NRF24L01+ for RC Car
Hello, I'm having trouble with this code. I'm getting a "void value not ignored as it ought to be." Here are the codes:
/* pins connections
  • vcc 3.3
  • gnd gnd
  • ce pin9
  • csn pin8
  • sck pin13
  • mosi pin11
  • miso pin12
Transceiver
#include <SPI.h>
#include <nRF24L01.h>
#include <RF24.h>
#define CE_PIN 9
#define CSN_PIN 8
const uint64_t pipe = 0xE8E8F0F0E1LL;
RF24 radio(CE_PIN, CSN_PIN);
char data[] = "Hello World, Electronic Clinic";
 radio.begin();
 radio.openWritingPipe(pipe);
 radio.write( data, sizeof(data) );
Receiver
#include <SPI.h>
#include <RF24.h>
RF24 radio(9, 8); // CE, CSN
const byte address[6] = "00001";
radio.begin();
radio.openReadingPipe(0, address);
radio.setPALevel(RF24_PA_MIN);
radio.startListening();
if (radio.available()) {
    char text[32] = "";
radio.read(&text, sizeof(text));
Serial.println(text);
Welcome to the forum
Both sketches compile OK for me
Please post the full error message copied from the IDE using the "Copy error message" button
. . . and say which RF24 library you are using or where you found it.
Okay, sorry about that you all. I had the ports mixed up. The codes uploaded, but the text isn't being sent. I'm going to update this library, which I thought was already updated. The library is RF24Network by TMRh20, Avamander OSI Layer 3 Networking for nrf24L01(+) devices.
Okay, so the Getting Started sketch worked. The problem was I couldn't read anything because of the baud rate. I've noticed my baud rate always has to override 115200. So I change the baud rate to that in the serial monitor. It took a little time to show all of the letters for the transmission though. However, I kept getting "Transmission failed or timed out" on the transmitter end. Then on the receiver end, I'm still getting "Radio hardware is not responding". I'm thinking it's because my wires aren't crimped tight enough on the female connector end. It transmits after I wiggle the wire. Here's the Getting Started code I used:
 * See documentation at https://nRF24.github.io/RF24
 * See License information at root directory of this library
 * Author: Brendan Doherty (2bndy5)
 * A simple example of sending data from 1 nRF24L01 transceiver to another.
 * This example was written to be used on 2 devices acting as "nodes".
 * Use the Serial Monitor to change each node's behavior.
#include <SPI.h>
#include "printf.h"
#include "RF24.h"
// instantiate an object for the nRF24L01 transceiver
RF24 radio(9, 8);  // using pin 7 for the CE pin, and pin 8 for the CSN pin
// Let these addresses be used for the pair
uint8_t address[][6] = { "1Node", "2Node" };
// It is very helpful to think of an address as a path instead of as
// an identifying device destination
// to use different addresses on a pair of radios, we need a variable to
// uniquely identify which address this radio will use to transmit
bool radioNumber = 1;  // 0 uses address[0] to transmit, 1 uses address[1] to transmit
// Used to control whether this node is sending or receiving
bool role = false;  // true = TX role, false = RX role
// For this example, we'll be using a payload containing
// a single float number that will be incremented
// on every successful transmission
float payload = 0.0;
  while (!Serial) {
    // some boards need to wait to ensure access to serial over USB
  // initialize the transceiver on the SPI bus
  if (!radio.begin()) {
    Serial.println(F("Radio hardware is not responding!!"));
    while (1) {}  // hold in infinite loop
  // print example's introductory prompt
  Serial.println(F("RF24/examples/GettingStarted"));
  // To set the radioNumber via the Serial monitor on startup
  Serial.println(F("Which radio is this? Enter '0' or '1'. Defaults to '0'"));
  while (!Serial.available()) {
    // wait for user input
  char input = Serial.parseInt();
  radioNumber = input == 1;
  Serial.print(F("radioNumber = "));
  Serial.println((int)radioNumber);
  // role variable is hardcoded to RX behavior, inform the user of this
  Serial.println(F("*** PRESS 'T' to begin transmitting to the other node"));
  // Set the PA Level low to try preventing power supply related problems
  // because these examples are likely run with nodes in close proximity to
  // each other.
  radio.setPALevel(RF24_PA_MIN);  // RF24_PA_MAX is default.
  // save on transmission time by setting the radio to only transmit the
  // number of bytes we need to transmit a float
  radio.setPayloadSize(sizeof(payload));  // float datatype occupies 4 bytes
  // set the TX address of the RX node into the TX pipe
  radio.openWritingPipe(address[radioNumber]);  // always uses pipe 0
  // set the RX address of the TX node into a RX pipe
  radio.openReadingPipe(1, address[!radioNumber]);  // using pipe 1
  // additional setup specific to the node's role
  if (role) {
    radio.stopListening();  // put radio in TX mode
    radio.startListening();  // put radio in RX mode
  // For debugging info
  // printf_begin();             // needed only once for printing details
  // radio.printDetails();       // (smaller) function that prints raw register values
  // radio.printPrettyDetails(); // (larger) function that prints human readable data
}  // setup
  if (role) {
    // This device is a TX node
    unsigned long start_timer = micros();                // start the timer
    bool report = radio.write(&payload, sizeof(float));  // transmit & save the report
    unsigned long end_timer = micros();                  // end the timer
    if (report) {
      Serial.print(F("Transmission successful! "));  // payload was delivered
      Serial.print(F("Time to transmit = "));
      Serial.print(end_timer - start_timer);  // print the timer result
      Serial.print(F(" us. Sent: "));
      Serial.println(payload);  // print payload sent
      payload += 0.01;          // increment float payload
      Serial.println(F("Transmission failed or timed out"));  // payload was not delivered
    // to make this example readable in the serial monitor
    delay(1000);  // slow transmissions down by 1 second
    // This device is a RX node
    uint8_t pipe;
    if (radio.available(&pipe)) {              // is there a payload? get the pipe number that recieved it
      uint8_t bytes = radio.getPayloadSize();  // get the size of the payload
      radio.read(&payload, bytes);             // fetch payload from FIFO
      Serial.print(F("Received "));
      Serial.print(bytes);  // print the size of the payload
      Serial.print(F(" bytes on pipe "));
      Serial.print(pipe);  // print the pipe number
      Serial.print(F(": "));
      Serial.println(payload);  // print the payload's value
  }  // role
  if (Serial.available()) {
    // change the role via the serial monitor
    char c = toupper(Serial.read());
    if (c == 'T' && !role) {
      // Become the TX node
      role = true;
      Serial.println(F("*** CHANGING TO TRANSMIT ROLE -- PRESS 'R' TO SWITCH BACK"));
    } else if (c == 'R' && role) {
      // Become the RX node
      role = false;
      Serial.println(F("*** CHANGING TO RECEIVE ROLE -- PRESS 'T' TO SWITCH BACK"));
}  // loop
I suggest that you try the simpler examples in Robin2's simple rf24 tutorial.
If you read and, closely, follow Robin2's simple rf24 tutorial you should be able to get the radios working. That tutorial sure helped me. The code in the simple examples has been proven to work many many times. If it does not work for you, there is likely a hardware problem.
Run the CheckConnection.ino (look in reply #30 in the tutorial) to verify the physical wiring between the radio module and its processor (Arduino).
Okay, thanks. Yeah, if it is a hardware problem it's probably from the wires I crimped. I've been wondering about this version I got from Amazon also. I saw on this forum how it has to run on the old bootloader. I'm thinking this may be a problem also. The root of the problem is probably the wire crimping though. I'll try this sketch you provided, the one I used is working on the transmitter end. This is only when I hold the wires. It is not working on the receiver's end though. I'm thinking for the same reason. Thanks again :grin:.
Okay, the Getting Started sketch was working, but then it stopped. I tried the sketch from the Robin2's simple rf24tutorial, CheckConnection.ino, and that didn't work either. I think I'm going to have to recrimp some wires, or maybe desolder these capacitors I put on there. I tried turning up the PA level to HIGH and MAX too. Somone told me I should change the channel though. I've ran the Scanner example, and sometimes it's all F's, but now it's this.
RF24/examples/scanner/
SPI Speedz	= 10 Mhz
STATUS		= 0x00 RX_DR=0 TX_DS=0 MAX_RT=0 RX_P_NO=0 TX_FULL=0
RX_ADDR_P0-1	= 0x0000000000 0x0000000000
RX_ADDR_P2-5	= 0x00 0x00 0x00 0x00
TX_ADDR		= 0x0000000000
RX_PW_P0-6	= 0x00 0xff 0x00 0xff 0xff 0xff
EN_AA		= 0x00
EN_RXADDR	= 0x00
RF_CH		= 0x00
RF_SETUP	= 0x00
CONFIG		= 0x1f
DYNPD/FEATURE	= 0x00 0x00
Data Rate	= 1 MBPS
Model		= nRF24L01+
CRC Length	= Disabled
PA Power	= PA_MIN
ARC		= 15
000000000000000011111111111111112222222222222222333333333333333344444444444444445555555555555555666666666666666677777777777777
0123456789ABCDEF0123456789ABCDEF0123456789ABCDEF0123456789ABCDEF0123456789ABCDEF0123456789ABCDEF0123456789ABCDEF0123456789ABCD
-----111111112---2-----1-1---111-2-------22-12--1-1-12------23-11111-121--1-11----2-2-12---11--13-4-1-1-11--11--1-----211----1
---1--1----24-1-2-1-22-1-22-1221-1-1-22--1-1-111-11131-4-113-1-1-2----1--1---11-1-221---1-1-1---12-1-1-----11112-212-1--2--11-
-1-------1-1------11-12--1-121--2-111-126--1-11-11-111-121122--------21--3--1-132-111-111-1112---1-21----1---1----112----11-11
11-12-21---1-----1-111---1--1--11-111-11-1-112111---1----1--112-21-1---21-1-21-1-1--111-1---113--11-1-211----12-1-111113----1-
11-11111--12-11-1------1-1---11-1-----22--21-1-11--1---2---1---1-----1111-1-1-2-12--1-11-21---21---1-------221--12-13--21-12-1
11-1---1121-11121-12---12---11---121-1--2-3-11111-1---11-----1---112-2-----1-1113---112--11-111--121-232-1-2-11---1--------3--
2------2--1-121121-2-2-13-13-2--1--1---21-1-----1-11-11-----1--1211-21----2-21----122-11-32-1-1211---11---111-1-----2-1112-11-
-1-1---1-1111211-121-2---1--11-1-----------1121121---1-2----1--121--2-11---221111-11111---12-11------1-11-------2-1112111-----
Does anyone know what this means?
