First of all this is my first post and hopefully i did not mess up from the beginning by posting in the wrong topic.
Back to the subject, i'm working on a project with it's purpose to control my heating/cooling system in my house. The project includes a few temperature/humidity sensors which are using nRF24L01 to communicate with a master receiver.
The sensors are sending data every 5 seconds to the receiver where the receiver decide which actuator to turn on/off.
The problem
I use an LED to indicate a successful data transmission.
1 flash - data sent ok
2 flashes - data sent nok
I defined a variable to check if the transmission has been successful or not. The problem is that even when the transmission is successful the LED flashes 2 times.
On the serial monitor data is received every 5 seconds without problems.
This happens randomly, let's say 70% nok and 30% ok.
Being on development phase the distance between sensor and receiver is max 2 meters, range problems is excluded.
for (int i=0; i<=3; i++){
delayMicroseconds(random(200, 500));
radio.write(&nRF24_SEND_DATA, sizeof(nRF24_SEND_DATA));
This statement:
if (RADIO_DATA_SENT_FLAG == true){break;}
will never evaluate to true, since the else block would not have been entered if RADIO_DATA_SENT_FLAG == true, and you don't change the value of RADIO_DATA_SENT_FLAG after that, maybe you meant to do this:
RADIO_DATA_SENT_FLAG = radio.write(&nRF24_SEND_DATA, sizeof(nRF24_SEND_DATA));
Either way, what happens is if the first transmission attempt fails, then the retransmission attempts succeed, you will still get the double blink that you expect to indicate a failed transmission.
Thank you for your advice.
On the last part of the code i deliberately let the LED to double flash if the first transmission failed, even if the second retry succeeded.
In mean time i have changed the code, i remove the "1 flash" part because it's not really important for me.
During the tests i found that if on the "void setup" part of the code i use "radio.setRetries(1, 3);" the code does not run as expected.
Looks like the first transmission fails every time. If i remove "radio.setRetries(1, 3);" everything is fine.
I don't get it, clearly i miss something here...
