3AC2LL };
struct DataPacket {
int voltage;
bool tilt;
bool volatile interruptTriggered = false;
RF24 radio(7,8);
void TiltPinInterrupt(void)
sleep_disable();
detachInterrupt(digitalPinToInterrupt(TILT_PIN));
interruptTriggered = true;
void watchdogSetup(void)
wdt_reset();
WDTCSR = bit (WDCE) | bit (WDE);
WDTCSR = bit (WDCE) | bit (WDE) | bit (WDIE) | bit (WDP3) | bit (WDP0);
void disableHardware() {
radio.powerDown();
power_spi_disable();
power_timer0_disable();
power_timer1_disable();
power_timer2_disable();
power_twi_disable();
power_usart0_disable();
ADCSRA &= ~(1 << ADEN);
power_adc_disable();
void enableHardware() {
power_spi_enable();
power_timer0_enable();
power_timer1_enable();
power_timer2_enable();
power_twi_enable();
#ifdef SERIAL_PRINT
power_usart0_enable();
#endif
power_adc_enable();
radio.powerUp();
void enterSleep(void)
{ADCSRA = 0;
sleep_enable();
disableHardware();
set_sleep_mode(SLEEP_MODE_PWR_DOWN);
cli();
noInterrupts();
MCUSR = 0;
watchdogSetup();
attachInterrupt(digitalPinToInterrupt(TILT_PIN), TiltPinInterrupt, CHANGE);
sei();
interrupts();
sleep_cpu();
sleep_disable();
enableHardware();
pinMode(TILT_PIN, INPUT);
radio.begin();
radio.setAutoAck(false);
radio.setPALevel(RF24_PA_MAX);
radio.setDataRate(RF24_250KBPS);
radio.setChannel(108);
radio.openWritingPipe(talking_pipes[TRANSMITER_NUM]);
radio.openReadingPipe(1,listening_pipes[TRANSMITER_NUM]);
radio.startListening();
getBandgap();
#ifdef SERIAL_PRINT
Serial.println("Initialisation complete.");
#endif
ISR (WDT_vect)
wdt_disable();
const long InternalReferenceVoltage = 1100;
int getBandgap ()
ADMUX = bit (REFS0) | bit (MUX3) | bit (MUX2) | bit (MUX1);
ADCSRA |= bit( ADSC );
while (ADCSRA & bit (ADSC))
int results = (((InternalReferenceVoltage * 1024) / ADC) + 5) / 10;
return results;
int cnt=0;
bool sendValue = false;
DataPacket data;
cnt++;
if (cnt >=3 ) {
cnt = 0;
sendValue = true;
if (interruptTriggered) {
sendValue = true;
if (sendValue) {
cnt = 0;
data.voltage = getBandgap();
data.tilt = digitalRead(TILT_PIN);
int resend = 0;
do {
resend++;
radio.stopListening();
if (radio.write( &data, sizeof(data) )) {
unsigned long started_waiting_at = millis();
bool timeout = false;
while ( ! radio.available() && ! timeout )
if (millis() - started_waiting_at > 250 )
timeout = true;
if ( timeout )
#ifdef SERIAL_PRINT
Serial.println("Failed, response timed out.\n\r");
#endif
unsigned long dummy;
radio.read( &dummy, sizeof(unsigned long) );
#ifdef SERIAL_PRINT
Serial.println("Got response");
#endif
resend = 0;
#ifdef SERIAL_PRINT
Serial.println("Error sending values");
#endif
} while ((resend > 0) && (resend <=3));
#ifdef SERIAL_PRINT
Serial.println(data.voltage, DEC);
Serial.println(data.tilt, DEC);
delay(100);
#endif
enterSleep();
Receiver code
#include <SPI.h>
#include "RF24.h"
#define LED_TILT 3
#define LED_VOLTAGE 4
#define LOW_BATTERY 260
struct DataPacket {
int voltage;
bool tilt;
DataPacket data[2];
unsigned long lastMilis[2];
RF24 radio(7,8);
wdt_reset();
WDTCSR = bit (WDCE) | bit (WDE) | bit (WDIE) | bit (WDP3) | bit (WDP0); // set WDIE, and 8 seconds delay
pinMode(LED_TILT, OUTPUT);
pinMode(LED_VOLTAGE, OUTPUT);
radio.begin();
radio.setChannel(0x66);
radio.openReadingPipe(1,talking_pipes[0]);
radio.openReadingPipe(2,talking_pipes[1]);
data[0].voltage = 500;
data[0].tilt = 1;
data[1].voltage = 500;
data[1].tilt = 1;
lastMilis[0] = 0;
lastMilis[1] = 0;
unsigned long previousMillis = 0;
long interval = 1000;
uint8_t pipe_num;
if ( radio.available(&pipe_num) )
unsigned long got_time;
bool done = false;
Serial.println(pipe_num, DEC);
radio.read(&data[pipe_num - 1], sizeof(DataPacket) );
lastMilis[pipe_num - 1] = millis();
Serial.println(data[pipe_num - 1].voltage, DEC);
Serial.println(data[pipe_num - 1].tilt, DEC);
radio.openWritingPipe(listening_pipes[pipe_num-1]);
radio.write( &got_time, sizeof(unsigned long) );
printf("Sent response to %04x.\n\r",pipe_num);
if (currentMillis > (lastMilis[0] + 30000)) {
data[0].tilt = true;
data[0].voltage = 0;
if (currentMillis > (lastMilis[1] + 30000)) {
data[1].tilt = true;
data[1].voltage = 0;
if ((!data[0].tilt) || (!data[1].tilt))
digitalWrite(LED_TILT, HIGH);
digitalWrite(LED_TILT, LOW);
if ((data[0].voltage >= LOW_BATTERY) && (data[1].voltage >= LOW_BATTERY))
digitalWrite(LED_VOLTAGE, LOW);
if ((data[0].voltage < LOW_BATTERY) && (data[1].voltage < LOW_BATTERY))
digitalWrite(LED_VOLTAGE, HIGH);
else {
if (data[0].voltage < LOW_BATTERY)
interval = 1000;
interval = 2000;
if (currentMillis - previousMillis >= interval) {
if (digitalRead(LED_VOLTAGE) == LOW) {
